Any Brushed DC permanent magnet motor will work, HOWEVER, as some folks have seen, you can burn out a 12 volt DC motor if you are not careful, because some of the time you are running it off 24 volts or higher. I have been using a 110 volt DC motor and it has taken everything I have thrown at it, so I would recommend a higher voltage DC motor if you can find one. The higher the better.
Just to see if we're telling the truth and see it work? ANY PM DC motor. To build something that will eventually produce some power for you? The bigger (higher voltage) the better.
that the Tesla switch is extremely difficult to set up and balance which means of course that your three battery motor arrangement is likely to prove a bit tetchy to tune (or get in the zone as you call it) Reading the above link you will see that
addendum
for sharing all this.
