*sigh* another 3 long winded posts of pure rhetoric and ad hominem attacks against the wrong target... You are truly a master.
You managed to find the About page yet you refuse to believe I exist just because my name doesn't fit into your narrow belief structure? Typical of a charlatan, and it shows ignorance to unique ideas.
I am in charge of the technical information on Let's Replicate. I'm a counter-troll that fights "troll physics" (incorrect claims that don't match reality), I enjoy spirited, intelligent debate, the peer review process, and talking to people that aren't lost in a world of fantasy. I've built many working and non-working replications of assorted interesting, but predictable devices in the past and noticed that there was nowhere online where people could post them that they would always remain up and not be buried in forum threads, or lost in the bowels of YouTube with far fewer views than they deserve. Diana has asked to to attempt to remain "as civil as possible" when representing Let's Replicate publicly because I represent the entire staff, which I am trying hard to accomplish but makes me frustrated when dealing with trolls due to the pointless ad hominem attacks.
It is quite impossible to find out information about me that I don't provide since Goolgeing ^.^ is not permitted due to the limitations of search engine programing: one of many factors in my choice of the name. I don't seek recognition for my work; and I don't don't care about money: ideas are the real wealth, and the working ones need to be disseminated in a better way than they currently are.
I'm not a carpenter: I do industrial design engineering. That means I work primarily in a 4-dimensional visual environment (CAD, or my own head: both work because I've been doing this for long enough) to solve engineering problems so that the problem can be solved in real life. So if a person can give me a "visual equation" (which includes text, diagrams, schematics, any math equation, and some chemistry equations) for what they are trying to build/do, I can "see" (hard to describe how it works, but it's awesome) how to build it. Most of the time I don't need to "scribble out equations" either because I can "see" them working, but I am aware that it is sometimes a very necessary part of the process and I know that ignoring an aspect of reality does not make it go away. If it looks like a nail to me, you must have been talking about nails.
I have built many circuits, the picture below was built when I was in school for electronics engineering, it is the alpha prototype for a small signal digital oscilloscope that I designed and build myself. The wires are color coded by standard conventions and circuit area (yellow - input/calibration, blue - AtoD, orange - 16 bit bus, white - display). The maximum sample frequency of the design was up as high as 16Mhz but had to be cut back when the LED display was replaced with a microprocessor for the beta. The prototype was so awesome that it was featured in the school's "technology fair" which normally only featured "finished" projects. I never had the heart to destroy it to get the breadboard back (I just bought more), so it's just sitting in a drawer now.
On that note: I used to design biomass boilers and furnaces, which sometimes included heat pumps for air conditioning. At the time I was working with a heating engineer who would do all the heating/cooling energy calculations, but I did pick a little of it up. So, let's talk about why you have an neither an "apple" (Btu) nor an "orange" (joule):
A "degree" is not an apple when it comes to heating or cooling, a Btu is:
If you can't tell me how many Btus/joules of cooling you have, then you don't have any. Your claim is an anecdote, not fact (regardless of how many people that you claim saw it happen). So I say again, how many joules of cooling did you have? Your claim is that you have a "heat suction" (cooling) and are using it to produce electricity. I'm asking you to prove the cooling effect by use of a simple, standard test. That is not unreasonable and your staunch avoidance of a simple request is evidence that you probably don't have any "real" cooling because there is no logical reason why you would refuse the test if your claim is true. This a is major issue because unless you can prove the cooling, the extra electrical energy was likely from stray emf.
To answer your list:
"Time" (t) = 0sec "when you drop the ball" because the ball has no kinetic energy at the moment it is dropped. You also don't specify how long it takes you to lift the ball in the example, or how long you held it for both of which make the initial lift work immaterial to the example. The ball could have been created on top of a 1m table and then fallen off to provide the same results.
That's funny because what you are trying to do then is reject math entirely and "guess" your way to the answer. Doing that often leads to confirmation biases because you can not "check" your experiment using math. What makes you any more right then the nut-job who believes in the "time cube"? At least he has his own poorly derived math to prop up his argument. You are arguing the equivalent of the moon being made of cheese despite there being evidence to the contrary, as I've previously stated.
