I made a radiant energy antenna for my 1st Free Energy project, and with LOTS of help and knowledge sharing from the Free energy community on Facebook i was able to construct it. Here are some pics. As of now i have 3 antennas and 2 grounds and have 2.81 volts in my cap. Somethings better than nothing
heres some pics of it
^^^these are the pieces of copper that gets buried in the ground they syupply the (-) of electricity
^^^ here is the 4 diodes arranged to create a full wave bridge rectifier. The diodes are 1N4005 diodes from radioshack, and the blue capacitor (radioshack) is 35Volt 3300uF, i used copprer as a contrasting background for the picture
here are the tetrahedrons on the lower roof, with a clear plastic tube keeping them oriented to eachother, and to help them not blow away.
^^^ the view 25 or so feet down to the ground where the wire travels
^^^ view of the wire leading up
^^^ view of the circuit
^^^ here is the rectifier/cap circuit housed in a protective hummus container. it connects the antennas (+) and the buried copper (-)
^^^ wire leading into the earth where the copper is buried
^^^liquid nails to plug the hole, to keep rain out
^^^view of the circuit , lid off
^^^ testing the cap 2.25volts (now at 2.81volts) with 3 antennas
^^^3rd antenna in production
Here is a seperate project, but also teaches you how to make the tetrahedrons, just stop at the audio chords, and solder them into the long chord leading down to the circuit Scalar Natural Earth Emitter DIY video 7.83Hz - YouTube
~+_~+_~+~_+~_~+_~+_~+~_~+_~+_~+~_+~_~+_~+~_
, and capacitors. Depend of the kind were charging to full in some time, then i was shorting them and they were charging again. I will go back to this when i have some more time.
the dimension of the tetrahedrons are 16 inches on each side. I need to hook up this pyramid, which is made from aluminum sheet meta,. alot thicker than aluminum foil. ANd that may have better charging properties. I want to do fractal shapes, but my mere monkey hands cannot do such precise bending.
