Let us first assume that everyone here is a good-hearted, open-minded, well-meaning, unselfish citizen of Earth and ALL of us are scientists with equal footing.
Let us further assume that we are engaged in a scientific pursuit where nothing matters but facts, theories, laws, observations, and truth.
We can also assume that we all seek the same thing, a truth that breaks the known laws of the conventional paradigm. Scientific rigor and carefully thought out methodology will provide the truth or will disclose an unknowable phenomena or a falsehood with like ease.
Because we are the above, there is no need for derision or sharp biting comments of any kind. Questions can be answered in the most concise manner while allowing for accuracy and precision.
Scientist number 1 (S-1) Aaron has made some pretty extraordinary claims, that if proven true, ultimately and forever break one or more of the known Laws of Thermodynamics. His claims are presented in a manner that leaves me (S-2) with many questions.
Quoting S-1:
I can put DC from a battery into an inductive
resistor and make that inductive resistor drop several degrees C below
ambient temperature while the battery's voltage and load powering ability
climbs.
S-2: I want one of those. Is there a thread, a video, a schematic and description of the coil?
I am assuming of course, without seeing the setup, that this is not thermoelectric cooling so I am at a complete loss to explain it.
S-1: That is OU and your belief in the calorimeter doesn't apply.
S-2: I don't see any reason we can not measure this accurately with calorimetry. Heat or cooling uses the same calculations.
S-2 I don't understand your statement above "while the battery's voltage and load powering ability climbs." Can you explain exactly what you mean and what test you performed to arrive at that conclusion?
S-2 I read your statement as saying, "My closed system running off one battery, is self running and produces excess energy that I can pull from the battery forever". Did I mis-read this? I hope not because now I really want one of these devices. If you can squeeze out just one watt you have won Dr. Jones prize and I hope that this would be a scalable effect as well.
S-1: The measurable amperage from the battery is _negative_ the
entire time.
S-2: I suppose by way of convention, you are saying the current is flowing the opposite direction as you would expect because the battery is charging? Doesn't really matter since power is absolute and equals I2R, the sign goes away. Which would explain your next statement.
S-1 That is free energy coming right out of "nowhere" to charge the battery while running the switching circuit to the resistor, etc...
S-2: Again I can only read that as saying, "I am breaking the known laws of physics. I have a closed system which is creating an excess of energy so that my system is not only free running but that I also have extra energy (regardless of the meager amount) that can be pulled out of my system (while maintaining the starting voltage level) to do work elsewhere for any length of time, for instance into a carefully chosen resistive load whose dissipated heat can be measured by way of calorimetry."
S-2 So if I measure the cooling energy as an absolute and add that to the energy of heat produced from the load, would that not be a fair measurement of your system's energy production? No tricks or traps with credit given on both sides of the equation...work done is work done.
S-1: The switch remains the same temp while inductive resistor gets cold.
All measured with very expensive calibrated platinum probes - highly
accurate but irrelevant to show that the temp absolutely drops. A 5
degree C drop in the resistor is the lowest it went below ambient.
S-2: A simple non-contact infra red thermometer would be perfectly adequate having determined the coils thermal mass or heat capacity, as would placing the coil into an well insulated air calorimeter. I have only used water but I'm thinking the different dielectric might kill your effect. There is a proper method of using readily available formula for doing this I assure you.
S-1: The battery winds up with more than I started with while the circuit
connected to the battery was switching the whole time.
S-2: Again, you lead me to the very same conclusion that you are stating energy from nowhere appears in the coil or other parts of your system which will run forever unless the battery fails. This is the answer all of humanity has been looking for Aaron.
I have been looking for years for someone the break the thermodynamic laws. I have followed inventor after inventor. Magnet this after magnet that. So far, because we live on a tough planet, Every single one of them that made claims like you have ALL turned out to be liars, frauds, and greedy purveyors of snake oil. I thought years ago, watching a video of you, before giving you money for the "key" book, that if anyone could do it...Aaron can. Congratulations!
S-2: Sounds perfectly like OU to me and my belief in calorimetry applies perfectly.
S-2: I want one. How do I replicate your work?
S-1: I'm not the only one that has done this.
S-2: Then it is not a secret, is reproducible with repeatable results, and I hope that you should have no problem submitting your device for testing and peer review by my methods of measurement which will be designed to favor your system, not the incompetent, dishonest, methods you have mentioned elsewhere. Now you can have the truth and it shall set you free and hopefully, along with the rest of humanity. I can't wait! Make it so!
Sorry, in all the excitement I'm having over this new information, I forgot to add that all the heat produced in the battery and switching circuit will also be added to the total energy production. That and Merry Christmas
S-2
___
Quoting S-1:
climbs.
entire time.
S-2
___
....I'm done. If you are not I can come back and call you what I heard at the forum across the street and let you ban me for a real insult.
