To All
LEARNING and UNDERSTANDING are not the same thing. Many here are building circuits because thay LEARNED how to do it. Untill you build it and play with it for a while, without changing it, you will not truely UNDERSTAND how it works. It is thru finding out why it does not work and going over everything again and again, as well as checking every item in the circuit off on another diagram as you go, that you begin the UNDERSTANDING. Then when you UNDERSTAND how it works, build another one and change that one, not the first one. Go slow, take notes and do every test you can at each level. It is thru UNDERSTANDING your circuit and going over your notes that you will be able to modify and improve what you have. When you put everything you have into one build and change it, when it goes up in smoke you will be at the begining and starting over again. That is stress----- as you now have nothing and no notes to get back on track. Keep up the good work guys.
Dana
Dana
I have said what I wanted to and will not respond to you about this again. Just relax...
I have a digital watt meter that tells consumption very accurately, but lead acid batteries are expensive (and I won't use lipos like you do even though I have lots of them I couldn't explain burning down our property to my wife) so maybe in a couple of months I might be able to buy 3 lead acid batteries. I try to use what I have if I can... you know poor people have poor ways. I could build a cement block bunker for them of course that would take up a lot of room on my bench. I'll look into making a smaller one out of fire bricks.