In order to reject the two-vector calculus that resulted from the Lorentz transformation of Heaviside's simplification of Maxwell's work, you'd need to understand the four-vector calculus that Maxwell was doing. I can assure you that four-vector calculus with "mixed observer" references that can't be reconciled with each other make Maxwell's math brain-bendingly non-intuitive for even the most seasoned mathematicians. Maxwell begin his work based entirely on trying to understand experimental data of Faraday. At least with two-vector calculus everything can be simplified to a single 2 dimensional graph with a common starting point.
"Advanced calculus" is a joke. When you can show that you know how to Laplace transform an LCR circuit diagram in order to produce the transient equations and accurately predict how it will react to a non-standard signal input within experimental error: I'll be more inclined to believe you understand the ramifications of multi-vector math. Just because you don't understand it doesn't make it wrong and the fact that it matches reality and is consistently verified by experiment proves it right. If even a single experiment is performed that doesn't match the math for it, new math is written to account for it: that's how people get themselves a Nobel Prize. The system works well in this regard.
If you somehow think that the equations you guess into existence better describe reality than engineering equations, by all means provide your mathematical proof. Geoff and I are capable of certifying its accuracy and bringing it to the attention of many engineers if it's right. Surely you will win a Nobel Prize for completely eliminating the need for calculus in the fields of engineering world-wide.
I'll let Geoff know you hold him in high regard while having utter disrespect for his hard-earned credentials and experience. We have other staff on Let's Replicate that are not currently listed on the about page, a few are engineers, many decline to provide their names due to the expectation of "free energy" troll attacks very similar to what you are trying to do to Geoff right now. As the owner of the forum wanting actual experts on a topics to provide any incite at all, you should be ashamed of yourself. I'm sure Geoff would be less inclined to post here himself due to these insults.
- You don't give your starting or ending ambient temperature, nor do you provide a stable ambient air temperature for all of your data points.
- You don't provide accurate times for the cooling to allow energy calculation.
- You don't give the thermal mass of your probe.
- Air has a MUCH lower heat capacity than water and air circulation adds measurement error.
- Technically all systems are "open" by the classical definition. That allows for insufficient classification though, so if you want to say that: "a closed system is not designed to make practical use of environmental input while an open one is", that's fine with me. That does mean then that the in your example of the bouncing ball, it is a "closed" system then. The IDEA of the ball bouncing is an open system, in the example, it's a closed system.
- Yup, that's right based on your explanation of "open dissipative systems". You said that they "avoid thermodynamic equilibrium", which is not the proper definition, but I'm willing to try to work within your understanding.
- The force of earth's gravity being reduced to the acceleration of 9.8m/s^2 assumes it has a stable effect on the system at all times. Is is the means that potential energy is converted to kinetic and back again, but it is not an energy input per se. It is a derivative of force, not a force itself.
- The ball does not normally leave it's equilibrium state (stationary) unless there is an an explicit energy input. For the ball to proceed into oscillation on its own ("avoid thermodynamic equilibrium"), the ground would have to be shaking or there would have to be some other sporadic energy input that is not disruptive to the oscillation but adds to or maintains it. That is an environmental input.
- The universe contains its own "time" dimension, the universe will end when time does. The arrow of time is actually in reverse: the "past" is really the "future" so the universe is actually contracting in reverse.
- Short answer yes with an "if", long answer no with a "but".
- The simplified physics equations already account for gravity's ability to convert potential energy to kinetic energy. Ek = -Ep
- The acceleration due to the aether rushing into and passed the ball is a "constant". Aether itself doesn't "contain" energy that can be passed to other objects, it is a vortexing downward current (like water draining out of a tank) that has its own momentum but does not have "electrical potential". It's hard to describe in words because people nit-pick the words used to describe the effect.
I was
very competent in advanced calculus 20 years ago in college and I
thank God that I never used it as a crutch to figure things out or else
I would be handicapped beyond belief in terms of building things that work.
There are thousands of people that are classified as geniuses that have spent their entire lives working in those areas of research, and you can bet they understand how a bouncing ball works by now.
