Large Scottish Pumped Storage Hydroelectric Reservoir and Dam
  • Large Scottish Pumped Storage Hydroelectric Reservoir and Dam
    I am presenting here my vision for a large pumped storage hydroelectric 2-square kilometres surface-area reservoir and 300+ metre tall dam which I have designed for the Coire Glas site, Scotland.
    (View site using Google Earth where the convenient label is "Loch a' Choire Ghlais" - or, Loch a' Choire Ghlais - Google Maps)
    I was inspired to conceive and to publish my vision by learning of the Scottish and Southern Energy (SSE) proposal to build a smaller hydroelectric pumped-storage scheme at Coire Glas which has been presented to the Scottish government for public consultation.
    I have not long been aware of the SSE plan for the Coire Glas scheme, not being a follower of such matters routinely, but I was prompted by an earlier tangentially-related news story (about energy storage technology for renewable energy generators such as wind farms) to write to Members of the Scottish Parliament on the merits and urgency of new pumped storage hydroelectric power for Scotland on 14th February and a reply from Ian Anderson, the parliamentary manager for Dave Thomson MSP received the next day, the 15th February informed me about the SSE plan and Ian added "initially scoped at 600MW but, to quote SSE, could be bigger!"
    I replied to Ian "So the schemes proposed by the SSE are welcome and ought to be green-lighted and fast-tracked, but I am really proposing that Scots start thinking long term about an order of magnitude and more greater investment in pumped storage hydroelectric capacity than those SSE plans."
    So I had in mind "bigger would be better" but it was not until the next day on the 16th February when a news story informed me that the SSE plans had been submitted to the Scottish government for public consultation that I thought "this needs consideration now".
    So starting late on the night of the 17th, early 18th February and all through the weekend, I got busy, outlining my alternative vision for a far bigger dam and reservoir at the same location.
    So this is my vision as inspired by the SSE plan. If my vision is flawed then the fault is mine alone. If my vision is brilliant, then the brilliance too is mine.
    Image also hosted on postimage
    The black contour line at 550 metres elevation shows the outline of the SSE proposed reservoir of about 1 square kilometre surface-area and the grey thick line shows the position of the proposed SSE dam which would stand 92 metres tall and would be the tallest dam in Scotland and indeed Britain to date though it seems our dams are several times smaller than the tallest dams elsewhere in the world these days.
    Part of the red contour line at 775 metres elevation, where the red line surrounds a blue shaded area, blue representing water, shows the outline of my larger reservoir of about 2 square kilometres surface-area and the thicker brown line shows the position of my proposed dam which would stand 317 metres tall which would be one of the tallest man-made dams in the world.
    Enhanced satellite photograph
    Image also hosted on PostImage.Org
    Cross section of the Dow-dam
    The Dow-dam would be more than 3 times higher than the proposed SSE-dam. In this diagram, a horizontal line one third of the way up the Dow-dam indicates the relative height of the SSE dam although it is not aligned with this cross-section.
    Maps showing the line of cross-section viewed from each side
    Cross section of the Dow-dam reservoir
    Cross section along the major diameter of the elliptical excavation of the reservoir bed
    Also hosted on PostImage.org
    Excavated Reservoir Bed
    The green ellipse of major diameter of 1.5 kilometres and minor diameter of 1 kilometre represents an excavated reservoir bed, as flat and as horizontal as practical, at an elevation of 463 metres.
    Since an excavated reservoir bed is not, that I can see, part of the SSE plan, at any size, I will provide some more information about my vision for that now.
    The basic idea of excavating a flat or flattish reservoir bed is to increase the volume of the water stored in the reservoir because more water means more energy can be stored.
    Depending on the geology and strength of the rock of Coire Glas the walls of the reservoir bed perimeter could be as steep as vertical from the reservoir bed up to the natural elevation of the existing rock surface which would mean, presumably, blasting out rock to create a cliff which at places could be as much as about 290 metres tall.
