Dr Stiffler SEC Replications?
  • #16
    I can tell you it works, check this out, we are in the middle of making a tunable cap and inductor board for it , the circuit was not hooked up correctly, we dropped the board on the ground cleaning up, some contact was made and an LED came on , NO POWER INPUT.
    Andrew and i nearly %$#$% our selves, i should of taken a photo, did you really think the Doc was not telling the truth?
    TRUE STORY, its me .
    Great news Ash. I've been watching his videos for a year, and despite there being a multitude of ways to fake the demo, the guy just never struck me as BS'er... he's just way too into it, ya know? People generally don't get that involved in their frauds, so to speak. Nice to hear this.
    • #17
      Originally posted by Kokomoj0 View Post
      Velly velly interwesting!
      I have a couple q's.
      First when we talk about a lattice, we are talking about the equivalent circuit o maybe I should say the expanded or complete circuit of the coil?
      Next 1.094 is specific to these particular coils and that would change with the diameter in combination with wire thickness I presume?
      Next is there something unique about the 13mghz area?
      Finally can this work with any coil at any freq?
      Say 150khz or 250mhz?
      This is frankly fascinating and I am trying to establish some rules of thumb from your videos.
      I can't quite tell you what the lattice is but I can answer your other questions.
      When you ring a coil normally you will get a peak at f0 (where f0 is the frequency) 2f0, 3f0, 4f0 etc. When the coil is excited by an exciter you get peaks every 1.094MHz which is very bizzare because conventionally you should only get peaks at multiples of f0 (including subharmonics 0.5f0 for example). The 1.094 will not change, it is a sort of signature of spatial energy coherence rather than the properties of the coil.
      It can work for any sized coil and therefore any frequency. However the Doc has several times urged replicators away from the larger coils, he says smaller coils are much more efficient. Check out this discussion;
      Exploring Dr Stiffler's Spatial Energy Coherence and Spatial Resonance effects. - Heretical Builders
      Raui
      • #18
        Originally posted by Raui View Post
        Frequency wise that instrument is fine however at 1V peak to peak I have some trouble measuring srf so if you used that circuit you'd have to have it switch a transistor which can handle say at minimum 10v but the higher the better and fast frequency. Ideally you'd want to get a 12v signal transistor which can switch at up to 20MHz, because your using the diy rf voltmeter you will have trouble measuring at low voltages so maybe even two batteries (9V or something so that you end up with an 18v signal). Here's a very rough circuit of what you'd want;
        You don't need high current capabilities so I'm sure you'd be able to find an appropriate signal transistor.
        Raui
        In choosing the transistor, if using a signal generator that has 1v peak to peak, do you need a transistor with an emitter-base voltage rating of just one volt? Sorry for my ignorance, and thanks for all the help.
        The MAX 038 Function Generator chip goes up to 20 MHZ and Vp-p is 2V.
        • #19
          You'll want a transistor with a lower emitter-base voltage of under 1V as what is given is usually the minimum voltage for the transistor to work. Most signal transistors will be fine. 2N2222 should work okay but remember to put a resistor in there after the transistor as to keep the current down.
          Maybe that sig gen would be better then, 20MHz is all my sig gen does and since your aiming for a 13.8MHz srf I'm sure it will be fine.
          Raui
          • #20
            Really, for this replication, don't we need someone to post a pic of the back of the 18X board ?
            Then the 1000uF 50V cap gets added, and the other changes are implemented. Hey presto, some mind numbingly frustrating tuning later, someone posts a runner.
            If so, then Dr. Stiffler would have a validation that discounts many peoples negative presumptions about his location.
            On topic, but off on thoughts here - if I get something PSEC'ing nicely, i'd like to calibrate and ramp up the 60kHz signal from Fort Collins, CO. It's the source of the atomic clock signals and, of course, Colorado is where Tesla conducted his famous 1898 experiments.
            I view that as the modern day Wardenclyffe (in fact, take out the audio from any radio signal and what you have is broadcast energy).
            Wireless energy transmission being amplified and used, from the very part of the country where he conducted those wireless experiments. That signal is countrywide, so, many more people could do the same as replications.
            Geeky as anything but what a project !
            • #21
              Raui
              thanks,
              very interesting...
              So then who thought up the term spatial energy coherence and what is the theory behind it? I presume there must be a write up from some one somewhere? Also I was perusing and someone mentioned nuclear decay? Yes the term lattice is also very important, and even more so now that we know the 1.094 is not winding dependent.
