The electric field of a magnet
  • Dave45
    Tesla's Egg of Columbus - YouTube
    We know the magnetic flux is contained within the iron toroid so what field is turning the copper egg.
  • Dave45
    Hey Bob
    I havent built it or worked out the kinks but the idea is sound, Im going to build it soon, I believe it can be wound then twisted to give the wires an angle this will create a twisting vortex of aether funneled into a jet.
  • Bob Smith
    Dave,
    By BEMF, are you referring to radiant energy?
    I like where you're going, but my understanding is that in order to harvest the RE, you need a sharp voltage spike. The RE comes in from the aether between the spikes. You poke the aether, and the aether pushes back to restore balance to the disturbed system (to put it crudely).
    With this in mind, I would think you'd need something at the bottom of your funnel to facilitate a discharge to disturb the system - perhaps a discharging cap with a spark gap grounded at far side, or perhaps a reverse-wired self-oscillating relay switch.
    Maybe I've misunderstood you, but for what it's worth, you've got my interest.
    Have a good day.
    Bob
  • Dave45
  • Dave45
    Its so simple, it boggles the mind
    If the wire is wound at an angle we can give the field spin.
    Its just a magnetic funnel
  • Raphael37
    Dr. Peter Plichta who has studied chemistry, physics, and biology wrote that book.
    he is just like you Dave, he sees himself as doing the work of god, he even refers to himself as St. Peter.
    He recovered a prime number code that he calls the PRIME NUMBER CROSS
    image on the left
    Is it a coincidence his Prime Number Cross based on prime numbers is a good match for my prime number theory that suggest the Knights Templar Sator Rotas magic square is the treasure found in Solomon's Temple
    see the image above right
    You can read more about him here:
    And here:
    So I find it odd that King Dave-id wants to remain out of the loop?
    It appears St. Peter Plichta and the ARKangLE RaphaEL will need to do it alone ...
  • Dave45
    Got stuck in the house all day, hidden numbers within the Fibonacci sequence.
  • Dave45
    The more I think about it I believe this is the correct connection diagram
    In order to do this Im going to have to wind the ccw coils.
    Im not going to give up just yet
    later
    dave
  • kingsleyke
    What will happen. Maybe it can be used for metal detecting.
  • Raphael37
    Originally posted by truesearch View Post
    @Dave45:
    Your points about the eddy-currents / magnetic-field makes sense. It seems like you're on to a sound theory. Keep it up and keep us posted.
    And good luck with your "frau" ~ 1 Peter 3:7.
    truesearch
    sAIN'T I37 LIfE a baa baa son-of-a-bit*h?
    137 the Cosmic Code | Alternative Thinking 37
  • Dave45
    I wound it with some old wire just to put a magnetic field through it, nothing out of the ordinary, it may need the opposite wound coils.
    I'll keep playing with it,
    later
    dave
  • truesearch
    @Dave45:
    truesearch
  • Dave45
    We use layered cores to try and separate the eddy currents from the magnetic field, we are going about it wrong, we need to collect those eddy currents.
    In a motor the magnetic field expels the current carrying wires, it pushes the electrons in the wire out to the outer edge of the magnetic field and it does it with a strong force, this gives our motors torque.
    The magnetic field running in the welding rod should do the same pushing the eddy currents to the outer edge where it can be collected in the copper winding.
    Eddy currents cause heating in the core, if youv ever run current through iron wire you know it cant take much before it gets very warm, but the magnetic field loves iron, we have to give each a path, iron for the magnetic field line and copper for the eddy currents.
    It would seem the size of the welding rods would make a difference, the larger the iron rod the stronger the magnetic field would need to be and the same for a smaller diameter rod the smaller the field could be.
    I really need to order some wire or make the drive.
    Just need to convince the wife , she gets ticked about the money , we cant really blame em I guess, but we have to, we have an obligation in life to try and help others.
  • Dave45
    So we've been studying structure chasing down clues, does it have merit?
    One more confirmation and another piece of the puzzle
    Amazing Discovery With Magnets - YouTube
  • Raphael37
    @Ralf
    Bro you blow me away you first say Christians dropped the ball then you say I had better work with you and the swastika or go to hell.
    I am a Christian and the verses in Job:38 have led me to where I am.
    Yeshua gave His life on the cross for the redemption of our sins, in Him I believe.
    Yeshua leads me and no one else.
    dave
    sheepish ewe means this guy right?
    CLEARLY your SS meSSiah is a figment of your imagination put there by the powers that be?
    WHAT IS THE PATTERN?
    Do you see the similarity between jesus and the other idea called Chon-Ji?
    I need to constantly remind you that the dEvIL EWE and your tribe fears, LucIfEr the I37 Satan NEEDS an army of folks who have NO idea what they do....and Christians putting on NAZI uniforms defines a well ochestrated MOB that was ignited using bIbLE babEL!
    Why are you proud of your MOBSTER heritage?
    And nothing is a catalyst for inciting a riot like religious BS.
    Jesus is a copy KAt.
    And you should be proud that he is copying something divine.
    Yes king Dave-id jeSuS the SS meSSiah loves ewe.
    The cool KAt, the copy KAt called jesus is a swasti-KA effigy.
    there is far too much info being recovered that suggests jesus is a propaganda camPAIN designed to manipulate the heARTs and MiNds of 'we the sheeple'....
    PhDUH and when you ROTATE the CHON-JI 90 degrees into a N/S position it clearly depicts what jesus is conveying.
    PhDUH the CROSS/jesus is placed between TWO THIEVES called ...
    POSITIVE +
    and
    NEGATIVE -
    UR
    So king Dave-id can EWE see the difference between EAST and WEST how the story/narrative gets told and sold over and over and over and over and over again like a fu*cking fractal....that gets taken LITERALLY???
    jesus is a copy KAt cool KAt:
    selah V
    p.s. Maybe you have noticed by now that I AM telling it like it is on page 37 of this thread.
    37 | Search Results | Alternative Thinking 37
