Resonance @ 60 Hz
I can't get my 3.5" can to resonate today. I had it resonating like crazy yesterday and then tried some other cans. I can't seem to get my hanging nail located in the right place to ring against the can. It's getting frustrating.
Ask Mr "C"
Can you describe how you have done it before?
Does the nail hang in Front[of opening] ,you say it Touches??
IMNSHO once the can is resonating it will "Transmit" a wave out the front
which should ring a hanging nail at a specific distance [focus]from the opening?
You see I feel the Nail could also be an optimal size [tune]?
Perhaps someone can offer an opinion here?
Or ask mr."C' [contact]
ChetIf you want to Change the world
BE that change !!
Position of Nail
The contact was not specific when I asked him several time, so I started experimenting on my own. I could only get the can to ring when the nail was placed against the inside edge of the can. I have my nail suspended from the ceiling via nylon fish line. The nail didn't work for me, so I replaced the nail with a small solid detachable phillips screwdriver head. It works much better for me than the nail did. I position the screwdriver head about a quarter of an inch down from the top opening on the inside of the can. I have the can pushed up against the screwdriver head. When I blasted the can yesterday from two different sides simultaneously, it resonated well. Today, I can't get the can to resonate and I've messed with it for over an hour and something.
I have several questions in to my contact but haven't heard from him since yesterday.
Originally posted by RAMSET View PostCan you describe how you have done it before?
Chet
Trued Up
The edge of the can is very important too. I found that once I had cut the can, I had to make sure the edge of the can was trued up and smoothed out. When you use tin snips to cut the can, it leaves a rigid edge which needs to be smoothed out so it will resonate. You do need to take care not to deform the can edge while trying to smooth it out. I've screwed up several cans so far. That thin aluminum is a pain to work with.
shhnazzy cup you have there Core
Very nice!!
I see you are going for a truer replication on "Davey" ! [ as you said]
Perhaps the Tuning will be similar to the Cans? I'm hoping the can will be easier to tune?
My take on the "Tune"
If you look at parabolic antennae/transmitter and the placement of the "Driver"
[out front] there is a given distance[from the front] that the "focus" takes place!
I think the nail needs to hang/work at this focus point ?do we have any antenna men here?
Chet
PS
Mr.S can you post a pic of your tuning rig?? You say you hang the nail "inside" from the ceiling?is the can vertical ?If you want to Change the world
BE that change !!
felt under can?
Is the can floating [HHMMM just had a thought]
I mean do you have it Hard to the ground or is a piece of "soft"[felt or??] underneath?
Thanks for the pix most helpful!!
Chet
Ps
I like you have the nail Inside[speakers can't shake the nail directly] ,IMO super lightweight brittle and straight wire would work better? [I suspect]
I have asked EM at the other forum [O.U.R.] for tuning suggestions using the nail and the can/cupIf you want to Change the world
BE that change !!
Surface Under Can Scenario
My can is on a raised hard surface to allow for proper allignment of the nail, but I don't have felt and/or any other insulator material in use between the can and the hard surface.
I have felt available. I'll try utilizing it and see what happens.
Great Idea!!
Originally posted by RAMSET View PostIs the can floating [HHMMM just had a thought]
Chet
Ps
Tuning Anodized Aluminum with Alternating Electromagnetic Fields
I stumbled onto this site today:
Nikola Tesla Plates and Tuning Anodized Aluminum with Alternating Electromagnetic Fields | Helpfulwaves.com
And it actually makes sense (to me )Originally posted by Slovenia View PostI stumbled onto this site today:
COHERENCE AT ANY LEVEL IS COHERENCE AT AL LEVELS. (same for INCOHERENCE)
An orderly arrangement between wave lengths establishes a connection between frequencies and fields. But for this connection to last, it must resonate to all frequencies and fields. This can only be accomplished through the resonate structure of golden mean pathways. This harmonic cascade of inter-connected-ness is the structure of our hologramic universeSigns and symbols -Confucius.
