Originally posted by tachyoncatcher
3 Battery Generating System
This topic is closed.
Hi tachyoncatcher, May I ask you to clarify your definition of "OU" ? What doOriginally posted by tachyoncatcher View PostMonsieurM,
Understanding that magnetism can be influenced by other things beside induction will help to understand and make sense of the successful devices over the years. If you believe that any of the historical devices of the past achieved OU ( I do ) then you are close to understanding a common thread to all of them, including the 3BGS. Look at those devices, consider the interplay between EMF, collapsing fields of coils, electrostatic storage/conversion, multiple potentials over the same wire, vibrations ( I use the term vibration over frequency as I believe it to be more correct as there are multiple harmonics), and, magnetic vibrations. Look at the devices by TK, DS, Tesla, Hubbard, Hendershot, even the 3BGS and you will see certain common factors in all of them, one of them being the importance of magnetism and a neutral zone or bloch wall or Zero Point. The theories of dipole magnetism are losing ground as we gain better understanding. So don't get hung up on that. You are closer yet.
Good Luck,
Randy
you mean by it. Is a radiant energy collector based on the Tesla "Plate"
Design OU ? Of course it must be surely. If not, why not and what does
qualify for OU in your opinion.
OU
Mr Farmhand,
I won't get caught up in the definition of OU and it's meanings. It's an urban term with scientific back pinning that has multiple meanings. I respect what you have done, your builds, demonstration and have read some of your contributions as to radiant collection and learned. I believe in the collection/translation of an ambient energy that has multiple names, radiant being one. Do I believe we are creating energy? No more than a diesel powered generator creates electricity. You honor me with your question.
Respectfully,
Randy
just wanted to bring the following to your attention :
Page 120.
Lead monoxide was mixed with paraffin or beeswax to obtain a massive dielectric for use in the capacitors
Thomas Townsend Brown: Scientific Notebooks, Vol 2
Page 27
89. A Tribo-Electric High Voltage Generator.
Catalina Island, CA; March 26, 1973.
If it is true that tribo-electric generation results from contact potential differences in dielectrics of differing dielectric constant and if it is true that the sliding motion or friction merely extends the effective surface of the dielectrics in contact and if it is true that the dielectric with greater K is always positive and the potential difference is related to the difference in dielectric constant, then it follows that a new type of generator is feasible.
Hi Matt,
It seems that these AGM batteries are real stubborns ,after mor than 10 times of full charge and full discharge they became even mor butter they can hold a charge of 13.25v now so I cannot do any thing else to kill them they are too strong to be killed so my only chance is to find a good bad battery and I don't think that I have a good chance but I will try .
I hope that we can find a way to kill these batteries .
Good luck
Ehsan
Take the wisdom even from the mouths of the insane
Ehsan,
Are you discharging the batteries and then leaving them shorted out for a week or more? It sounds like you are only discharging them and then recharging them right away. According to Matt you have to leave them discharged and keep them shorted out for a week or more.
Respectfully, CarrollJust because someone disagrees with you does NOT make them your enemy. We can disagree without attacking someone.
Discharge them, short them out, put them near heat source, then in fridge. Then charge them and start over.
But this is the reason I am so opposed to the idea that sulfates have anything to do with what we are seeing. It is very unlikely they have anything to do with the effect, unless the near nothing for acid and sulfate building blocks is the reason they act this way.
Matt
CarrollOriginally posted by citfta View PostEhsan,
First time I did discharge them and then shorted them for three week only once and then pulse them as Dave recommended .but then yes I discharge them totally and then charge them with out shorted them before charge .
Thank you for your note.
Respectfully
Ehsan
Thank you MattOriginally posted by Matthew Jones View PostDischarge them, short them out, put them near heat source, then in fridge. Then charge them and start over.
Matt
I will do that all over again although it will be a long process.but what will I look for when I put it them near heat source and then in fridge what should be the voltage is there any notices ?what should I notice mean while ?
Ehsan
Hi
I installed the 5BGS with a chain drive 3:1 between motor and generator.
The motor runs with 9V, the generator shows 26V unloaded.
Then I connected one of the primaries 12V to the generator with a 1000 Ohm Resistor, the voltage measured over the Resistor is 8V.
U = R x I
8V = 1000 Ohm x 8mA
P = U x I
64mW = 8V x 8 mA
I think the generator was feeding back 64mW to the primary.
Next I will try to get a 2.7 Ohm Resistor (rated 50W)
This will probably result in some lower voltage like
U = R x I
5.4V = 2.7Ohm x 2A
P = U x I
10.8W = 5.4V x 2A
Would be nice to see one of the primaries as well as the buffer going up.
All right, will order some expensive resistors.
cubalibreLast edited by cubalibre; 12-16-2013, 09:27 PM.
No. You are dissipating 64mW in the resistor.Originally posted by cubalibre View PostHi
... I connected one of the primaries 12V to the generator with a 1000 Ohm Resistor, the voltage measured over the Resistor is 8V.
U = R x I
8V = 1000 Ohm x 8mA
P = U x I
64mW = 8V x 8 mA
Don't waste your money... all you are doing here is generating heat (10.8W of it) in the resistor.Originally posted by cubalibre View PostNext I will try to get a 2.7 Ohm Resistor (rated 50W)
U = R x I
5.4V = 2.7Ohm x 2A
P = U x I
10.8W = 5.4V x 2A
cubalibre
OK, if you want to be pedantic, you're also pushing 2 amps (8mA in the previous example) into the battery - but this will be less than what you took out in the first place to drive the motor-generator set.
JFP
How do you know? Have you built one?Originally posted by JFP View PostOK, if you want to be pedantic, you're also pushing 2 amps (8mA in the previous example) into the battery - but this will be less than what you took out in the first place to drive the motor-generator set.
JFP
Matt
