I may be wrong, but the negistor types are the requirement...however, he has shown a diode in place of that method on one PSEC.
RadioShack is good for a quick fix of 3 types all in the same bag for a couple of bucks (forgive my ignorance but do you have RS up there ?). Could be a tip for others, half a dozen of each of 2N2222A, 2N3904 and 2N4401.
How on earth they got the only 3 reported negistor type NPN's to be in the same bag in beyond me...unless extensive testing hasn't been done and the reports are based on a RadioShack bag
The NPN and PNP lists are in the huge JonnyDavro Joule Thief Exciter thread:
Post 1844 on that page
However, one thing to note, my recently posted codge up SEC 18-1 from a CRT monitor PCB uses a STS5343 - Datasheet here: http://www.auk.co.kr/pro_upload/STS5343_1.pdf
It was about the only 'decent' transistor on the PCB.
Now, what do I mean by decent ? really, that it has a high hFE, low switch on voltage, decent switching speed. It's the same story with regard to the trannies lists I put together.
Notes on that one - Low collector saturation voltage of 0.25V, Max current gain of 240, Decent breakdown voltages of 60V and 50V and fair enough switch off of current at 0.1uA. Collector current is 150mA, which, isn't bad, but nowhere near the 1A or so for heavier loading and keeping cool (if tuned right, we may imagine the tranny to run cool and the power draw to be very low...but until that happens, the magic smoke may escape).
Low side is the switching speed of 80MHz, but it's not bad in any way considering it'll never see that need to be quicker (power trannies can only typically switch around 3 or 4MHz).
Can forget C945, S9018, S8050 and others with similar datasheets...but by all means try them to see and compare.
For the Slayer, the best for me of the TO-92 size was the KN2222A, which is a slightly spritelier version of the ubiquitous 2N2222A.
Disclaimer - that's my experience, others may hold different views or have been around electronics much longer than I.
