The electric field of a magnet
  • If we're running current into the body of a vehicle it would seem current runs well in iron
    • So voltage runs from neg to pos but amperage runs from pos to neg through a dc circuit.
      • But then again the high voltage spark is jumping to ground creating the spark
        very interesting
        • Are you sure that car ignition coil chassis is connected to HV terminal ????? !!!!!
            Thats what the schematic shows
            • Yep the femf from the secondary runs to ground and the bemf runs to the spark plug.
              HowStuffWorks "Inductor Basics"
              The reason for this strange behavior is the inductor. When current first starts flowing in the coil, the coil wants to build up a magnetic field. While the field is building, the coil inhibits the flow of current. Once the field is built, current can flow normally through the wire. When the switch gets opened, the magnetic field around the coil keeps current flowing in the coil until the field collapses. This current keeps the bulb lit for a period of time even though the switch is open. In other words, an inductor can store energy in its magnetic field, and an inductor tends to resist any change in the amount of current flowing through it.
              This is the femf it keeps the bulb lit after the power is turned off, the bemf is moving in the opposite direction so flys back to source.
              • Every coil produces a cw and ccw field around the coil, when it collapses one side moves on forward into the bulb in this case and the other returns as bemf.
                One side is amperage the other voltage.
                • The direction of current through the coil changes the polarity of the primary therefore it changes the polarity of the induced fields into the secondary.
                  Now you can see why we dont want to use an LC circuit to drive our system, or ac it does the same.
                  • This is too much fun
                    • ccw side still have to wind the cw side
                      black- primary
                      green- one side of shorted coil
                      red- secondary
                      • Everyone wants to use and lc circuit or tank circuit as it sometimes called and I can understand why, because it can be tuned to resonate but on one side the fields will be right vs the cw and ccw coils then when the poles flip the coils will be wrong so your only catching one side.
                        Its the direction of current through the coil that changes the polarity
                        • Awesome
                          Awsome site on post 1067. Thanks for that. looks like you have found the power of gifs.
                          Randy
                          _
                          • Lets think of a cw spinning particle running in a ccw coil what would happen?
                            It would leave the wire, have you noticed this in your Tesla coils?
                            Sure you have.
                            Think of riding a roller coaster that is spinning to the right but your in a tunnel that is twisting to the left, sparks are gonna fly.
                            • If you use a tank circuit to drive your primary use split tensor coils for your secondary's, Im not sure if a shorted coil could be added to this system what with the switching fields, maybe a double shorted coil just like the secondary tensor coil, a shorted coil acts as a flywheel.
                              Its all about the spin direction of the particle, your secondary has to be wound in the right direction or it will leave the wire.
                              • I rewound the ccw coil it was just too large.
                                13 windings, shorted coil starts after the seventh wind of the primary then the secondary this should put the shorted coil and the secondary well to one side of the bloch wall of the primary, so as to not catch any bemf, we only want femf in these coils.
                                Have ever notice that an odd number of magnets will not complete the loop but an even number will ;D
                                13 on each side will not loop but 26 all together will
                                There were 13 disciple's including Jesus.
                                They say the number 13 is unlucky because thats the date the templars were gathered up and killed, but lets look at who the templars were, they were the banking elite at that time.
                                The Bible says to stay away from usery, why because it makes you a slave to the bankers.
                                So the number 13 is unlucky for who.
