Hi Slider,
Tnx for the heads up.
Yesterday I decided to make a joule thief and wrecked an old power supply for the parts. I did find a nice toroid wit dubble copper windings on it, find a 1k resistor and a Mosfet (IRFP460A).
I soldered it all together and as I needed an input power I uses the Garden Solar. The light went on butt i did not see any difference , so I unhooked it (I did not take measurement, maybe I had a good Ampdraw)
This circuit seems efficient now,but as you buy it, there is a El Cheapo rechargable battery in it and the original led was so dim, i sometimes had to find the right looking angle to see it even glow. Now with the extra battery things work much better, maybe it was at the edge of operating Voltage with just one AA.
So I analyzed the Solar thing and came to the conclusion it had to be a Joulethief of some kind. So in the beginning I coupled a Joulethief to a joulethief ;-) After removing that I started to do so measurements and Letsreplicate was kind enough to guide me over the first steps.
My goal is (besides "free" energy, as we all, and just some fun making things and trying things out) To get a small water-pump running on a solar panel. And a few (LED) lights as grow lamps for my indoor Aquaponics. I was think three 2x2 solar panel and 2x2 penlights should do the trick, remove the optical diode and hopefully it can run my waterpum (Just a tiny continues flow)
LED FLOODLIGHT / LED REFLEKTOR 10w 20W - YouTube
Does anyone know if these LED high power floodlights run can be hooked to a joulethief? I think i will get into the jouleringer, or flip flop stuff for higher wattages and voltages?
I have tons of ideas ;-) Anyone tested those inverter circuits with some more interesting stuff as Peltiers, or run a simple low friction Stirling to produce low cost heat or cold?
It seemed odd that it didn't have an inductor while I was drawing it up and it being an inductor makes perfect sense now.
Any chance you'd be willing to explain double loopstick energy scavenging on
Also, our dear wonderful sweet cat 'MiniMe' sent the circuit flying across the room one day, with a deft flick of a paw.
