Jes Ascanius Radiant collector
  • #46
    Hi Jes & others,
    My question directly goes to Jes but in his absence I would look forward to a reply from any knowledgeable person.
    In the article (Practical Guide to Free-Energy Devices - Chapter 7) it says;
    "This circuit looks completely mad as the aerial input to the circuit appears to be directly short-circuited by the second earth connection."
    Can you please explain as to why you had done that, as I can not see the logic behind it.
    CJ
    • #47
      Simular?
      Hi all,
      You guys seen this one?:
      free energy generator - raw video footage - uncut version - YouTube
      First version:
      free energy generator - partlist included - 100% free - YouTube
      Now if you imagine the magnet going in the coil..
      It reminds me of Tesla's car, the rods (magnet cylinder) shoven into a box (the cil) and an antenna..
      • #48
        The circuit is a fake. He has batteries in motor and voltmeter, and use coil as starter(short circuit). A very good fake
        • #49
          hi all, i started a thread on this the other day (tesla style earth battery) not realising there were allready so many threads on the topic. seeing this thread is still in use i hope the author does not mind if i post my ideas and findings here so all info is in the same place and easyer to find.
          if you read my post you will find i have a very simple setup, 2 heavy copper wires, 1 connected to a copper tap for ground and the other connected to my metal roof for antenna, this on its own reads 0.3dcv. i wound a large coil and attached it with a joule theif, using this i can get a reading up to 8.5dcv. im new to all this and have done alot of research in the last few months but there is so much to learn so all i really know are the basics. im not using capacitors, inverters/converters or any form of battery,just a heep of copper wire to get this reading. i read that some have a reading that dissapers? i can short mine out and it will read 8.5dcv instantly without it having to build up a charge again.it has run an led 24/7 for the last few months and every now and again i attach another 7 to is, 8 leds will light fairly bright from this but not to their full potential,also i done some tests on it, at the time it was sitting on 5.5dcv and reading 4.5dca, im hoping i could get some advice for a novice, at the moment i have up to 8.5dcv at times running straight into the ground, now that i have a basic knowlage of circuits, i would like to charge a car battery of it so the energy isnt been wasted and maybe run some outdoor lights of it
          my problem is i dont know what voltage i need to charge a car battery? weather a car battery is the correct choice of battery to charge of 5-8dcv and also how to correctly charge a battery?
          im hoping that someone with knowlage could help me out with a simple charging circuit for a battery that would be suited for this application, if i can atleast charge a battery it will be a big start for me and much more usefull then sending it back into the ground, also if anyone has ideas they would like me to test for them i will be your crash test dummy and post all info here, unless you want it to be kept private. i would rather share the info with everyone and anyone that is interested though
          • #50
            also i just opened the link above "Davs homemade loop antennas" sorry i should have looked at it first, i believe this has a huge part in its opperation but not used as an antenna, instead as a pancake coil which acts like a capacitor, if you look in teslas pics there is 1 with him sitting in a chair, you can see a huge pancake coil on his wall, it looks like a peice of art work but if zoomed in you can see it is actually a coil with a hole in the centre, in another pic he is working on a project and in the back ground there is his coil with a plug in the centre of the coil with a cord attached running from the plug, i think what he was doing was using the coil as a capacitor to hold a huge amount of energy coming from his antenna, then was shorted out using something like a joule theif, the wire im using is just an extention cord, i cut the outer insulation of it to get the 3 wires inside and then rolled a coil with it. im thinking of winding a large pancake coil out of it and see what happens.the idea im going with is the larger the amount of copper, the larger the energy it holds.
            what does everyone else think?
            • #51
              Originally posted by C_J View Post
              Hi Jes & others,
              CJ
              It is mad, but it worked, try it urself.
              Jes schematic, (not the schematic actually, but his actual wiring) posed a great similarity to what Dr. Harold Aspden called "magic capacitor"
              and Jes suggestion in his post, to use limestone covered metal .. it also worked as he said , i used white cement with quartz sand to cover a polished aluminum plate though.
              • #52
                Nice work Gav
                But is your metal roof insulated, I don't think so
                I'm also looking for the same info as you are.
                Is there anybody using this kind of radiant energy for any practical purpose?
                I also would like to know how to charge a 12V battery out of it.
                If I can do that, then I can use an inverter to run any AC device.
                • #53
                  just google "how to trickle charge a battery"
                  basically u need about 12v-13v if ur battery is 12v. constant trickling amperage will eventually fill up ur battery. connect (+) to (+) and (-) to (-).
                  • #54
                    Nice work Gav
                    My plate is under roof insulation, but I live in a city which is already 200m above sea level, and my plate is under the roof of a 2 story house. so yes it is quite high. as for grounding, its a solid 20mm copper rod 1 meter long plunged down into a water well.
                    • #55
                      thanks mate im looking into it now
                      • #56
                        out of interest, how big are the plates you guys are using? the way im thinking the receiver plate should not be insulated, we are trying to collect a chemical reaction that is naturally created on the surface of a metal object, if it is exposed to the natural enviroment it will continue to make this reaction, im even thinking the reaction of rusting metal could be a part of it also, apperantly elevation makes a difference but i live on a river 30m above sea level, my advantage is a large metal roof. if you havnt seen this watch this vid, the guy give a really good explanation of electricity, from what this guy was saying made me realise what teslas pancake coil on his wall was for and why i wound a large thick coil to create back emf from
                        UNLIMITED FREE ENERGY IDENTIFIED Part 2 - YouTube
                        • #57
                          My charger runs at 13.9 volt
                          • #58
                            Tesla very specifically states the metal plate should be polished and insulated.
                            Even Jes Ascanius had outlined that fact as following;
                            1. The plate must be high off the ground.
                            2. The plate must be polished and insulated.
                            3. The wire must be single-strand solid wire.
                            4. There must not be any part of the wire above the circuit, which is not insulated.
                            Other fact is that it's not how high you are above the sea level, but how high your are above your ground level.
                            • #59
                              im on a fairly steep mountain in a single story house, the weird thing is i allways get negitive readings, i think my ground is stronger then my antenna and it swapped the positive and negitive somehow? my ground is run to a copper pipe which comes from our water tank,there is then a very long pipe run to the top of the mountain where we have a natural spring, could it could be working in reverse? the large insulated antenna is the large plastic water tank? tesla was going to drill and tap into the earths underground water where the magnetic feilds are stronger, or something like that?, we have 3 natural springs on the mountain here that i know of. oh and our reception here is zero, we have no mobile phone reception here and very few radio stations can be picked up, im still amazed every time i look at it and the led is on
                              • #60
                                If your ground is,
                                "a copper pipe which comes from our water tank,there is then a very long pipe run to the top of the mountain"
                                then it is not a ground as the copper pipe run to the top of the mountain. So it is above your roof. Is that copper pipe under ground?
                                Another point is "large plastic water tank" can not be a antenna as it is plastic!
