The electric field of a magnet
  • Originally posted by Raphael37 View Post
    you are just another lying insincere X-tian
    if my brother had talked to ME the way you have on this thread I would have taken him out to the shed and gave the punk the 'tough love' whacking he deserved.
    Ralf your the brother Im concerned about.
    I hope you find your way back
    I'll keep you in my prayers
    dave
    • Iv got to get away from this for a while, its causing me to say things I really dont mean.
      I need some shop time, talk to you guys later
      Yah Bless
      dave
        Yah Bless
        dave
        Me 2
        ... that makes three of us ...
        but all four of us should take a break
        • what makes either of you believe you are even capable of comprehending anything of significance?
          • Originally posted by s e t h View Post
            Your so right Seth.
            What happens when a solar flare hits the earths magnetic field,
            The magnetic field carries the charged particles into the earths core, the magnetic field is a charge carrier and it carries that charge into the core.
            If we want to collect that charge we need to do it in the core, as the magnetic field leaves the core it expands but as it enters the core it contracts.
            Bloch Wall - YouTube
            Our transformers transfer energy from one coil to another outside the core usually through a common core, no overunity, maybe we need to look in the core.
            • So lets say we have our core built and our unit is ready to collect in the core now all we need is a solar flare
                DUH the simpleton response might be ... because we all can, IF you know how?
                i.e. it helps if you know how to activate your atrophied right brain.
                IF you have anymore questions Seth ... talk to the hand.
                selah V
                • Electricity heats the core of our planet, the magnetic field carries charged particles from the sun, stars, solar wind into the core where our iron core is heated to liquid metal.
                  These are not facts but my thoughts on the core design
                  If the solenoid were powered with a steady dc the cores could all be wound with the same winding ( cw or ccw depending on the direction the solenoid was wound ) remember the aether runs opposite the direction of the current.
                  Lets look at an alternating current solenoid, the poles change polarity, in other words the north will switch ends of the solenoid with the changing polarity of the current powering the solenoid. In order to catch the charged particles in the core half the cores will need to be wound cw and the other half ccw to accept the charge as the solenoid switches poles.
                  A pulsed DC solenoid would need to be wound the same as the AC solenoid because of bemf, when the outer field collapses into the solenoid winding it changes the polarity of the solenoid just like the AC system.
                  • As the magnetic field enters the core the welding rod attracts the magnetic field line, the electron runs in the copper
                    • one of the motions they have is they spiral around and around the magnetic field
                      How Electrons Are Supercharged in Earth's Radiation Belt
                      • Magnetic Viewing Film, Looking at Zen Magnets - YouTube
                        22 Hast thou entered into the treasures of the snow? or hast thou seen the treasures of the hail,
                        23 Which I have reserved against the time of trouble, against the day of battle and war?
                        • In an electrical discharge as the charge moves forward it branches out, if we follow this flow pattern and look at the snowflake the discharge is from the center out.
                          Magnetic viewing film should be called electrical viewing film
                            ok then we both love the THUNDERBOLT - aka Lightning
                            formerly a power only the gods like Thor and Zeus etc. could harness and wield its awesome power
                            then sometime between the old world gods and the 20th century god called Tesla, a fella named Ben Franklin was told by an inner voice "to go fly a fooking kite and don't forget to attach the KEY ....
                            Are you familiar with this book, with the work of John Michell?
                            I love the snowflake.
                            What I love about this book, is that John Michell knows his bIbLE babel and the numbers, and how to build sacred towers of babEL using sacred 'G'.
                            Chapter 5 which discusses Symbolic Numbers and 666 ends with this line.
                            The number (961) also indicates the manner of the New Jerusalem's appearance, suddenly as a revelation from above; for 961 is the number of the divine thunderbolt.
                            Which is a beautiful fit to what I had written here:
                            SO OBVIOUSLY I would love it if King Dave-id took a look at this book, and you might have some AHAs revealed to you, as I did.
                            I can see now why many folks love the work of John Michell.
                            i.e. Did you know that Magnesia which antedates Atlantis is associated with the CIRCLE?
                            Did you know Atlantis is the idEA that fell to earth in the shape of a SQUARE?
                            As you know the CIRCLE and the SQUARE is a problem/idea 'squaring the circle' that goes waaaaaaaaaaaaaaaaay back.
                            Now further to all of his out-of-this-world insights, maybe we can associate MAGNESIa with MAGNEtISm and Atlantis or maybe ELantis with ELectricity and EL.
                            What IF?
                            He also confirmed one of my most profound THOTH thoughts, that we can connect sacred geometry to the angels.
                            i.e. angELs know all about angLEs!
                            Till now the only other fella I can quote who said the same thing is one of hItLErs and hImmLErs mystics.
                            Karl Maria Willigut
                            Give John Michell's book a go...especially the chapters where he tackles what Plato really meant when discussing Magnesia and Atlantis....and you might love the chapter on 666.
                            I have a new hero, and his name is John mIchELL
                            Without a doubt, John mIchELL just like ME is a 'I37 - LEI' messenJAH.
                            Can we find correlations between his work, yours and mine?
                            Yes ... and we can use John Michell as mediator between Dave/Jesus and Raphael/SwaStika.
                            btw John Michell confirms what you thought about ME...
                            selah V
                            re: 961
                            something John Michell did NOT mention is that the numbers on the MIDDLE PILLAR or the MIDDLE PATH of the QaBaLaH Tree of LIfe are the numbers 1-6-9-10
                            ...and what can I say ... all of the above is a 'stellar' match for what I had already been 'recovering'.
                            I wrote this on July 4th, 2008
                            Happy Birthday aMEri-KA!
                            • Half of the Answer is knowing the right Question
                              • Sela V Wisdom
                                Hey Sela/Raphael,
                                We, the sheeple, get the message that you are infinitely wiser, more intelligent and far advanced intellectually over the majority of us. Therefore, it would be prudent and infinitely wise of you to attract us to your knowledge by mellowing your rhetoric into simple phrases and concepts that can be accepted readily by our dull minds. Please give us simple examples of your work with straightforward instructions for replication so that we too, can share this bliss! Do not push us away - attract us to this knowledge...
                                The Buddha, of course, just pointed without words - however we are not that advanced. Be the teacher...
