  • Reply
    Hi all,
    thanx for clarification of green lamp phenomena... I will engage my Samsung Galaxy to see what it can see
    Regarding coil:
    I have 'regular' enameled wire coil as Ufo suggested, 200+ turns, 20AWG. I do experiments with this coil. But 'resonant' frequency when energy burst comes, is very low, 1kHz and is duty cycle dependent.
    Then I was thinking during long nite, and Tesla said, radiant impulse appears in wire in instant moment once switch is closed. Then Ufo announced, that best result he got was parallel bifilar coil. Make sense, two wires, lowed resistance, double radiant generated. And I got idea to employ more than 2 wires at the same time. Recently I have one coil for my solar energy conversion project, to boost poor solar voltage to 400VDC for true sine wave inverter, 500W calculated load. Coil has been designed to do not generate much heat during operation. For this type of coil/transformers I am always using different litz wire (please google it, if you don't know). I just use this coil for test, without ferrite E core of course. Litz wire used is 105 x 40AWG -> total 20AWG -> 1.2mm dia. Coil used is ETD39. So there is 24 turns in 5 layers. Resistance is about 0.5 ohm. 'Resonating' on about 15kHz, which is good for electrolyte caps.
    I don't have current measurement, as my meter is showing crap. Needs to buy new one,
    @Ufo
    I said, light is fully lit with 230VDC on it. Meaning, capacitor bank is holding 230VDC going to the bulb. Driving voltage is 35V.
    Of course we can built coil operating on 230V, it must have XL high enough to allow transistor to handle his peak pulse current. But problem will be with pulse amplitude during instant off. It will climb far over Uce or Uds and poor guy will break down. With 200turns and 35V is peak amplitude around 550V, my MOSFET is 600V. I switched to IGBT, because max voltage you can get is 1200V Uce. Much better, no over voltage protection required.
    @all
    I don't have bigger litz wire available here. Only 20AWG, I bought it on eBay in USA and it takes 2 weeks to arrive here. You are guys in US, you can get thicker litz wire within 2 days. Can you do some tests ??? It would be nice to compare result litz wire / enameled wire. Link is here :
    Litz wire 105/40 for Coil and Loop antenna 100' | eBay
    this guy got a lot different sizes....
    BR
    Cinan
      Sir,
      Yes, You are completely right...NO, I do not agree with anything you have written here, and as a matter of fact, I do find your final words as an insult to myself...
      Let me ask you a very plain and simple question...
      Do You Know who I AM?!
      Do You Know my expertise in the fields??!!
      Then, why, do you dare to come here, to my FORUM, to write all this diminishing words to my Work?!
      What is the point?
      To gain audience?...For people to believe "You DO know" what You are writing about?
      Or is it any other "Negative Feelings" against my work that I will reserve to bring out, but that you know exactly what am referring to?
      I will respond to your writings in the same attitude you have done it.
      Show the Video(s) ...then I will believe you, otherwise,it will be considered a False Statement-Claim.
      After all, it is a Policy from this Site to do that...Show "Proof"...or be considered Fake.
      I am Not GLORIFYING, ABSOLUTELY NOTHING.
      The Purple Plasma Ball I know perfectly WELL, is nothing new, as a matter of Fact Eric Dollard have produce it years ago...and YES, it is attributed to Radiant Energy...And it could manifested in many ways...even in a circuit without power supply...(like you have written here) not only through my set-up, Sir.
      I not only have operated Pulsed Motors,...BUT have designed them and fabricate them from scratch...zero, nada.
      And not talking of crappy models made out in pieces of Plexiglass or Lexan...BUT THE REAL ONES that can stand the Heat, METAL, ALUMINUM, STEEL...welded framed and ready to run..Sir.
      I do not need to install Neons on my MOSFET's...Yes, I heard they have seen that light right before transistor blow...of course, it is a feedback from Radiant into your circuit.
      When You are playing with HEAVY DUTY EQUIPMENT, you do not use Neons...they can not save absolutely no MOSFET's, nothing like a well placed and balanced Rectifier.
