  • Coil winding
    Okay I made a similar machine today like this one. Well I had it and added the right size spool today is what I should say.
    So from what I understand one secondary is wound CCW and the other secondary is wound CC I think. Does any one know if this is right?
    I was thinking both wound in either direction the same and just reverse the wire.
    I don't know what I was thinking. I guess i better read up.
    I see the 120 turns information. I think it matters a great deal.
    • CCW AND CW windings
      Here is a picture of the Auroratek diagram showing opposite windings but no designation of CCW and CW it is just follow the picture.
      Free Energy Blog:2014:07:16 - PESWiki
      Maybe I'll go read up.
        The picture shows them in series and the dot notation tells you the rest.
        It's pretty easy, you can only wrap it two ways and hook it up two ways. Just tie them together in-phase, parallel or series. If you get zero volts, you have them backwards.
        • CCW and CW
          Right but I looked through all of Thanes stuff and I can't find CCW and CW anywhere. Then which way will the primary be wound?
          I can hook wires up both ways but if the winds are CW and CCW and I wind them both the same? see what I mean?
          Everyone thinks just reverse the wires, NO!! You can't if the coil is wound backwards.
          See what I mean? Bob sent me a link about Thanes connections but it didn't work.
          But one thing we have is the Auroratek diagram.
          I have just finished my cores. 3 are bound together as one using high frequency ferrite material. This makes the secondary core 50 percent larger than the 2 primary links combined.
          Very important to proportion the flux paths.
          As shown in the Auroratek pictures the large core is a combination of 2 taped together side by side touching tightly. This is the proper way. Tape is used to keep the secondary core material together as one core.
          So i am using a total of 5 high frequency ferrite cores to get the right amounts of flux path. I wound one coil and couldn't get it off the spool and the Dia. was off, just a test with a few wraps gorilla glued.
          King Kong could get that stuff loose. I am searching for a smaller spool insert out back and tough paper to wind on to make it easy to slip off the winding spool.
          I think I heard Thane say in a video that his winding were all the same direction but Bills has one counter wound.
          That is why I am stuck. gonna figure it out for sure ahead of time.
          Let see CCW and CW Which way should I go? Well I'll wind up 4 coils and try them all. No biggy if there is nothing for sure anywhere.
          Mike
          • Almost there. My mini BiTT/AuroraTek Xformer
            I used an insulated copper tape and got around 25 turns on the primary and 15+15 turns on secondaries. Ferrite cores (3C90 material).
            • Originally posted by kEhYo77 View Post
              That looks really nice!
              If you can find a high frequency and get some amperage in there, you may very well be powering your home from that device in the near future. I have my fingers crossed.
              Please do keep us posted on your progress.
                I guess I don't follow Mike. So the coils could really be wound backwards? I wonder if I did that with my setup...
                Please try to elaborate on this point--my simple mind says we are using AC power and the signal/flux is either in-phase or opposite. If that's not true, we need to get to the bottom of this. As an example, if you have a one-turn primary, there is no difference between CW and CCW. This should hold true regardless of the number of turns.
                Right now my setup outputs some voltage, but absolutely no current--doesn't even spark.
                • Sweet Setup
                  Hey thats a sweet transformer you got there. Went ahead an spent the money hey? Plus your bench is awesome dude.
                  Well I hear people talking that these systems work on cancellation of self inductance like wire wound power resistors are built.
                  So the idea is that one secondary is wound CW on a ceramic tube then stop half way and wind backwards or CCW so as NOT to make the power resistor an inductor magnetically as well. The power resistor is wound this way to cancel each other so no magnetic field is induced.
                  Magnetically the two individual fields CCW and CW are ZERO!!!
                  Not then this is the way the Auroratek transformer is wound.
                  According to Bob in the other thread he found this out from Bill though he knew it already.
                  You can not turn a CCW wound coil upside down and make it CW it is not the same thing.
                  Mike
                  • Dot Notation
                    Keep going Mike, I still don't understand. Pretend you are trying to teach a child.
                    I have never encounterd an instance where the simple dot notation hasn't been sufficent to determine the correct phase without the use of a scope.
                    Again, if I wrap a coil with one turn, is that turn clockwise or counter-clockwise?
                    • Originally posted by Dog-One View Post
                      Are you trying to draw current from BOTH secondaries simultaneously? If you just try to short one, the input flux will avoid that particular secondary if the opposite secondary coil is open.
                      All of my coils are wound in the same direction. Looking at any coil from the front will be similar with all of the coils on my SFT, wire starts and finishes in the same relative places. I'm getting good results with my test setup.
                      • RA
                        I screwed up, twice. For one I have a step-down configuration and two, I'm using silicon steel cores. I think those cores are simply unable to transfer any power at 14kHz, which is where I see the highest voltage output and the best phase shift on the input. I have my secondaries wired in series to get the most voltage out that I can, which is still under 12 volts. I also have multiple taps on the primary but when I use any of the lower turn winds, the phase offset quickly heads to zero.
