Anybody can replicate this?
  • #16
    Hi mire, That's a long way from being free energy I'm afraid. It costs a lot of money to
    run a power station. Without the power station running the device does not
    work. So if there is a blackout it won't work. Believe it or not that device is
    using energy provided by the power station.
    bigger is better cheers.. Free Energy Device ( the 3rd generation ) - YouTube
    are you an expert on this? have you built one? can you explain exactly how it does what you say, because you simply say it?
    makes no difference to me free is free!
    • #17
      Well, does it work when there is a blackout ? Can you or anyone else say for
      sure the device does not use metered energy/power or add to the bill ? Will it
      work if the power is not connected to the house ?
      • #18
        Originally posted by mire View Post
        I have seen only one free energy device.
        Its on youtube, the name of the inventor lorrie machette
        I would suggest every one start building these devises he provides free without charge.
        Free Energy " One of a Kind Device " - YouTube
        Another one I can mark off of my 'to-try' list. This Lorrie Matchett "one of a kind device" is garbage. I first tried a 0.5 meter brass rod wrapped with 0.4 insulated wire. Sure enough, the the rectified DC voltage shoots up to 110V when plugged into the 220v mains supply. The problem is that it takes about 15min to charge a 220uF capacitor!!! I then tried an 0.8 meter 5mm diameter iron bar wound with at least a few hundred meters of 0.2mm enameled copper wire. This time with just the voltmeter across it, it would instantly show 200V. It would charge a 0.47uF capacitor to 275V in about 2secs but a 47uF capacitor would instantly charge to about 60V then ever so slowly start charging the rest of the way up. It's all voltage, there is absolutely no usable current available.
        If this worked on the electrostatic principle stated, the obvious next step would have been to generate much higher voltages from a battery setup rather than using a low voltage mains supply. But it doesn't - all you've got here is a crude transformer, siphoning power from the mains supply.
        What annoys me is PJK's certitude in his write-up on this - on reading it, it seem almost plausible!