      Forgive me Sir...But I do MASTER THE FUNDAMENTALS, That is exactly the reason why, I DO, CAN AFFORD TO MOVE INTO THE UNKNOWN...and very secure of my steps.
      ARE YOU?
      This is the only part of your entire post where We both come to an understanding!
      That You Know off...Have I ever been disrespectful, Sir?...Or Do you think You are giving me any reasons to be?
      Ohhh!!...That would be terrible wouldn't it?!!...
      But the thing is..like I wrote before in another post (And I am completely sure you have not read me prior, but my latest post here)...I made my Models first, test them and run them, then I come up with conclusions and make my claims, Sir.
      It is a very "Non Scientific Approach" to build a MOTOR in plastic and expect to perform like a real model should be made off...Heavy Metals, or at least Carbon Fibers...or worst, to write in a scrappy piece of paper a whole bunch of symbols and numbers...and then say "it will work just fine like this"...I know many that have done that and their illusions dropped below zero. That was terrible for them!!
      Sorry, but your type of approach, I don't like, at all...even if you consider yourself a "knowledgeable individual", I do not need that kind of "Help"...So, thanks for your time here, Sir.
      And Goodbye
      Ufo, why you are wasting time with that... Makes no difference, they will always pull the legs... Just leave it... Use this time and do third video instead
      Cinan
      • I expected this kind of response, and alluded to it in my closing statement regarding your needing to be respectful when responding....you weren't.....sad really...
        Sir,
        That is exactly why I made the statement. I knew you wouldn't agree with anything I had written. The fact that you find any of it insulting demonstrates that you think you have it all figured out, and external opinions and questions which challenge your authority (in your mind) is unwelcome.
        Shoot.
        That was two questions......
        Your first question it's the exact same question that the learned asks an unlearned when he/she feels that his/her authority is being challenged. If I knew you, do you really think it would change my opinion? I would still challenge your authority!
        Your second question is as in a word....terrible...it makes you look bad. I know this much....with reference to your expertise, you praised another individual for providing you with a circuit that you have yet to test (that is an insult, how much effort went into developing that circuit....sad)! I compared the two...your circuit sucks compared to his, that maybe be because electronics isn't your area of expertise...but that's just a guess on my part...
        So...it's been established that you may not be an expert in electronics....you say "fields" I haven't seen you do anything that isn't related to electronics so...where is this expertise you speak of, and please elaborate on these fields.
        Your forum huh...LOL....This is your thread.....your corner on the forum where you can pretend like you know more than those who pay you a visit in your corner of this forum....LOL.....your forum...you are a funny guy.
        What is the point?
        Preaching to the choir.....This is your corner of the Forum...your audience..LOL...your believers...(followers). I just made a statement that you didn't agree with......it's you not me who has pages of babble....
        I'm not going to be that whipped dog man....bring it...I stated my opinion, one which wasn't welcome. You feel insulted, look in the mirror take it up with that guy staring back at you.
        You really think I care about whether you believe me or not? You need believers! You have a few as far as I can tell. I am a fake..you are a fake...we are all fakes...LOL..you think your videos prove anything? There are thousands of individuals making videos and like yours...they prove nothing....
        Sure you are glorifying this....it's all radiant this radiant that....blah blah...you got to do it like this..blah..Take some of the advice you keep pouring out, go reread your posts!
        Thanks for acknowledging that I know what I'm talking about though, I'm not as smart as you nor do I have your congregation, but I am trying....LOL
        Not really difficult to do...John Bedini's pulse motor was put together by a school girl...LOL...she put it together from scratch too...oh wait...you made your own copper wire...molded and made your own magnets....the aluminum you got from bauxit ore, then cast...same goes for the steel I guess...yeah....that changes things....
        When you can't beat em,...I wonder....had I not posted that image of my first real pulse motor, what would you have said here? LOL....The image I uploaded is a testament to my attention to detail. I think it's a pretty sweet pulse motor...and you are rattled cause my motor looks better than yours...Plexi-glass makes for exellent demonstration, and proof of concept models....its ignorant to think that you can go straight to the finish line...but you are the expert.....
