So you want a free energy device, yes? so do I.
If we are serious about this we have to take every aspect of a system into consideration and the first is how to make the best use of the power we put in. I will talk here about an electromechanical system ie a motor/generator or Lockridge type device.
We know a motor has losses and the mechanical losses are friction so it goes without saying that we want low friction bearings, slip rings and commutators. Other losses include resistance (not to be mistaken for impedance) eddy currents etc and for the purpose of this thread we are going to stick to basics and look mainly at resistance.
Resistance in a system converts electrical current into heat and is a direct loss so again this has to be kept to a minimum ie very low.
Now lets get to the more interesting stuff. Induction coils are very good at storing a limited amount of energy and at the same time producing a magnetic field. as we put current into a coil this energy is stored and a magnetic field builds up and when the current is switched off the magnetic field collapses and a new current is induced into the wire and this is what we know as inductive kickback.
The object here is to collect this current and use it to partially power the next pulse therefore saving a significant amount of power. This is very simple to do and the interesting thing is we can store it at a higher voltage than the source, allowing us to use this stored energy before we use our source battery. See the attached circuits.
In the first circuit we are feeding the energy back into the motor. the graphs show current from the source pulsed at a 32% duty cycle and current through the coils. Note that there is always current going through the coil. The the voltage is 12v so we can calculate the power. you will note that the power in the coil is double that of the pulse. This only happens with pulsed coils and we have to pulse them very fast to get the effect.
In the second circuit we charge a capacitor, with the inductive kickback, to double the voltage of the input. The two graphs tell the same story double the power in the motor of the pulse we put in.
So if we build a motor that is 70% efficient and run it on 100w (300w pulses) and we will have 140w mechanical output. All we have to do now is put a generator on the output and feed it back to the source but as most generators are around 70% efficient these losses will leave us with only 98w. So to produce a self running system we need to use a more efficient motor and more efficient generator and then we have an excess of power.
Its not quite as simple as that because of the factors that I have not gone into but the process is that simple.
so I thought I would start the regenerative thread to try and get peoples understanding of my work. So any ideas you have on that subject would be better placed on that thread.
