The electric field of a magnet
  • The magnetic permeability of the core material affects the efficiency of transformer and selecting the proper core material can enhance the total system efficiency. The following attached information may help
    • Great idea Martin I think banding strap should work. Sourcing material is a pain you can get it from China by the ton we dont make anything anymore.
      • wire will work as well and i think the banding comes with some oiling on it for rust but it is easy to lacqer with a spray can as well when winding a drop of superglue can help hold it in place as well
        this was what i was thinking of doing for simplicity.
        Martin
        • I think it would work for testing, money is tight this time of year, should be able to get some from the lumber yard, winding coils is gonna be a pain and slow, I wonder could it be threaded through bobbins.
          • now that might be the problem with banding material.
            i know i have see 3/4 square hole bobbins but can't remember were.
            Martin
            • I was mia for a couple of days,
              I decided to map the fields and this is what I came up with for a six sided magnet motor
              but I was thinking about the crystal radio that powers itself and the perpendicular coils that are a requirement for it to work, I was thinking how could we boost it, this is what I came up with
              notice the center coil the receiving coil
              • The perpendicular coils has me curious
                we know by looking at the alternator
                that when the magnetic field and the electric field are moved into the same plane we get extra energy
                so
                • I think these would have to be air cored coils, if we run the electric field in iron cores they will heat up, or I was thinking I have some hollow ferrite cores that would be interesting to try.
                  • Im going to continue to work on the transformer, but when money permits I am going to build this
                    there is free energy here.
                    • All coils bifilar powered by ac one leg one filar the other leg the other filar, center coil pickup coil. coil diameter and cross section sized according to phi
                      • Walter Ford�s High-powered Crystal Set
                        In the 1961 edition of the Electronics Experimenter�s Handbook, there is an interesting circuit from Walter B. Ford for a high-power crystal set capable of powering a 2.5-inch loudspeaker:
                        He says: Here�s a pint-sized crystal radio with enough power to drive a 2.5� speaker. This little unit's selectivity is far better than you would expect to find in a crystal re�ceiver and volume is equal to that obtained with sets using a transistor. No external power source is required.
                        The unusual selectivity of this radio is due to its special double-tuned circuit. A pair of diodes connected as a voltage-doubler provides the extra power to operate the small speaker. An output jack is provided for headphone listening and for connecting the set to an amplifier.
                        Construction: The model was built on a 2.5� x 4.5" wooden chassis with a 3.5" x 4.5� metal front panel. However, size is not critical, and other materials can be substi�tuted if desired.
                        Two standard ferrite loopsticks, L2 and L3, are used. Both must be modified by the addition of a second winding. L1 and L4, respectively. Each of the added windings consists of 22 turns of No. 24 cotton-covered wire wound on a small cardboard tube as shown in the picture. (Actually, any wire size from No. 22 to No. 28 with cotton or enamel insulation will do the job).
                        The diameter of the cardboard tube should be slightly larger than L2 and L3 so that L1 and L4 will slip overL2 and L3 easily.
                        Resistor R1 is used only for feeding the set into an amplifier; it should be omitted for both earphone and loudspeaker opera�tion. Trimmer capacitor C2 should be sol�dered across the stator terminals of two-gang variable capacitor C1a/C1b as shown. The speaker and output transformer can be mounted wherever convenient.
                        If a metal chassis is used, then be sure to insulate the aerial and earth connection sockets from the chassis. When all of the parts have been mounted on the chassis, wire them together follow�ing the schematic and pictorial diagrams. Be sure that diodes D1 and D2 and capaci�tors C3 and C4 are connected correctly, paying attention to their polarity.
                        While this is interesting, what appears to be a key factor is contained in the drawings, where he states that the only important thing is that it is essential for the two sets of coils to be mounted perpendicular to each other:
                        we need to take this principle and run with it
                        • this is some mighty inspiration.....as far as i can tell, you have the fractal shape correct
                          and perpendicular coils are nothing more than vertical vs horizontal...two opposites
                          or if you prefer 6 vs 9
                          Signs and symbols -Confucius.
                          • This blew my mind when I started mapping it, its a sink, this is it,just have to build it and figure out how to power it.
                            • with a No external power source crystal radio ...maybe
                              • Iv been thinking about the transformer, if we think about the transformer as a pump and the magnetic field as the housing, if we open it up we may lose instead of gain, this is why Tesla never got in a hurry to build something, he thought about it for sometimes years.
                                If we pulsed the pmh coils with dc voltage we may boost the system but the timing would have to be perfect, or maybe put a cap in the pmh coils
                                Im going to study this awhile, there can probably be gain here if constructed right, but I want a system that produces so much gain that there's no question and we will find it.