    Near the dam, the reservoir bed perimeter wall would be only 40 metres or less tall. The further from the dam, the higher the wall will be and the more rock needs to be excavated.
    A vertical reservoir bed perimeter wall would be ideal to maximise reservoir volume wherever the geology provides a strong stone which can maintain a vertical wall face without collapse, (a stone such as granite perhaps).
    Where the geology only provides a weaker stone then a sloping perimeter wall at a suitable angle of repose for reliable stability would be constructed.
    So the reservoir perimeter wall could be as sloped as shallow as 45 degrees from the natural elevation at the perimeter of the eclipse sloping down to the reservoir bed at 463 metres elevation in the case of the weakest and most prone to collapse kinds of stone.
    Exactly how strong the stone is at each location I guess we'll only find out absolutely for sure if and when engineers start blasting it and testing the revealed rock wall face for strength.
    The shape of the perimeter of the excavated reservoir bed is not absolutely critical. So long as it ends up as a stable wall or slope, however it is shaped by the blasting, it will be fine. There is no need to have stone masons chip the perimeter smooth and flat! The ellipse is simply the easiest approximate mathematical shape to describe and to draw. If the end result is not a perfect ellipse, don't worry, it will be fine!
    OK, well I guess that's the vision part over. The rest is fairly straight-forward engineering I hope. Oh, and there is always getting the permission and the funding to build it of course which is never easy for anything this big.
    OK, well if anyone has any questions or points to make about my vision or can say why they think the SSE plan is better than mine, or if you don't see why we need any pumped storage hydroelectric scheme at Coire Glas, whatever your point of view, if you have something to add in reply, please do.
    Last edited by Peter Dow; 02-27-2012, 01:16 AM. Reason: Changing the title to see if I can generate some replies
    Scottish National Standard Bearer website
    Scotland best for pumped-storage hydroelectricity energy economy
    This is a statement of the obvious as far as Scottish electrical power-generation engineers and scientists are concerned I expect but I am making this statement anyway, not for the benefit of our scientists or engineers but to inform the political debate about the potential of the Scottish economy "after the North Sea oil runs out" because political debate involves mostly non-scientists and non-engineers who need to have such things explained to them.
    The Scottish economy has a profitable living to make in future in the business of electrical energy import/export from/to English electrical power suppliers and perhaps even to countries further away one day.
    The tried and tested engineering technology we Scots can use in future to make money is pumped-storage hydroelectricity.
    In Scotland, the Cruachan Dam pumped-storage hydroelectric power station was first operational in 1966 and was built there to take advantage of Scotland's appropriate geography and available capital.
    So Scotland has the appropriate geography for pumped-storage hydroelectric power and we have the capital particularly if we invest some of the taxes on North Sea oil before it all runs out and it is all spent.
    Investment in wind-power energy generation is proceeding apace, in Scotland, in England, on and offshore, and that's very "green" and quite clever, though wind power is not as dependable as tidal power, but unless and until sufficient capacity to store energy becomes available to supply needs when the wind isn't blowing then conventional, and perhaps increasingly expensive, coal, gas or oil burning or nuclear energy power will still be needed to keep the lights on when the wind doesn't blow.
    Scottish opportunity
    Here is the opportunity for the Scottish economy in a future where wind-power generation is increasingly rampant: if we Scots build a large capacity of new pumped-storage hydroelectric power stations, not only can we supply all our own Scottish energy needs from "green" renewable energy schemes, but we could provide energy storage capacity for customers outside Scotland, particularly in England, who live in a land not so well endowed with appropriate geography for hydroelectric power.
    In future, a Scotland with investment in a massive pumped-storage hydroelectric capacity could buy cheap English wind-power while the wind is blowing then sell the same energy back to English power suppliers, at a profit, when the wind isn't blowing and the English will pay more for energy.
