The electric field of a magnet
I havent put this one through the hoops and Im already planning another one
but Im going to ramp the next one up a notch
or six
I wonder what a iron toroid would do separating the two coils with the windings looped up and over the toroid, maybe cause a separation
Remember Photoinductions vid where he used an iron ring to separate the high voltage terminals, for some reason this keeps coming back.Half of the Answer is knowing the right Question
one way to check is if you have a copper tube you can slide inside the PVC tube and a Magnet ballOriginally posted by Dave45 View PostCool MM we are definitely on to something I havent quit got a grip on it yet but I will.
Something else to consider this is an asymmetrical system and I am getting a strong magnetic field through the core using dc this should tell you something about the magnetic field.
........ copper and neo magnet interact in a very peculiar manner ..... it was shown in the vid earlier about ed and freemason temple
and be careful ..... you may end up having the ball shoot up or down or not at all ..... always use caution
= ( http://www.energeticforum.com/renewa...netism-48.html )
also from http://www.energeticforum.com/renewa...h-other-2.html
Magnetic Warp (Circles) - YouTubeOriginally posted by Vortex View Postamigo WOW
Seems you guys over looked this.
This is amazing stuff, live, real time videos of MOVING Magnetic Flux fields.
Not a computer simulation.
Image taken via a Flux Resonator of a circular magnet
Signs and symbols -Confucius.
here is the vid i mentioned earlier :
Copper Pipe Magnet - YouTube
he has several neo magnets attached then dropped in the tube ..... but we can take it to the next level
Neodymium Magnets - Platonic Solids - YouTube!
we can try the same by dropping platonic solids in a copper tubeVideo demonstrating how to make all the platonic solids using spherical magnets.
Neodymium magnet in copper pipe + Nitrogen - YouTube
Hello All,
Following this thread with great interest already for a while...
I would like to share the following...
The Primer Fields Part 2 - YouTube
dave , i think this may interest you :
Magnetic Gear - YouTube + Magnomatics - Magnetic Gear - YouTube
Uploaded on Dec 31, 2010
The objective of studying magnetic gears is to replace mechanical gears which are noisy, require frequent maintenance and lubrication, and suffer from friction losses. The magnetic gear is contactless and quiet in operation, and it requires no lubrication. In addition, it slips when overloaded whereas the mechanical gear may break down when overloaded.
The magnetic gear has been studied more thoroughly in the last decade although there was a patent in 1901 by Armstrong(1) and an improved one in 1941 by Faus(2). Another significant improvement was contributed by Martin in 1968(3) in which steel pole pieces were used. However, it was not commercially marketed because the transmitted torques were small as ceramic magnets were used. Recently, strong rare earth magnets have been developed, and the new operational principle employing the harmonic magnetic flux has also been developed. As a result, a high torque density can be achieved. Hence, high performance magnetic gears can be marketed for industrial and commercial applications.
The theory of mgnetic gearing was established by Dr. Atallah and his colleagues at Sheffield University.Last edited by MonsieurM; 02-02-2013, 08:43 PM.Signs and symbols -Confucius.
Hey DaveOriginally posted by Dave45
six going in six coming out, energy folds in on itself.
This is the magnetic grid that encompasses our planet, it is also a wiring diagram for free energy
Since there is a lull in discussion and i dont want to interrupt the thread, i wish to ask you- where the stone carved image above is from?
Hope you getting on well with the fountain
Many thanks in advance.
Sayana
I think sacred geometry is a representation of the magnetic fields, what I dont like is that evil has tried to put their stamp on the geometry but it is just a representation of God's creation.
But evil has always tried to get man to worship creation rather than the Creator, he wants alot of company in hell.
I sometimes wonder if Im doing the right thing working and researching in this field its chalked full of representations of the snake.............. I have been thinking of this for a long time,
I want to help and thought free energy would benefit the poor but Im not so sure anymore.
Later
God Bless
daveLast edited by Dave45; 05-11-2013, 05:53 PM.Half of the Answer is knowing the right Question
Thanks!
Nice one Dave, will have a long look laterOriginally posted by Dave45 View PostI got it here The Esoteric Bookworm | A detail from the marble tombstone of grand prince...
Later
God Bless
dave
I have only recently begun to appreciate sacred geometry, im exploring it by making things out of copper and drawing. You are IMHO correct with regards to the sublimation of everything around us- the meanings have become muddied, but if you look into it- well let your creativity flow. Don't worry about the serpents, they can be calmed with frequency!LOL They are an good visual example of energy flow/movement- you must have read MrM's discoveries- depends on what you want to see
Well, if you want to provide self generating energy for the world then go for it, i would love to do this, but am yet not equipped with the traditional tools- i may get there another way.
I would like to see you make a giant fountain using the flower of life spiral. Then stand inside it and see what happens if you or i were to become the spindle, tap into our own capacitors and transformers.... lol
If anything i will have made you laugh!
S
Bowl shaped magnets
Another member posted this in http://www.energeticforum.com/renewa...tml#post224519
I thought it might also be appropriate in this thread.
The Primer Fields Part 1 - YouTube
If not, let me know and i will delete this post.Last edited by SlickDick; 02-13-2013, 05:08 PM.All the best,
Slick