        NO.....I didn't say you need to install neons on your mosfets...you read what you wanted to read.
        For the record....All of my circuits are supplied with between 120v-230v.....LOL....soon to increase dramatically....Grow a pair buddy!
        I seriously doubt that, but the creator is your judge....Sir...
        ARE YOU?
        Till the fundamentals are comprehended, I will stay right here on earth, where its safe.
        You have no idea what I mean when I say fundamentals, and that is funny.
        uh.....if you say so....
        You seriously asking me this? I can provide you with a few quotes where you made an ass out of yourself in the manner in which you responded to a few folks here...but I won't point them out, I will just recommend again that you take some of your own advice, and reread your posts...reread your entire thread! Clean your corner of the forum....LOL......go back and see how you have been treating your congregation.
        You have no idea what you are talking about, this is a test model!! You build tiny toys, test them and build tiny toys.... I build large motor/generator test rigs! It's going to be funny watching you eat all this crap you are preaching to those poor unsuspecting individuals, cause you think you know, and the truth is, you aren't even close.
        You like that big plastic motor....you don't you...LOL....you like it so much that you make reference to it twice.....she likes you too...LOL.....I'll make you one if you ask nicely.
        See you read that one wrong too...you assumed that when "knowledgeable individual" was used, that it was a reference to myself....no buddy, my EGO isn't as inflated as yours...I absolutely loved that post you made in the Ismael Aviso thread where you reveal to all how big your ego really is when you made the highlighed statement.
        Hello All,
        I have left a few comments at Ismael Aviso's YT Channel before I started here on EF...warning him of Investor dealings and Patents and Intellectual protections...However, He has not answered any so far...
        I believe He's got something there, although some of his explanations does not make sense to some of Us who are "knowledgeable of the Arts"...
        But one thing I wanted to post here is related to Investors Policies (must of)
        When you get long sums of Money from Investor(s), they do it through Legal Channels, of course, however, besides the contract type of Legal Clauses there is particularly one that is common in must agreements signed by both parties (Inventor-Investor).
        One- The Investment Fund$ must be Insured.
        Two- The most common type of Investment Funds Insurance is like a Life Insurance Policy, where the Inventor(s) Life(s) is/are the "protected" one against any "loss" that may occur...The beneficiary parties are -of course- The Investors...and after reading in detail the "fine print"...Inventor is worth more Dead...than Alive...That is the way the policies are written to protect money...
        There is a name for this type of Insurance...I just can not remember it now...but is something like "Main Man Policy" or something like...
        Regards to all
        EGO Alarm bells going crazy...you claim to be one of the few, a member of the club of those skilled in the art....LOL.
        I was responding to you when I used the words "knowledgable individual" please don't misunderstand, I would never consider you as being a "knowledagable individual", as you claim to be....I was talking about a real knowledgable individual. You wouldn't know a knowledgable individual if one came up to you and kissed you on the on the mouth, and thats what was ment by my statement.
        That is the perfect spot to end this on....
        I know who you are now Sir, and what are about!
        If it suits you, you can reply to this, but rest assured I will not respond to it, I have said what I want to say, and was civil...LOL
        • Erfinder - what do you want
          @erfinder
          what the hell is wrong with you ! If you don't have nothing constructive and useful to say, just leave and let this corner as is and go shout your bull**** somewhere else ! If you have problem with the thinks here, don't read it !
          I am really tired to find topic related answers hidden between stupid ping-pong posts talking crap. If you have some mental unsolved issues, don't try to fix it here. Nobody is interesting..
          Cinan
          P.S. don't reply this. I didn't put any question mark, and I don't want to know another piece of your internal mood.
          • @ufo,
            don't be stubborn, do not reply him, do video instead
            • Stick to the experiments
              Originally posted by cinan View Post
              @ufo,
              Hey Buddy,
              I agree 100% that so many people are trying to discredit something that is clear to me obtains Radiant energy.