                        My AlphaCores will ship tomorrow, so maybe next week I'll have version 2.0 to work with.
                        For the moment Dave, you hold the reference architecture; anything you can tell us that will keep us on track, is probably the right way to go.
                        For one, about how much wattage can you get through your SFT? Does it appear to limit itself long before you would burn-up any windings?
                          I wouldn't use silicon steel. I've never seen anything good from it. Your success seems to be directly related to core material. I've used a few different kinds and don't get consistent results with my apparent success of the FerroXCube cores. My experience with my transformers may have no bearing on what your transformers might behave like if you use different material. Note that the BH curve of my material is highly square.
                          I only see good results when I resonate the secondaries with a series capacitor. However, I don't go into full resonance as it kills the effect completely. I stay on the lower frequency side of resonance and begin to see a negative power factor on the scope (ordering new probes as we speak so I can double check). You can feel heat coming from the dielectric in the series resonating capacitor and it will shock you with many volts if you aren't careful, don't use LV caps. I haven't calculated anything yet, but when I feel heat and see negative power phase shifts on the scope something makes me feel good about this. I claim nothing, just observations.
                          Since I am using a resonating secondary section, I can say that I don't like off balance configurations on the secondaries winding count. I've built two SFTs so far, one with equal number of turns on the secondaries and another with golden ratio proportioned unequal turn counts. The one with the unequal secondaries won't resonate and is less efficient in my preliminary investigations. Just hot glued a few more toroids together tonight. Maybe I'll get to winding another one soon.
                          • Originally posted by Web000x View Post
                            When I mentioned turns on the secondaries before, what I was getting at is a fixed turns ratio between the primary and secondary cores, if you have room to do it. So for example if you used a 5P to 2S turn count ratio, you would wrap like so:
                            A turn around the primary only,
                            then a turn around both the primary and the secondary,
                            another turn around just the primary,
                            around both,
                            and again a single around just the primary.
                            Then repeat all of the above for the whole winding however many turns you are shooting for.
                            Do both secondaries windings identical. You may want to go the other way and do 5S to 2P instead, some ratio that is easy to remember while winding. 1:2, 1:3, 2:5, 3:5, 4:5 You get the idea right? Mechanically, you'll have to leave a gap large enough to loop the single core only turns, or do those loops off to the side. I'm thinking it best to not just do all the single core windings, THEN the dual core windings, or vice versa. It may work the same, it may not. Gut feeling is that following a pattern is better.
                            I'm really not sure what this will do. The idea is to adjust the Back EMF in such a way that you can tune the SFT to run the kind of load you anticipate for it. Normally, more turns means lower flux density, so would you want lower flux density on the small primary core, or the larger secondary core? I simply don't know so I'll have to find out myself experimentally or someone can try this and give us a field analysis of what it appears to do. It might become obvious right away 1:1 is best, but who knows until we try. Bill might have one in his lab set to the golden ratio that works wonderfully, but we haven't seen it and probably won't. My gut tells me the ratio should match the cross sectional area of the two different sized cores; that should make it so both cores would saturate at the same time, getting the very most possible from all the cores.
                            What I'd really like to see is to take the output, rectify it to DC and put a constant 5 amps through a load while holding 13.8 volts. All the while the input side sits at 90 degrees out of phase. The immediate application of this is a battery charger requiring minimal input power. It would replace solar cells overnight (pun intended) if we figure it out and can replicate it consistently. True I want to learn how to build one of these things and understand it, but with the investment made already, I'd like to put it to work as soon as possible too. OU is good, but OU finally paying dividends is better.
                            • I plan on winding this next one with as many secondary windings as possible. Not sure how many I can get, but Bill had a small primary with BIG secondaries. I'm seeing that the dielectric side of the secondaries is the way to go. I also have that unbalanced secondaries core to modify since I'm not impressed with it. Maybe I'll strip off the secondaries and try a 1:1.
                              Are you suggesting I use one conductor to wind a turns ratio test? Kinda confused...
                              • Coil Winder
                                Thanks man. I am going to wind one CCW and one CW first to see if I need a cap? Will a cap always be in the tuning? It makes sense of course.
                                Thanks for that fact that you have wound you coils in the same direction.
                                I am still in the winding stage of 120 turn or more plans gonna fill the area that is 5/8" high by 3/4 wide this maybe more like 150 turns for me and yes both the same is what I thought.
                                Down the road show the amp draw on the wall and see how much power pumps out on the other side and keep tuning great job.
                                In Thanes video he states that many companies have verified the transofrmer and are incorporating the Bi-toroidal transformer into electric bikes. One company is an amplifier company. They are good at building ac wave generating equipment so this is why it fits well with their corporation.
                                Unless you go into sales you are free to power things around the house obviously if you work hard generating ac waveforms at a good efficiency.
                                Even though we are only looking at a few watts this is a break though for the average Joe experimenter.
                                Thanks for being there and showing everyone with great ease how we all can do this 90 degree shift or even more.
                                This is so awesome.
                                People need to wake up, free energy is here.
                                Mike
