3D electromagnetic field
  • 3D electromagnetic field
    Hi All,
    One of my most admirable scientists of today who does not worry about rubbing up a few people in the wrong way, is V.I.Korobejnikov.
    His theories which have been supported both by events and in practice are one of the futures in our strive for a clean energy. His 3D electromagnetic field is one of the systems that I use and has been put into practice.
    I am going to share this with you so that just maybe a new insight into electromagnetic waves will inspire some of you to view what has been seen as anomilies in certain threads in this and other forums, and start designing to create what many think is impossible.
    First I want to show you a very disturbing fact:-
    On the anomalous secular increase of the eccentricity of the orbit of the Moon
    Lorenzo Iorio
    (Submitted on 1 Feb 2011 (v1), last revised 21 Feb 2011 (this version, v3))
    A recent analysis of a Lunar Laser Ranging (LLR) data record spanning 38.7 yr revealed an anomalous increase of the eccentricity of the lunar orbit amounting to de/dt_meas = (9 +/- 3) 10^-12 yr^-1. The present-day models of the dissipative phenomena occurring in the interiors of both the Earth and the Moon are not able to explain it. We examine several dynamical effects, not modeled in the data analysis, in the framework of long-range modified models of gravity and of the standard Newtonian/Einsteinian paradigm. It turns out that none of them can accommodate de/dt_meas. Many of them do not even induce long-term changes in e; other models do, instead, yield such an effect, but the resulting magnitudes are in disagreement with de/dt_meas. In particular, the general relativistic gravitomagnetic acceleration of the Moon due to the Earth's angular momentum has the right order of magnitude, but the resulting Lense-Thirring secular effect for the eccentricity vanishes. A potentially viable Newtonian candidate would be a trans-Plutonian massive object (Planet X/Nemesis/Tyche) since it, actually, would affect e with a non-vanishing long-term variation. On the other hand, the values for the physical and orbital parameters of such a hypothetical body required to obtain the right order of magnitude for de/dt are completely unrealistic. Moreover, they are in neat disagreement with both the most recent theoretical scenarios envisaging the existence of a distant, planetary-sized body and with the model-independent constraints on them dynamically inferred from planetary motions. Thus, the issue of finding a satisfactorily explanation for the anomalous behavior of the Moon's eccentricity remains open.
    This goes along with a paper by V.I.Korobejnikov which changes totally the concept of gravity, which can be found on the web.
    As far as the above and the Moon, I would prefer someone take this on and make a new thread so as I can keep this for 3D electromagnetic fields and how they are created and how they can be used to create a new form of energy generation.
    Over the last couple of years I have given hints to this and with very little interest it seems, this even enters the work of Dr. Stiffler, though he might disagree and so we will probably agree to disagree and that is fine with me.
    I stated that the theories of V.I.Korobejnikov have been put into practice, well yes in a system of RF, oh yes RF has come up again, electromagnetic waves. A company EH Antenna systems have been working along with Korobejnikov to make an antenna to use a 3D electromagnetic wave which has some very unusual effects. Please read the paper here:-
    This domain name is available, own it today. Affordable payment options. Fast and professional service.
    In fact please read all of their site as it will give you an insite to all of this better than I can and it will save me a lot of typing
    From time to time I will post here more on this subject as my time becomes available, which is a bit thin on the ground at the moment with all of my projects taking priority.
    Enjoy and learn, things or lights will start lighting, pun intended
    Mike
    Thank you for the info
    Signs and symbols -Confucius.
      You are welcome, please make use of it
      Mike
        I just had a quick look ...I read about it before here
        Robert T. HART
        EH Antenna
        Robert hart -- EH Antenna
        will definitely look into it
          Meg
          EH antenna.
          That drawing reminds me of Bearden's MEG.
          Mark
            I see a similarity to Ezekiels wheel. It was just a communication device.
            The coils would be at the intersects.
            There is a radiant like description of it. It was turned off at ground level.
            You dont see many people working on a 2 toroidal coil configuration like this.
            ‪Magnetic field in a toroidal coil‬‏ - YouTube
              @Iotayodi
              Check antigraviticsystems1 post:
                Mike
                As you see from my motto " "You cannot invent, you can only discover" -
                from this and the fact (a personal belief) that the Universe is fractal, this revolutionary discovery exist in nature at different scale....
                ...and you can tap into it.....this deserves some serious pondering...
                Thank you Michael for this precious info
                  Thanks for the link MonsieurM.
                    Mike,
                    This appears to explain aspects of what I've been working on. I've been using pulsed coils to produce magnetic fields for healing. I initially assumed the strongest effects would come from the ends of the coil. Based on reading the link you provided, I surmised that it might actually be a magnetic field with infinite wavelength as described on the website, so the actual beneficial field is radiating off the sides of the coil. After some simple experiments, that seems to be the case. I'm really excited about designing further experiments to test out these concepts.
                    Thanks!!!!
                      Have you guys come across
                      Maurice HATELY // Fathi KABBARY
                      Crossed Field Antenna
                      Maurice Hately, Fathi Kabbary, X-Field Antenna,US Patent 5,155,495
                      looks like it is using the same principle
                        Robert T. HART
                        EH Antenna
                        If Mike have open and posted that pdf is because want help peoples to understand. But the main problem is that peoplecan't see inside Mike mind and for that reason is very difficult understand.. Simply Mike using that method solve some problems that surely have with old RF reactor.
                        Using that method you can process your water molecules in the middle of EM field and obtain in output your gas , that semplify previously method but my question is you obtain an high efficiency >90% during the reaction?
                        Im not sure of that because during my test the variable of time inside process is very important.
                          From Mike's pdf doc:
                          Let us concentrate our attention on the simplest question: That will be, does an electric charge (electron) rotate? Such rotary dynamics of an electric charge (electron) will somehow be reflected in an electromagnetic field of this charge in space.
                          • #14
                            you reminded me of
                            Felix Ehrenhaft: Magnetic Current --- 9 articles
                            Can a magnet take water to pieces?
                            pay attention to his set up and compare to the set up of the EH Antenna
                            For his "impossible" experiment, Dr Ehrenhaft employs the simplest of apparatus. Two shiny rods of pure Swedish iron, sealed in holes through opposite sides of a U-shaped tube, resemble a setup familiar to high-school students for breaking up water into hydrogen and oxygen gases by passing electricity through it. And that is exactly what would happen if Dr Ehrenhaft attached electric wires from a battery to the rods. But, he does no such thing.
                            • #15
                              i'm currently reading Maxwell in 3d and it comforts my views on the fractal Universe, and some of the posts i made in various threads
                              A charged particle (mass - charge) is surrounded with an electromagnetic field making it complete. This applies to any body having mass and an electric charge (mass - charge). Generally, when there are charges moving in time or moving on a contour with a current in space surrounding them, there is a variable electromagnetic field. If these processes are periodic, the variable electromagnetic field will be a wave. [1] [2] [3]. All this applies to the full concerns and to such enormous concentrated mass, possessing electric charges (mass - charge), with the periodic law of movement, as planets, stars, galaxies. Much to our regret, lengths of electromagnetic waves (frequency) of such heavenly bodies are not reflected yet on a scale in directories and textbooks. Now practical frequencies are lower than 1 Hertz by 5-6 orders of magnitude and more (105106the hertz and is lower). These have been considered as constant electric current or in the general category of "static", but that basically is not true.
                              All this demands we consider any physical processes as occurring in an external electromagnetic field....
                              ...in the universe there is no motionless point, and uniform, rectilinear movement in the pure state does not exist.
                              ‪Solar system new interpretation‬‏ - YouTube
