A number of people have suggested that you can mix a low voltage high current source and a high voltage low current source to multiply the power available in a circuit. I built a circuit using an SCR with a 12 volt charged cap (25 uF ceramic) and a 600 volt charged cap (100 pF ceramic) and dumped them both through the SCR into a battery at a 40 Hz repetition rate. This should combine a low voltage, higher amp source (25 uF cap) with a high voltage low current source (100 pF) cap.
In order to prevent latchup on the SCR I'm limited on how large a capacitor I can use. In addition, I wanted to use non-electrolytic caps since electrolytics are not that good with quick discharges.
A nickel metal hydride battery didn't increase much when connected (1.280 to 1.284), yet an alkaline battery jumped from 1.440 to 1.484. Not overly impressive, but it's what I've seen so far with the setup. I'm playing around with charging the alkaline longer to see if it increases and holds the charge.
Any thoughts on experiments with this kind of setup?
