Has Anyone Made this Efficienct Generator?
  • Has Anyone Made this Efficienct Generator?
    it seems well within the means of being simple enough to do.
    -pdf-
    0P3N S0UR(E 3NG1N33R1NG
    Nor did the fellow who declared it efficient. His secondary idea that he has also not built (using large coils instead of magnets or motionless) shows you his understanding of time constants in electrical circuits. The design can simplify home built generators by making the balance and attachment of moving objects safer. Beyond that you will have to figure out somethng different on the issue of efficiency.
      fair enough
        John Ecklin's Stationary Armature Generator (SAG)
        -pdf-
        http://www.zeitgeist.si/sites/defaul...enerator_0.pdf
        Dear Nate,
        The plans at your link are a typical rip-off job by Creative Science. The generator depicted on the front page was invented by John Ecklin in 1979. It was an unpatented variant to his US Patent #3,879,622. This was the first design, proposed 33 years ago, that has lead to ALL of the work going on in all of these threads on reduced back-emf generators and machines that can circumvent Lenz Law.
        The plans do not lead to the understanding of a "High Efficiency Generator", as proposed. There is simply too much magnetic flux leakage and poor magnetic flux coupling between the input and the output to produce either high efficiency output or low back-emf behavior.
        Best regards,
        Peter
        Peter Lindemann, D.Sc.
          Hi Nasa Nate
          I strongly recommend reading Hugh Piggot at
          Hugh Piggott's home page
          I used his plans for my windmills and continue to use similar designs for my Watson machine experiments. See Electricity's Watson machine thread.
          The plans are easy to follow and build. they are also easy to adapt to whatever you are working on. Let me know if you have any questions about them.
          Bizzy
          Smile it doesn't hurt!
          Jesus said,"...all things are possible through God." Mk10:27
            Wow thank you for the leads!
            ah that makes me curious....how many have trodden the path before me. and also attempted building the updated fuelless engine aka the "pancake" motor...
            ...and a part of me still wants to give it a go...because i learn with my hands. . .