    So everyone wins, the energy is all green, the electricity supply is always available when it is needed and that is how the Scottish energy economy does very well after the North Sea oil runs out. 8)
    So problem solved but not job done as yet. We Scots do actually need to get busy investing and building pumped-storage hydroelectric power generation and supply capacity in Scotland now.
      You should be commended for taking interest in this form of power generation and I am sure you will make a good contribution to the discussions taking place about the dam but I am sorry to tell you how your plan is flawed.
      The catchment area for the dam is the highest peaks facing towards the dam and this is the same in both yours and the official plan. This and the annual rainfall in the area sets the limit on how much water can be obtained within 1 year. You now divide this by 12 to find how much water per month is required for continuous generation. Now you look how much water falls in each individual month and look to store as much water as will be needed to supply the plant for the driest months, where you will have a deficit of water and this is the size of dam you need. Normally the dam will be a little bit larger than this to build in a margin of safety. The size of the dam has to be matched to the catchment area and the annual volume of water.
      I don't know what the rainfall figures are for this area, but the original plan looks about right for the catchment area, using a rule of thumb view on it.
      I notice that this new proposed dam feed into another dam, effectively increasing its capacity without threatening roads and villages in the area. I also notice that there are similar sites in the area where similar things could be done and no doubt similar plans have been made.
      Thumbs up for looking for a better solution but as usual things get a little more complicated when you look in detail.
        Take a look at the following page: The Josef Hasslberger page: Technology
        See half way down in the "Calculation" section:
        The electrical energy that can be obtained from water is calculated on the basis of the velocity of flow and the mass of the water, i.e. magnitude of flow measured in cubic meters per second, according to the formula
        E kin = m/2 * v^2 (kw)
        An example, assuming a velocity of 25 m/sec and a mass of 5 cubic meters per second:
        5 / 2 = 2.5 * 25 * 25 = 1562.5 kw
        Basically in the example above: if you can get a stream which has a flow of 5 cubic meters per second. And increase the velocity to 25 m/sec (by narrowing the path the water takes and then through a funnel), you could produce over 1.5MW of power.
        With no environmental destruction required...
        Regular service Signature:
          Pumped-storage hydroelectricity
          Thank you for your reply and for bumping this topic but I am pleased to tell you that you misunderstand. The plan is not flawed and I will explain.
          It's a pumped-storage hydro dam scheme. The upper reservoir ("dam") is filled by pumping up water from a lower reservoir, lake or in this Scottish case, "loch".
          You ought to educate yourself about pumped-storage hydro dams. I suggest this link.
          Wikipedia: Pumped-storage hydroelectricity
          Pumped-storage hydroelectricity is a type of hydroelectric power generation used by some power plants for load balancing. The method stores energy in the form of water, pumped from a lower elevation reservoir to a higher elevation. Low-cost off-peak electric power is used to run the pumps. During periods of high electrical demand, the stored water is released through turbines to produce electric power. Although the losses of the pumping process makes the plant a net consumer of energy overall, the system increases revenue by selling more electricity during periods of peak demand, when electricity prices are highest. Pumped storage is the largest-capacity form of grid energy storage now available. It can be 70%[1][not in citation given][2] to 87% efficient in practice.
          The reason that additional pumped storage capacity is required is because of the increase in wind power generators means energy surpluses when the wind blows hard and deficits when the wind is calm - hence a need for much greater load balancing.
          That'll be "Loch Lochy" which will serve as the lower reservoir for the pumped storage hydro scheme.
          Yes they do. So I suggest that you look in more detail before assuming you know best.
            Energy stored in a hydroelectric dam
            The gravitational potential energy stored in a hydroelectric dam is
            Energy = mass of water x acceleration of free fall due under gravity x height of the center of mass of the water above lower reservoir or turbine outlet.
