Walter Russell - Understanding and applying his work
  • anotherwalterrussellfan
    Originally posted by cplouffe View Post
    Hey guys... I am wanting to create a 3D model of the periodic chart. But I was looking at one of the other charts and it has a 10th octave. hmmm. I haven't read that in any of his stuff yet. Am I missing something?
    Also I feel like I need to build it as a spiral from larger at the bottom to smaller at the top, but I have to have the inertia line in there. So... does the wave loop out and then come back to the inertia line to connect? Just higher up, correct? But then I read about ellipsoids. How does that work if it looks like semi-circles of a wave.
    Thanks for any help!
    When you do this, please try to indicate the polarities with colors like in this one...
    I know - i simply missed to add her... sorry for that :/
    Btw. tell me when the missing pages are found somewhere. I will add them into the pdf file then.
    I love how you made Red and Blue into PURPLE
  • MonsieurM
    Much appreciated anotherwalterrussellfan
    One slight rectification should be made...As" Walter Russell " wrote "Everything has poles "....the Work of Russell is not an Exception ... for it is the work of Walter and Lao Russell
    I think it is Important to Mention it ... as probably WR would have wanted it to be
    Atomic Suicide material
    Guys, i have noticed that you used Atomic Suicide | Are We Committing Atomic SuicideWalter Russell - Atomic Suicide
    I hope you guys like it
    Now i will go on and read the entire post.
  • StweenyA
    I found the source where Walter Russell says that there is no Oxygen and Hydrogen in water, instead they are "manufactured" by when a current is passed through!
    It's in his book called "The Russell Genro-Radiative Concept" or "The Cyclic Theory of Continuous Motion"
  • StweenyA
    Haan, Exactly, there are so many seeming contradictions.
    This Bible verse is puzzling me, I think it may be related:
    (Ecclesiastes 3:11) (KJV)
    He hath made every thing beautiful in his time:
    also he hath set the world in their heart,
    so that no man can find out the work that God
    maketh from the beginning to the end.
  • MonsieurM
    Originally posted by barbosi View Post
    PPS: Ahem! Is not obvious to me though the balanced state of Carbon Monoxide (CO), or Carbon Dioxide (CO2), or of the miraculous molecule H2O. Are these molecules unbalanced? what might be the purpose?
    What about NaCl dissolved in H2O? Is that another super-molecule called solution? If NaCl is so neatly balanced, then why is unhealthy for humans the excess of it? Well that's silly, is the metal of Na that's unhealthy, but you got it. For conditioned minds, answers are not always obvious.
    Well... the [re]search goes on.
    hope this helps advance your research :
    http://rexresearch.com/rahn/rahn3.pdf on page 5
    The same authors found that even the dissolution of NaCl
    in water produces & growth-stimulating radiation (Table 14) This
    energy emission occurs only during the act oI dissolving ; it- ceases
    completely when all the salt i8 in solution' No effect is noticeable
    when sugar is dissolved in water, or when palmitic acid is dissolved
    in alcohol. Wolff and Ras concluded therefore that the process
    of dissociation of salt into ions is the source of ultraviolet'
    [B]truly this document is full of info (principle of correspondence )
    AWalter Russell Paintings Paintings by Walter Russell
  • electronicsounds
    doesn't know if it has already been posted
    About hydrogen production from water:
    Walter Russel - Use of Magnetic Fields for Hydrogen Production Using Dual Polarity Control and ...
  • barbosi
    Originally posted by StweenyA View Post
    I'm thinking it has something to do with male/female, but I don't get how this works, for even basic molecules. Please somebody give an example if possible....
    Far from being an expert, I may suggest looking into Sodium Chloride, a crystal used few times in Russell's works. Use his 1926 periodic table (like this one from http://www.walter-russell.de/Illustr...densystem2.gif but you may prefer it in english) and locate the elements. Where is simulated the still magnetic light with regard to those elements? (such as carbon, but one octave higher, )? I bet for more complex molecules the process is similar but requires a broader attention span.
    PS: An image with the cube crystal of NaCl:
    Note also the size of the spheres and refer to the corresponding octave, and also the polarity of each element which would have its sex-polarity in the chart.
  • MonsieurM
    One thing that frustrates me about his books, is that he keeps on mentioning "this is not a textbook" etc... Well, where is the textbook? does it even exist? Or is this the part we have to figure out on our own lol
    The Texbook will reveal itself as it is all around you...Think of it this way, if it can help, If Walter Russell had access to the word Fractal, don't you think he would have used it in all kind of manners
  • dambit
    I find that it helps to forget pretty much all conventional explanations with regards to the how and why of chemistry when looking at it from the Russell point of view. Molecules exist but they are not exactly what we were taught in school and they don't behave in exactly the same way either.
    Once you start to do this things begin to become clearer and easier to understand.
    Steve
  • StweenyA
    Great posts all, really enjoyed reading them, thanks!
    I have finally finished reading "Atomic Suicide".. although, I do not by any means feel I have completely finished with it for good, nor do I feel like I completely understand it. Some things only clicked when I got to the end of the book. Now with everything in mind, I'm going to have to read it again, from the new perspective.
    One thing I'm struggling to understand though... How, or does he explain the eqivalent of molecules??
    Am I missing something here? I'm thinking it has something to do with male/female, but I don't get how this works, for even basic molecules. Please somebody give an example if possible....
  • dambit
    Ok all,
    I've just put an order in with my metal guy for some coil cores. I uploaded a pdf showing the dimensions in case anyone is interested. I should have them in a week or so, then I have to drop them off with my coil guy so he can wind those bad boys.
    Should be interesting.
    Steve
  • MonsieurM
    Originally posted by purelyconstructive
    However, no matter what book you choose to read, through careful study and peaceful meditation all information that one needs to have in order to understand Reality is readily presented. What do you desire to Know and why? Constantly hold it in Mind with a feeling of Respect in your Heart and the resources to unfold one's comprehension in regards to this subject will appear within you and before you. To use a familiar proverb, "When the student is ready, the teacher appears."
    When we make Truth, Beauty, Love, Wisdom, Joy, and other constructive principles our very Purpose, there is no more searching for these qualities as they begin to appear everywhere in some form. Nature is continually communicating with us if we have but the "eyes to see, and ears to hear"...This includes practical scientific knowledge that can be applied towards everyone's mutual benefit.
    Thank you again purelyconstructive
  • cplouffe
    Great!! Thanks for that explanation. That is my next step. Asking within and trying to get answers. A little too much time lately searching external sources.
    I am almost done with Atomic Suicide. But I have read Secret of Light, and a New Concept without ever seeing the 10th. So I see now.
