3D electromagnetic field
  • #31
    Probably that help your mind to understand ... all is based on electrons and electrons are the key
    Thank you tutanka , for the image but you forgot one thing in it , the rotary motion of the electron itself (spin if you prefer )
    • #32
      Hello , that is vortex motion of electrons inside e-beam reactor
      • #33
        Antiphase
        To create the 3rd dimensional field you have to create an ANTIPHASE in your coils in the case of for example the Muller motor/generator. Your electromagnets are wound from the center of your ferrite rod, two wires connected but wound in opposite directions and terminating at each end.
        This will create the 3rd field which is a vortex field and NOTHING ELSE, from this you can design your motor/generator. You will have zero Lenze effect and will only draw current for the driving circuit alone. It is ALL in winding the coils in ANTIPHASE to create a unique vortex field, I will leave the rest of the design of the motor/generator up to you, I will probably get shot for what I have told you.
        Mike
        • #34
          Mike
          Mike, let me ask you this, being new to 3d electromagnetic theory, what is the link between Antiphase and Caduceus coil
          thank you again for your invaluable input
          • #35
            As I have not done anything with a Caduceus coil, I can't say, I will look into it.
            Mike
            • #36
              Mike
              What is your suggestion on how to exactly catch any usable energy from the antiphase situation?
              Where do you see that realized in the Muller motor?
              My antiphase experiments so far have not shown a way.
              Also others that have built bucking coil Mullers have not seen anything unusual. There must be a bit more to it to "catch" it.
              • #37
                xenomorph, Isn't what Mike is suggesting different than bucking coils. When I think of bucking coils with the Muller gen I think of one coil on top being wound one way and the one on the bottom below the magnet being wound the other way. But I don't think that is what Mike is suggesting here. Rather it sounds like two sets of wires on one coil with one wound CW and one CCW and the start ends hooked together as one connection point while the ending wires hooked together as the other connection point with everything wound on the same core. I envision this as being a bit time consuming to wind and am not totally clear on how would be best to do this but it sounds possible and once I get it clear I'll give it a try.
                Does what I describe here sound correct Mike?
                • #38
                  antimatter and black hole
                  To the end Mike have found the way for create anti-matter and after an black hole OK.. sorry but an good italian espression ask "altro giro altra corsa" .. in other words .. You can never finish a thing, and if it starts another Good Night
                  • #39
                    xenomorph,
                    Currently, I see 2 ways that such a coil could be wound, as I don't understand what Mike means exactly in his description.
                    I get that we have to start the wind with 2 wires, at the center of the core, and wind both wires in opposite direction from each other.
                    If we think about that for a second, this is exactly the same thing as a standard coil that has a center tap added.
                    I wonder if the "center tap" is then used in the connections to the external circuit, or if we have to use only the 2 outer wires...
                    The other way would be:
                    Wind bifilar, starting from the center of the core, each strand going out away from center.
                    Mechanically, this would be called "same direction", but electrically (if the center tap is not used) the wires would be in opposite direction, creating the vortex.
                    So which one is it ?
                    Altair
                    • #40
                      Well there is for sure something about bucking coils or whatever you wanna call them. They are found in pretty much every OU system that can be considered "the real deal". But all of them include high voltage pulsing the coils not like magnets pulsing them.
                      Until i haven't experimentally replicated the pdf posted by Mike in the exact way as it describes, it is not possible to draw a conclusion.
                      I believe there is something to it, i feel it rather hehe.
                      • #41
                        check the Caduceus coil out
                        • #42
                          I would suggest starting at the webpage Mike shared:
                          and work from their designs to make sure you've got a working model. They have an antenna that specifically produces just the vortex field or whatever you want to call it. Build that antenna first and make sure you can broadcast between units without picking the signal up on a standard antenna. Then try small changes to the antenna to see if you can keep it working or improve its function. On the webpage, they refer to it as a Hz antenna with a cylinder of conductive (non-ferromagnetic material) and two coils wound on the top and bottom of the cylinder. This supposedly produces the "special" field.
                          • #43
                            This is my caduceus pickup coil ...
                            ‪Mk1 Pickup Winding .‬‏ - YouTube
                            • #44
                              facts not only words..
                              Attached pdf about electron movement with mathematical formulas.. the words are nothing if don't are based on true researches
                              • #45
                                Caduceus coil = Tesla coil
                                Nothing of new...