            E = m g h
            For my proposed dam, those values would be about
            m = 400 million Mega-grams = 4 x 10^11 Kgs (at most, an approximate figure)
            g = 9.81 m/s^2 (assuming the standard gravity and local gravity won't be much different from that)
            h = 569 metres (when then dam is full, by design)
            So that works out to be
            E = 2.2 x 10^15 Joules or 6.2 x 10^11 kW.hrs or 620 GigaWatt-hours
              Originally posted by Peter Dow View Post
              The energy stored in a hydroelectic dam is
              Energy = mass of water x gravitational constant x height of the center of mass of the water above lower reservoir or turbine outlet.
              E = m g h
              For my propose dam, those values would be about
              g = 9.81 m/s^2 (a physical constant)
              If you read the web page I linked to (The Josef Hasslberger page: Technology), you will understand the example. And why no dam is required, even for GigaWatt-hours of electricity.
                Ahhh your proposal makes more sense now, Its a capacitor
                Your dam would be for stored energy that was overcapacity that would not otherwise be used.
                Although the efficiency is low, I don't agree with wikipedia, it does not matter because the input power is free.
                Sorry I wasn't paying attention I jumped in based on a system I was working on for BP 20+ years ago, they wanted hydro electric power to drill for oil. I designed a 100Kw hydraulic drive system that gave constant power from a varying flow of water down a river. This was a cheaper alternative to a dam and also damming the area would prevent loggers from harvesting the trees in a vast area and the timber would have been lost. (amazon rain forest). We had to so a study to prove our system was better and so did the calculations for a dam. Our system was four huge pontoons with massive paddle wheels bigger than you get on a Mississippi paddle streamer, with a hydraulic drive to a generator on land.
                This part of Scotland is a beautiful part of the world by the way, I have been there about 12 years ago, lovely people too.
                  Thank you for your interest my friend but in this case, a dam is required.
                  Right.
                  Well the efficiency is not too bad, Wikipedia say "70% to 87%" in practice.
                  So you get back most of the energy you put in.
                  That's not bad efficiency and the low cost of the raw materials which store the energy, low cost in Scotland anyway - water, concrete and hills - means it is easy to make an operating profit once you've invested enough to build the hydro scheme.
                  No need to apologise my friend. I am pleased that you bumped my topic!
                  Good thinking.
                  Although we have hills in Scotland people like to use them to walk in and to climb and enjoy in many other ways and so there is a duty on me to try to think of ways to use the least number of hills and the way to do that is to build bigger, higher dams in a few locations rather than many smaller lower dams all over the place.
                  You are very kind. To be honest I could do with more love from the Scots. For example, I am 51 and I have not found any women to bear my children in life even though I love women a lot, not just Scots women but all kinds of women, they don't seem to love me back, not much anyway.
                  In addition, I have been excluded from the local universities in Aberdeen. I have been arrested and tortured by the Queen's police and jailed for my outspoken nature and politics.
                  This is my website all about the politics of Scotland from my revolutionary republican perspective.
                  Peter Dow's Scottish National Standard Bearer website.
                  I would rather that non-Scots ask of or about the Scots - "how dare the Scots leave their beautiful country in the hands of that Queen whose state she is head of is mistreating that good Scotsman, Peter Dow, and other good Scots, so badly?"
                  I think sometimes the harsh truth is kinder in the long run.
                  I am not so complacent about the Scots. I call on our people to rise to a higher standard still, throw off the monarchy and establish a Scottish republic.
                  Meanwhile, I had better make sure that my hydro-dam scheme doesn't flood any Scots out of their homes or they will love me even less.
                  This is how I plan to keep people's feet and homes dry.
                  Loch Lochy and vicinity water flow control works
                  Here is an annotated satellite photograph of the land south from Coire Glas showing Loch Lochy, Loch Arkaig, the isthmus between the lochs, Mucomir where Loch Lochy empties into the River Spean before it flows on as the River Lochy, the Caledonian Canal and Fort William where the river flows into a sea loch.