              The topic here is to extract more Radiant energy and have a greater understanding of it's relationship to pulse/oscillation circuits.
              I have made a few rotored SSG's, SS SSG circuits and finishing my Kromrey Converter to understand this energy more clearly. Ufopolitics circuit has shown the correct properties in his clips to spark my interest in replicating his results and don't care to read this crap.
              Looking forward to the third video myself
              Zero
              • Originally posted by cinan View Post
                @erfinder
                Cinan
                LOL....thats right....come to the aid of your guru.
                • Thanks Cinan
                  @ufo,
                  Cinan,
                  Thanks for your advice my friend, you are completely and absolutely right.
                  I will make video instead...
                  • Thanks ZeropointEnergy
                    Originally posted by ZeropointEnergy View Post
                    Hey Buddy,
                    Zero
                    Thanks ZPE
                    • Originally posted by erfinder View Post
                      @erfinder, this is a thread started by ufopolitics, if you want to discuss something you think it is interesting to the community, could you please go and start another thread, and stop populating this space with your off-topic ramblings.
                      We do not want to know your opinion about ufopolitics discovery here, so please, GET LOST.
                      • @arron5120
                        See thats the problem with you brown nosers...you can't see past what your guru wants you to see, in the information he is providing you with, and his opinions of those who question his information. The thread is interesting, its why I am here. If and when I want to start a thread about something I will, I don't need your permission or invitation to do so. That which you deem to be off topic is right on topic in my opinion, but thats the problem isn't it....opinions aren't welcome! That includes your own! Your praise is desired, your thoughts aren't. It is you and your guru who are rambling, I made a statement which was related to the subject matter, this was interpreted as a personal attack....
                        We...so you speak for your guru now...LOL...You all should really start thinking, and questioning your leader, his motives, and the more importantly the information that hes giving you.
                        As far as discovery, please! What discovery.....whats been discovered here....it would be more accurate and gentleman like to say its a rediscovery, and that doesn't apply either! Your leader is "teaching" you that the energy you are playing with is Radiant Energy......its NOT!! If you did your own research instead of waiting for this guy to pave the way for you, you would know that this isn't Radiant Energy!!! Nothing has been discovered! Everyone knows about inductive kickback, and thats what this is! If and when you finally do experience Radiant Energy, your life will change, your circuits will evolve, and you will never look at any of this stuff we do the same way again!!! You aren't anywhere near that.....yet.
                        Saying please before closing with get lost doesn't make it any less offensive.
                        I pointed out what I had observed on my bench, thats what researchers do....your guru took offense, his problem, not mine, if I see something that doesn't make sense I will question it......period. The authorities are dead.....and those who took their place are silent!
                        They have a name for people who don't ask questions and think for themselves........sheep.....
                        In the 1800s Radiant Energy was defined by authorities, those who had mastered the arts. They identified that it is associated with a "specific" phenomena when caused to manifest in inductors. Contrary to popular belief I have read the material being discussed here, and not once was the mystery phenomena mentioned.
                        Think for yourselves, you are chasing inductive kickback, you are no where near Radiant Energy.
                        I have said what I wanted to say, if you don't want me to post again, then don't call me out again!
                          @arron5120
                          <Stuff deleted>
                          <Stuff deleted>
                          Hi Erfinder,
                          Do you have a link or PDF about this info?
                          Bert
                          • Edison etheric force ?
                            • Originally posted by bbem View Post
                              Hi Erfinder,
                              Bert
                              Sure I got a list of names, but thats not what you want....If you want to know what Radiant Energy is check out
                              "Secrets Of Cold War Technology"
                              Chapter 1.
                              Radiant Energy for the layman! When you digest that you will have a better and more realistic image of what Radiant Energy really is and be connected back to the guy who more or less "discovered" the force, how he discovered it, and developed a practical application for it after studying it.
                              Make no mistake, Tesla didn't originate the concept, (Radiant Energy), but he was one of the first (that we can know about) to "master" and tame the force.
                              • Radiant Energy...1
                                One of the simplest, but precisely defined concepts of Radiant Energy is on Wikipedia:
                                Radiant energy is the energy of electromagnetic waves.
