The electric field of a magnet
  • Hey Shylo
    They say its the amps that create a larger magnetic field, you should make a vid on the floating bifilar too cool
    • I got my ccw coils wound for the structured core project and also built a cone shaped core for the vortex project, Im going to try and wind the cone core with a spiral Fibonacci curl we'll see
      I ran across some cool solar cooking
      Solar cooked Popcorn on a Parabolic - YouTube
      Parabolic Solar Cooker: Cantinawest's "Solar Burner"
      Different Fresnel Lenses, Different Capabilities - Different TVs - YouTube
      Solar Oven, Pot Roast with Potatoes, Onions and carrots. - YouTube
      The fresnel lens would make a cool steam boiler to run a Tesla turbine.
      • Resonant LCR Amazing Circuit 1. - YouTube
        Resonant LCR Amazing Circuit 2. - YouTube
        • magnets and coils mesh like gears
          • I really like the fresnel lens and the steam turbine idea, I passed up alot of large projection tv's in the past
            The solar cooker is cool too, especially for only 170 bucks
            • Hi Dave
              Just some thoughts that I hope will help the conversation along...
              The way I see it, if you were running voltage thru the wires, you'd have N and S all at the same ends of the outer wound rods, and N and S at the opposite end in the inner core. This seems to be what UFOPolitics was describing in his early videos. It seems to me that this would allow for an opposite pole attraction between the outer core ends and their opposite pole on the inner core - effectively creating a tubular vortex of magnetic energy flow thru the centre core?
              However, it you'e relying solely on the iron rods' ability to pick up the earth's magnetic field, I can see how you'd be using the wires to collect voltage (?) from the earth's magnetic field lines in the iron acting on the copper. My stumbling block comes with the fact that your field lines are going to be fairly constant, and I'd think you'd want some kind of fluctuation, either in the mag field lines or in the induced voltage picked up thru the copper wire.
              I can't help but consider the TPU discussions in light of this setup - do they have something to contribute to this? Would series wound bifilar coil windings with a cap for charge-discharge pumping/kicking action have a place in your arrangement? With 250,000 times the potential difference between winds in the swbf coil (versus the single-wound coil), you might have a chance of harvesting some useable voltage for kicking some aether butt and draw in some radiant energy. I dunno - just thought I'd throw it out there fwiw, recognizing that there's a lot more to your envisioning of this than I might be grasping.
              I love the Larskro vids. Is he saturating the cores? He's not doing it with a magnet, but perhaps with steel picking up the earth's mag field? Reminds me of the mag amp. The interesting thing here tho' is that he's got a voltage pulse from the transistor to work with and amplify by inserting the screwdriver or wire. My question is, how can you get a pulse in your setup? I think it's do-able with a cap and perhaps diode(s) (and perhaps series-wound bifi coils) to help things move in the right direction.
              Keep fighting the good fight!
              • The way I see it, if you were running voltage thru the wires, you'd have N and S all at the same ends of the outer wound rods, and N and S at the opposite end in the inner core. This seems to be what UFOPolitics was describing in his early videos. It seems to me that this would allow for an opposite pole attraction between the outer core ends and their opposite pole on the inner core - effectively creating a tubular vortex of magnetic energy flow thru the centre core?
                exactly, think of the planetary gears I refered to earlier in this thread, it works the same, if the very outer gear were turned what would happen............
                The reason I posted the Larskro vids is not the circuit but the principle, there's a magnetic field around the current carrying wire Larskro is taking advantage of this by giving the magnetic field something to run in, increasing this field increases the electric field in the copper.
                Now back to the planetary gear the outer gear is the same as the field running in Larskro's toroids.
                I know this is not the way things are done but Im not sure the system needs to be pulsed
                Study the planetary gear
                Im working on it, its gonna work
                • Thanks Dave. I see where you're coming from, and will chew on it awhile, play with it if time becomes available.
                  All the best.
                  Bob
                  • I was wondering about sizing the outer coils and the inner coil
                    The answers are all there
                    We know the shape of the magnetic field from the snowflake, it is formed in our planets magnetic field.
                    22 Hast thou entered into the treasures of the snow? or hast thou seen the treasures of the hail,
                    23 Which I have reserved against the time of trouble, against the day of battle and war?
                    All creation points to the Sabbath
                    Exodus 20:11
                    For in six days the Lord made heaven and earth, the sea, and all that in them is, and rested the seventh day: wherefore the Lord blessed the sabbath day, and hallowed it.
                    • How long does it need to be ?
                      • Hi Dave
                        How long --
                        I'm assuming you're questioning the length of the apparatus or wire. Your posting of fibonacci numbers higher up on the page might give a clue. I see you were an active player with Morpher44's Phi ratio postings on the Hubbard coil thread - might be worth going over again:
                        Another one of interest - I think you responded to this somewhere as well, but fwiw:
                        I wonder if the Lahkovsky coils might also have a clue.
                        Bob
                        • My thoughts as well Bob, just fishing for idea's
                          You mentioned the TPU earlier I truly believe the TPU is based on Tesla's egg of columbus the difference being there is a pickup coil in the center.
                          Steven said different frequencies could travel in a wire at the same time and he could read the five volts he used to pulse his system, this tells me he is pulsing through the system rather than an induction type device.
                          He also used the choke, if you have read up on the magamp alternating current cannot pass through a choke unless its biased with a dc field, I think this is what he was doing when he attached a magnet to the choke.
                          Iv thought alot about the TPU but have to follow my inspiration.
                          dave
                          • About Air Ions
                            About Electromagnetism
                            • How do AC ionizers work?
                              Answer: AC ionizer's work by applying an alternating high voltage to the tip of a sharp point producing an electrostatic field in the vicinity of the point. This electrostatic field is of sufficient strength to cause electrons to be stripped from the air molecules within the field. During the positive half of the AC cycle, the free electrons quickly attach to a nearby air molecule and are attracted toward the point while the resulting positive air molecule is repelled from the point. During the negative half the AC cycle, the effects are reversed. Positive ions are attracted to the point and negative ions are repelled.
                              • So what is bemf, and is there a positive bemf and a negative bemf
                                Is there a pos flowing current and a neg flowing current
                                If neg current is moving through an inductor will the collapsing field be pos
                                and if there is a pos current moving through an inductor will the collapsing field be neg.
                                If we have a battery and a light bulb (resistor) does energy move from negative through the resistor to positive or are both meeting at the light bulb combining, giving off heat and light?
                                inquiring minds want to know