                  Click to see larger image
                  New waterway
                  Loch Lochy is separated from a neighbouring loch, Loch Arkaig, by a 2 km wide isthmus, which I have identified on this map as "the Achnacarry Bunarkaig isthmus", after the local place names.
                  It ought to be quite straight forward to build a canal or culvert, to connect those two lochs. The idea is that the new waterway would be wide and deep enough, enough of a cross section area under water, perhaps hundreds of square metres, so as to allow free flow from one loch to the other, so as to equalise the surface elevations of the two lochs, so as to increase the effective surface area of Loch Lochy so as to decrease the depth changes to Loch Lochy when water flows in from the Coire Glas reservoir when it discharges water when supplying power.
                  Now, Loch Arkaig has a natural surface elevation of 43 metres and this would be lowered to that of Loch Lochy. The surface area of Loch Arkaig is given by wikipedia as 16 km^2 also, (though it looks to me somewhat smaller than Loch Lochy). In addition, partially draining Loch Arkaig to bring its level down to that of Loch Lochy will also reduce its surface area.
                  If say, the additional surface area of Loch Arkaig is about 10 km^2 added to Loch Lochy's 16 km^2 this would give an effective surface area of 26 km^2 and reduce the potential depth variation to
                  Potential depth variation of Loch Lochy + Loch Arkaig = 400 000 000 m^3 / 26 000 000 m^2 = 15.3 metres.
                  Without equalising the loch levels, the depth changes to Loch Lochy that would require to be managed may be potentially more like 25 metres than 15 metres. So the new waterway is an important part of the new water flow control works that Coire Glas/Dow requires to be constructed.
                  Additional Loch Lochy water level control measures
                  When the Coire Glas reservoir is full, then the water level of Loch Lochy should be prevented, by new water works - drains, dams, flood barriers etc. - from rising due to rainfall and natural flow into the loch above a safe level which allows for the reservoir to empty into the loch without overflowing and flooding.
                  The safe "upper-reservoir-full" loch level will likely turn out to be around about 15 metres below the maximum loch level.
                  The next diagram showing the new loch drain and the reservoir pump inlets indicates how this might be achieved.
                  The drain from Loch Lochy to the sea which goes underground from the 14 m elevation level in the loch would need capacity for the usual outflow from Loch Lochy which currently goes through the Mucomir hydroelectric station.
                  I have estimated the flow through Mucomir from its maximum power of 2MegaWatts and its head of 7m as somewhere near 0.2 Mega-cubic-metres-per-hour and compared that value using a spreadsheet I have written to predict the capacity of water flow through different sizes of drains using the empirical Manning formula and this is also useful for determining the appropriate size of the new water channel between the lochs.
                  Ease my quantity
                  To construct Coire Glas/Dow/600GW.Hrs/12GW may cost of the order of around
                    Geology of the Coire Glas site
                    I have been able to extract this information from the British Geological Survey (BGS) Geology of Britain viewer, from the 1:50 000 scale map.
                    According to this map, the bedrock at the site which would be used to build the dam on top of and to extract rock from to create the tunnels for the underground complex seems to be a rock geologists call "psammite" which I understand to mean here "a metamorphic rock whose protolith was a sandstone".
                    What neither the map nor the "psammite" name is telling us is how fractured the psammite rock there is and therefore how strong and also how impermeable or otherwise to water this rock is likely to prove to be, both of which would be interesting for any engineers building a pumped-storage hydro dam scheme there to know.
                    What does look fairly obvious to me is that the superficial deposit of what the map calls "hummocky (moundy) glacial deposits - diamicton, sand and gravel" would not be strong enough, nor impermeable enough to build any dam on top of and at least along the line of the dam, this glacial deposit ought to be removed to get down to the bedrock within which to establish the foundations of the dam, although I would think that this glacial deposit might be made into aggregate to make the concrete for the dam by the sounds of it.