                                Before Nikola Tesla times, Maxwell derived and developed two main paths to analyze-calculate Electromagnetism:
                                1-Symmetrical Systems
                                2-Asymmetrical Systems
                                Symmetrical Systems were the ones "legalized and Adopted" by Classic Physics to our date, the ONLY ones we know so far to develop, calculate, design and build must Electrodynamics-Electromagnetic Systems up to now.
                                Asymmetrical Systems were "Disregarded" by Nobel Prize Scientist Lorentz , financed into this "Enterprise" by John P. Morgan and Thomas Alva Edison.
                                Heaviside and Johnstone Equations backing Up Maxwell Asymmetrical Systems were also disregarded by Lorentz and Einstein.
                                The Energy Conservation Laws Applies ONLY to Symmetrical Systems. NOT to Asymmetrical Systems.
                                The Laws of Thermodynamics also Applies to CLOSED SYMMETRICAL SYSTEMS.
                                Asymmetrical Systems are based on ELECTROMAGNETIC FEEDBACK, or ELECTROMAGNETIC RESONANCE.
                                Symmetrical Systems are designed to maintain a Symmetrical Balance between their interactions as to cancel between them, they are CLOSED SYSTEMS. Their Equations "Balances" perfectly, not living space for any "Incoming Force" to develop. They ALL BALANCE OUT by Including a LOSS, whether in Heat or in Parasitical, "Inductive Spikes"...
                                When applying Symmetry to an Electrodynamic Machine, we have series of shorted interactions, based on closed coils, interconnected between them, either in series or parallel, or combinations thereof.
                                Nikola Tesla Electrodynamic Machines are MUST based on OPEN COILS PAIRS, OR GROUPS OF PAIRS In their ROTORS, BUT, OPEN, INDEPENDENTLY CONNECTED ONE FROM THE OTHER.
                                Open, whether interrupted by commutation elements or by Spark Gaps.
                                This Motors were utilized by Tesla in his Radiant Energy Apparatus...
                                Asymmetrical Systems includes Capacitors, Transformers, Inductors and Open Coils Motors and Generators, they all violate Lenz Laws and Energy Conservation Laws...just because they are NOT Part, Nor Included in those Laws.
                                The Tesla Coil, The Don Smith Transformers are examples of ASYMMETRICAL TRANSFORMERS.
                                If a Motor, every 90 or 180 degrees reverses polarity between its Rotor Coils, cancels its electromagnetic feedback and resonance built up at input timing, creates a heavy electronic and flux collision against the incoming flow, releasing heat and feed-backing High Voltage Spikes, Transient currents and reversed fluxing developing opposite magnetic fields, all known as C or B EMF...
                                I had developed Motors that do not reverse polarity in order to achieve rotation, they are based on Open Independent or Groups of Coils, Open Systems like Tesla designed back in 1888.
                                The Coils receives its input, polarizes magnetically and reacts into an attraction-repulsion with the Stators, and then...GO FREE...not colliding against a reversed voltage from another pair of brushes, but delivering to an Output Port its charged current, then traveling "EMPTY" to next Input stage.
                                Any OPEN, INTERRUPTED COIL after excitation will deliver a free Electromagnetic Feedback, a Magnetic Resonance that will Induce a reversed current of greater magnitude as the Input, and it is understood that if it is NOT DISTURBED by an Incoming reversed voltage/amperage it then CAN THRIVE OUT PEACEFULLY...
                                That is the Effect that I have on this Open Coil, interrupted by square waves falling to Zero, at Time Off it then travel Free via Diodes towards an Output, sending its reversed generated Voltage/Amperage by Magnetic Feed back to a destination Load.
                                There is "No Secret" on this...I have written it must on my description on my first post.
                                According to my tests, this reversed current, obtained by Electromagnetic Feedback reacts-behaves very different than our typical known electricity, and I have proven it through my videos. Even though I have not released all of them because of lack of time...I have to make money to make a living...
                                Regards to All