              • #22
                deleted post.
                • #23
                  Kokomojo0,
                  You have mail.
                  Raui
                  • #24
                    It hasnt even been 24 hours and another cosmic cop who doesnt get it.
                    you could also have had respect and emailed me privately but you like the other person chose not to do so, why not practice what you preach and you both really need to learn about the fair use policies that I in fact did comply with.
                    nuff said, I will edit this in the future based on your edits, or not. your choice. UNtil then this will stay up and people can take notice of the hypocrisy.
                    yes how about a little respect?
                    • #25
                      trying to work on the PSEC here for ..sake.
                      Too much bickering, the PSEC deserves more so does the doc and YOU guys.
                      not blaming any one OK... but
                      1) The doc should be allowed to post here -can we change this why not?
                      2) People should work TOGETHER AND with the doc
                      3) Stop fighting against each other no excuse
                      is that to much to ask..Aaron, can you help? , can we get the doc back?
                      shesh man, people should give each other a chance to COME AROUND, if there are any problems, who else cares?
                      times are tough , cant we ALL yes good and bad see past the BS for at least once in our lives?Thanks guys, just a thought, didnt know the Doc was banned here.
                      Ash
                      • #26
                        @Kokomojo0
                        I agree with Inquorate, please do not copy/paste Ronald's copyrighted texts, afterall, if he ever reads this thread, it'd be nice to be professional and courteous towards his efforts. Please remove it, if you are still able to edit?
                        Kyle
                        @Inquorate
                        Could you post a link to (any info/vids) re: your DIY RF Voltmeter that raui mentioned to me in a PM? Thanks.
                        I'm currently uploading a video of the circuit and how it works compared to my oscilloscope. It worked out to be within 0.2MHz of my oscilloscope, not bad at all. Check out my channel sometime in the next hour or so and it should be done.
                        Ash
                        I agree, we're all grown-ups here are we not?
                        Raui
                        • #27
                          first I am not upset, this is purely academic and an apology is not necessary, secondly I identified a character trait that was unequivocally demonstrated which is distinctly different than "name calling", and finally its unfortunate that my remarks on the matter in that post are considered "not adding input" and that anyone would fault me for what in their "opinion" they consider "not adding input", since it is after all discretionary. It in fact should be considered input and if its not, well its not my loss.
                          you dont create a peaceful thread by taking yet another dump in my back yard and expect me not to call foul ball.
                          as a side note I was not aware stiffler was banned either and frankly expected an answer from him directly on my last post on the matter that has gone unanswered.
                          now back to your regularly scheduled psec channel.
                          • #28
                            Raui
                            Kool I ll check it out....
                            • #29
                              I'll keep my eyes on your channel too Raui
                              Would have checked before now, but have been uploading a progress vid too, comp gets slow if I open too much.
                              Things are looking better over here, after I really took a good look at what Dr. Stiffler was doing in his PSEC videos. I don't have the test equipment and so, unfortunately, have had to go down a different route.
                              It revolves around using phenomenon that I know from 'traditional' Slayer exciter builds.
                              A better version of an actual PSEC looking (and seemingly partially performing) device has been built. Wiring has been guessed at...so no real point in a circuit diagram, unless folks like what they see at this point.
                              It uses the HV output from the unit I showed in the previous page, so giving a source of known energy with which to work.
                              Voltage used is down to less than 3V, so the next stage is to bring the seen effects from a single AA.
                              Here's the video:
                              SEC replication progress - YouTube
                              Since the start of the upload, it has been found that the reason for some of the initial slow startup of the device has been because of the 1000uF cap charging ! All of that side looks to be fine in retrospect.
                              15 LED's are now on the 'power meter' seen on the video and it gives a great idea of what sort of energy levels are flying around
                              • #30
                                I have/had no idea why Dr. Stiffler is banned from this forum, but judging by some of the flames I have read in another forum, I can speculate he got annoyed... and I only hoped this thread would stay healthy. I agree with Ashweth, let's just drop it, and ultimately: I apologize for being judgmental or disrespectful if that's how it was perceived. I am excited to see a few make efforts and see some success, and hope to learn more about the PSEC.
                                Dr Stiffler is not banned, he moved to another Forum, where he may think to be more save from the Copycats, what try to sell similar Things as he work on or whatever, more Partipation at his Work.