                      Dam foundations and height of the dam above the bedrock
                      The top of the Dow-Dam has an elevation of 780 metres by design.
                      Image also hosted here
                      The lowest elevation of the current ground surface of Coire Glas along the line of the proposed dam is 463 metres and subtracting 463 from 780 is how the initial value of 317 metres for the nominal height of the dam above the existing surface used in previous diagrams was arrived at.
                      However, the glacial deposit of as yet unknown thickness is to be removed before building the foundations of the dam within and upon the bedrock.
                      Although the lowest surface elevation along the line of the dam of the bedrock too is unknown a formula relating the Height of the Dam Above the Bedrock (HDAB) to the Glacial Deposit Depth (GDD) can be easily stated.
                      HDAB = 317 + GDD
                      Examples.
                      If the GDD turns out to be 13 metres then the dam will be 330 metres tall.
                      If the GDD turns out to be 83 metres then the dam will be 400 metres tall.
                      I propose that the height of the Dow-Dam be as tall above the bedrock as it needs to be to keep the top of the dam at an elevation of 780 metres no matter how deep the removed glacial deposit layer turns out to be.
                      My approach may well differ from the SSE's approach. The SSE have said that their dam will be "92 metres" high and they may stick to that without having any goal for the elevation of the top of their dam.
                      As the diagram indicates, I propose to secure the Dow-Dam to the bedrock by massive piles inserted and secured into shafts which would be drilled into the bedrock.
                        Spirit of Ireland, Seawater Pumped Storage Proposal, Shorter video - YouTube
                        Video which illustrates the principle of using wind turbines and pumped storage hydro dam schemes together.
                          "Dow" equation for the power and energy output of a wind farm
                          "Dow" equation for the power and energy output of a wind farm.
                          "The power and energy of a wind farm is proportional to (the square root of the wind farm area) times the rotor diameter".
                          In his book which was mentioned to me on another forum and so I had a look, David MacKay wrote that the power / energy of a wind farm was independent of rotor size which didn't seem right to me considering the trend to increasing wind turbine size.
                          Now I think the commercial wind-turbine manufacturing companies know better and very possibly someone else has derived this equation independently of me and long ago - in which case by all means step in and tell me whose equation this is.
                          Or if you've not see this wind farm power/energy equation before, then see if you can figure out my derivation!
                          • #14
                            No takers for the derivation challenge huh? OK then.
                            Derivation
                            Assume various simplifications like all turbine rotors are the same size and height, flat ground and a rotationally symmetrical wind turbine formation so that it doesn't matter what direction the wind is coming from.
                            Consider that an efficient wind farm will have taken a significant proportion of the theoretically usable power (at most the Betz Limit, 59.3%, apparently, but anyway assume a certain percent) of all the wind flowing at rotor height out by the time the wind passes the last turbine.
                            So assume the wind farm is efficient or at least that the power extracted is proportional to the energy of all the wind flowing through the wind farm at rotor height.
                            This defines a horizontal layer of wind which passes through the wind farm of depth the same as the rotor diameter. The width of this layer which flows through the wind farm is simply the width of the wind farm which is proportional to the square root of the wind farm area.
                            Wind farm turbine formations
                            Therefore the width or diameter of a rotationally symmetrical wind farm is a critically important factor and arranging the formation of wind turbines to maximise the diameter of the wind farm is important.
                            Consider two different rotationally symmetrical wind turbine formations, I have called the "Ring formation" and the "Compact formation".
                            Let n be the number of wind turbines in the wind farm
                            Let s be the spacing between the wind turbines
                            Ring formation
                            Larger image also hosted here
                            The circumference of the ring formation is simply n times s.
                            Circumference = n x s
                            The diameter of the ring formation is simply n times s divided by PI.
                            Diameter = n x s / PI
                            Compact formation
                            The area of the compact formation, for large n, is n times s squared. This is slightly too big an area for small n.
