The Pratt & Whitney Power Systems PureCycle power system is a closed-cycle process that uses any hot water resource to generate 280 kW (gross) of electrical power. The system is driven by a simple evaporation process and is entirely enclosed, which means it produces no emissions.
Don't get me wrong, but the only problem I see with a system like this is the cost.
The use of freon to absorb ambient heat - compared to the freon temp is the bit I really like.
Regular service Signature:
Without a doubt, cost would be a consideration in the manufacture and design of such a system. However, consider that the maintenance cost would be extremely negligible, and the fuel cost would be essentially nonexistent.
Air source heat pumps take heat from the outside air, extract it and use it to heat buildings. They can take heat out of the air even at 15 degrees below 0C. Air Source heat pumps are an extremely efficient way of providing heat - for every unit of energy they use, they produce 3-4 units of heat.
The TES simply extracts thermal energy from one location and transfers it to another location. In the process, the TES takes some of that thermal energy that it extracts and converts it into a form of energy that the TES can use in order to continue the process of extracting thermal energy from one location and transferring it to another location.
Reason: Addition
Hi, I've been looking into this matter and a simplest and most beautiful way is taken by Matteran Energy.Pure organic rankine cycle with no moving parts.Please look their web site Matteran Energy produces electricity from low temperature, renewable thermal sources.
I am an engineer and as part of my job is maintenace of refrigeration and air cond systems.I have in my mind some ideas to make this system even more efficient, simple and automated by low cost components.
In the video Dennis Lee Heat Pump.flv - YouTube, DL stated using a refrigerant that boils at forty below zero. His video looks pretty old, so he could have been using R12.
Earlier someone commented on the cost of these symbiotic systems. I can see the build cost and also the R&D costs. This appears significant to home scale but perhaps not on larger scale and with volume sales.
We must consider the opportunity cost of solar PV as capping the threshold for budget constraints, especially when considering the smaller home scale and a single build effort.
I am wondering about the costs of a home scale symbiotic system (heat pump/ rankine style), both build cost, and R&D costs?
I'm not just pointing at problems, for naysayer's sake. I believe in proposing solutions along with pointing out problems. In fact, I believe not only in harnessing thermal potential (heat pump COP's much greater than 1), but also in the rankine style turbine generator symbiotically to help deliver more out than in.
The intermediate tank batch process to re-seed liquid refrigerant to the evaporator tank is brilliant and represents my 'missing link'.
I have spent many hours in deep study of heat pump dynamics. I sit upon improved efficiency discovery. I can not take much credit: I looked, I asked, wisdom flowed, I received.
There is very little difference between this 'environmental exchange' system and a sealed 'self-exchange' system. I have no doubts that both work.
The problem for me is financial. A solution would be investment (which has its own issues), but requires some volume of sales, which draws attention.
So my quest is one of gaining info on projected costs. Perhaps our forum members could help us find or generate this info here for discussion.
Thanks Vidbid,
For posting the link to this most interesting interview. I also would like to thank Aaron & Peter for putting this together.
I did however have an error occurred @ 57:02/1:01:00 and wonder if I missed anything in their closing statements?
Regards, Gene
PS I find your tes quite interesting. I wonder if you or someone here with more knowledge in these systems might consider building a small scale model, this could dramatically reduce the costs. If you think this is doable, I may be able to help with a small donation.