                            Area = n x s^2 (for large n)
                            The diameter of the compact formation, for large n, is 2 times s times the square root of n divided by PI. This is slightly too big a diameter for small n.
                            Diameter = 2 x s x SQRT(n/PI)
                            This is easily corrected for small n greater than 3 by adding a "compact area trim constant" (CATC) (which is a negative value so really it is a subtraction) to the s-multiplier factor.
                            The CATC is 4 divided by PI minus 2 times the square root of 4 divided by PI.
                            CATC = 4/PI - 2 x SQRT(4/PI) = - 0.9835
                            This CATC correction was selected to ensure that the compact formation diameter equation for n=4 evaluates to the same value as does the ring formation equation for n = 4, that being the largest n for which the ring and compact formations are indistinguishable.
                            The CATC works out to be minus 0.9835 which gives
                            Diameter = s x ( 2 x SQRT(n/PI) - 0.9835) (for n > 3)
                            Ratio of diameters
                            It is of interest to compare the two formations of wind farm for the same n and s.
                            The diameter of the ring formation is larger by the ratio of diameter formulas in which the spacing s drops out.
                            Ring formation diameter : Compact formation diameter
                            n/PI : 2 x SQRT (n/PI) - 0.9835
                            This ratio can be evaluated for any n > 3 and here are some ratios with the compact value of the ratio normalised to 100% so that the ring value of the ratio will give the ring formation diameter as a percentage of the equivalent compact formation diameter.
                            Here are some examples,
                            n = 4, 100 : 100
                            n = 10, 123 : 100
                            n = 18, 151 : 100
                            n = 40, 207 : 100
                            n =100, 309 : 100
                            n =180, 405 : 100
                            n =300, 514 : 100
                            n =500, 656 : 100
                            As we can see that for big wind farms, with more turbines, the ratio of diameters increases.
                            Since the Dow equation for the power and energy of a wind farm is proportional to the diameter of the wind farm then it predicts that the power and energy of the ring formation wind farms will be increased compared to the compact formation wind farms by the same ratio.
                            In other words, the Dow equation predicts, for example, that a 100 turbine wind farm in the ring formation generates 3 times more power and energy than they would in the compact formation, assuming the spacing is the same in each case.
                            Practical application when designing a wind farm
                            My recommendation would be to prefer to deploy wind turbines in a wind farm in the ring formation in preference to the compact formation all other things being equal.
                            The compact formation can be improved up to the performance of a ring formation by increasing the turbine spacing so that the circumference is as big as the ring but then if a greater turbine spacing is permitted then the ring formation may be allowed to get proportionally bigger as well keeping its advantage, assuming more area for a larger wind farm is available.
                            The ring formation may be best if there is a large obstacle which can be encircled by the ring, such as a town or lake where it would not be possible or cost effective to build turbines in the middle of it and so a compact formation with larger spacing may not be possible there.
                            Where it is not possible to install a complete ring formation then a partial ring formation shaped as an arc of a circle would do well also.
                            • #15
                              Reservoir bed drain
                              Reservoir bed drain
                              The high pressure of water which is deeper than 100 metres has the potential to induce seismic activity or earthquakes in susceptible rock in which a new reservoir has been constructed.
                              Originally posted by Wikipedia
                              Wikipedia: Induced seismicity - Causes - Reservoirs.
                              The mass of water in a reservoir alters the pressure in the rock below and through fissures in the rocks, lubricates the fault, which can trigger earthquakes.
                              Unfortunately, understanding of reservoir induced seismic activity is very limited. However, it has been noted that seismicity appears to occur on dams with heights larger than 100 meters. The extra water pressure created by vast reservoirs is the most accepted explanation for the seismic activity.
                              Coire Glas/SSE/92 m
                              Hopefully, reservoir induced seismicity was an issue considered by the SSE when selecting Coire Glas for their hydro dam project.
                              I am speculating that this issue may be why the SSE have limited their dam to a height and their reservoir to a depth of 92 metres?
                              I would note however that the pressure in the head race tunnels which supply water from the reservoir to the turbines would be proportional to their depth below the surface of the reservoir and this could be as much as 500 metres deep, so there would seem to be some potential for water to penetrate the bed rock from the high pressure water tunnels and induce seismic activity even in the SSE case.
                              This is an issue which ought to have been addressed in the many previous pumped-storage hydro scheme projects, most of which seem to have a difference in head of more than 100 metres.
                              Given that "understanding ... is very limited" according to Wikipedia, though, I do wonder if the reservoir induced seismicity issue has not always been properly addressed in all previous dam and reservoir construction schemes where the great depth of water and susceptible geology ought to make it a relevant concern?
                              Coire Glas/Dow/317+m
                              I am proposing measures to counter the reservoir induced seismicity effect in the case that the geology of Coire Glas is susceptible to it and in the general case.
                              I propose the construction of a large reservoir surface drain to cover the whole reservoir bed and the reservoir sides too to try to stop the penetration of water under high pressure into fractures in the bedrock and so thereby stop this high pressure water from widening and extending bedrock fractures.
                              To illustrate my "reservoir bed drain" concept, I have drawn a diagram comparing the usual no drain on the left, with my proposed reservoir bed drain on the right.
                              Image also hosted here.
                              So my idea is that the top layer of the bed drain is as impermeable as practical, using perhaps a layer of reinforced asphalt concrete.
                              In engineering practice I believe that impermeable reservoir bed layers have used clay or clay with asphalt or even rubberised asphalt mixed with sand.
                              My basic idea is to construct an impermeable layer and to use whatever material is best for that.
                              Then working downwards, the permeable drain layers are increasingly bigger loose particles, with sand at the 2nd top then beneath that grit, then gravel, then small stones and finally below all those a layer of large stones.
                              The higher layers support the top impermeable layer which is under high pressure from the reservoir water and the lower permeable layers provide many small channels for any (hopefully tiny amounts of) water which forces its way through the supposedly impermeable top layer to drain down the slope of the reservoir bed to the base of the dam and then out under the dam through drain-pipes built into the base of the dam.
                              The bottom layer is another impermeable layer to try to make doubly sure that the relatively low pressure water that gets into the drain will find its way out through the dam drain pipes by following the course of the drain.
                              These kinds of layers of different sized loose particles have previously been used to make simple narrow drains and impermeable layers have been added to reservoir beds before now but whether professional dam engineers have ever covered the entire reservoir bed and sides with one large drain I don't know. If not, this could be named the "Dow drain" solution to reservoir induced seismicity!
                              Why not add a simple impermeable layer to the reservoir bed?
                              I think the additional complexity and expense of a bed drain (and drains for the sides too) is better than simply adding an impermeable layer.
                              Consider the fault condition of the two possible solutions.
                              If a simple impermeable layer fails, if it cracks or ruptures or disintegrates under the pressure changes, how would anyone know? It may look fine but be leaking high pressure water into the bedrock and inducing seismicity which OK the engineers would notice any earthquakes but so would everyone else, the earthquakes could cause damage or loss of life and it could lead to a loss of confidence in the project and in the engineers who built it. They could go to jail!
                              If the top impermeable layer of the bed drain fails then there would be some water pouring out of the drainpipes through the base of the dam when at most it should only be a tiny trickle of water. So the engineers would know there was a problem with the bed drain and they'd know to drain the reservoir and fix or replace the top supposedly "impermeable" layer, fix the bed drain so that it operated as it should.
                              So failure with the bed drain is noticed right away and it is not a catastrophic failure. Whereas failure with the simple impermeable layer may not be noticed until a catastrophic earthquake happens.
                              So this is why I think the bed drain is worth the extra complexity and expense. It is a more fault tolerant engineering solution.
