  • Originally posted by StweenyA View Post
    Wow!!! Just trying to keep up here...
    StweenyA ........ welcome back ...... good reading you again
    an old version of the previous posts
    Signs and symbols -Confucius.
    • Fibonacci quasicrystal - Wikipedia, the free encyclopedia
      A Fibonacci crystal or quasicrystal is a model used to study systems with aperiodic structure. Both names are acceptable as a 'Fibonacci crystal' denotes a quasicrystal and a 'Fibonacci' quasicrystal is a specific type of quasicrystal. Fibonacci 'chains' or 'lattices' are other synonyms used with regard to the dimensionality of the model.[1] While it is used mostly as a theoretical construct, physical models are also implemented for empirical checks. Most of its applications pertain to various areas of solid state physics.
      Quasicrystal - Wikipedia, the free encyclopedia
      Two-dimensional aperiodic tiling based on the Fibonnacci word
      The mathematical properties of the Fibonacci word and related topics are well researched and readily applied in such studies. The elements of a Fibonacci crystal structure are arranged in one or more spatial dimensions according to the sequence given by the Fibonacci word. The Fourier transform of such arrangements consists of discrete values, which is the defining property for crystals. In an algebric form the sequence is expressed with a matrix whose eigenvalues are Pisot numbers. This feature guarantees that its Fourier transform is discrete. Material waves with appropriate length would interfere constructively when interacting with a Fibonacci structured physical system. For instance, when submitted to X-rays, a Fibonacci quasicrystal would produce Bragg peaks. Other features describing media behaviour such as damping, transmitivity, etc. can be evidenced on Fibonacci models.[2]
      The Fibonacci-based constructions are an obvious example of quasicrystals that do not possess a 'forbidden symmetry'. Their diffraction pattern would be of a square type with the intensities arranged in a fractal pattern.[3]
      CCC Sacred Geometry Page 2
      Various patterns of standing waves on fluid surfaces generated by vibrating the containing vessels with various driving frequencies, producing A: hexagonal, B: rectangular lattice, C: quasi-crystal patterns, among many more. D: This pattern is defined more by the shape of the walls of the container rather than by the driving waveform, showing how interference patterns in the resonating system tend to subdivide the resonating system into periodic and symmetric sub-patterns in an essentially Gestalt manner.
      Harmonic Resonance Theory: An Alternative to the "Neuron Doctrine" Paradigm of Neurocomputation to Address Gestalt Properties of Perception
      note picture C
      ready .......
      Evolution inspires more efficient solar cell design: Geometric pattern maximizes time light is trapped in solar cell
      new design for organic solar cells that could lead to more efficient, less expensive solar powerthe researchers sought to design the geometric pattern of the scattering layer to maximize the amount of time light remained trapped within the cell.
      Read more at:
      6 Harmonic Resonance Theory
      The properties of perception as observed phenomenally and as described by Gestalt theory are truly baffling when it comes to proposing a computational mechanism to account for those properties. However there is one physical phenomenon that exhibits exactly those baffling properties observed in perception, and that is the phenomenon of harmonic resonance, or the representation of spatial structure expressed as patterns of standing waves in a resonating system (Lehar 2003a, Lehar 2003c). This tantalizing similarity cannot be coincidental, considering that no other physical mechanism or phenomenon has ever been identified that exhibits these same enigmatic properties. The most remarkable property of harmonic resonance is the sheer number of different unique patterns that can be obtained in even the simplest resonating system. A pioneering study of more complex standing wave patterns was presented by Chladni (1787) who demonstrated the resonant patterns produced by a vibrating steel plate. The technique introduced by Chladni was to sprinkle sand on top of the plate, and then to set the plate into vibration by bowing with a violin bow. The vibration of the plate causes the sand to dance about randomly except at the nodes of vibration where the sand accumulates, thereby revealing the spatial pattern of nodes. This technique was refined by Waller (1961) using a piece of dry ice pressed against the plate, where the escaping gas due to the sublimation of the ice sets the plate into resonance, resulting in a high pitched squeal as the plate vibrates. Figure 1 (adapted from Waller 1961 P. 69) shows some of the patterns that can be obtained by vibrating a square steel plate clamped at its midpoint. The lines in the figure represent the patterns of nodes obtained by vibration at various harmonic modes of the plate, each node forming the boundary between portions of the plate moving in opposite directions, i.e. during the first half-cycle, alternate segments deflect upwards while neighboring segments deflect downwards, and these motions reverse during the second half-cycle of the oscillation. The different patterns seen in Figure 1 can be obtained by touching the plate at a selected point while bowing at the periphery of the plate, which forms a node of oscillation at the damped location, as well as at the clamped center point of the plate. The plate emits an acoustical tone when bowed in this manner, and each of the patterns shown in figure 1 corresponds to a unique temporal frequency, or musical pitch, the lowest tones being produced by the patterns with fewer large segments shown at the upper-left of figure 1, while higher tones are produced by the higher harmonics depicted towards the lower right in the figure. The higher harmonics represent higher energies of vibration, and are achieved by damping closer to the central clamp point, as well as by more vigorous bowing. There are many more possible patterns in a square plate than those depicted in figure 1, which would be revealed by suspending the plate without clamping, allowing patterns which do not happen to exhibit a node at the center of the square, and of course there are many more patterns possible in plates of different shapes (Waller 1961), and many more still in volumetric resonant systems such as a vibrating cube or sphere, which define three-dimensional subdivisions of the resonating volume, although these have not received much attention due to the difficulty in observing the standing wave patterns within a solid volume or volumetric resonant cavity. Faraday (1831) extended Chladni's phenomenon by observing standing waves on the surface of liquids, which produces geometrical arrays of standing waves on the surface of the fluid in the form of concentric rings, parallel ridges, grid and checkerboard patterns, arrays of cone-like points, and even brick patterns. This work has been extended more recently by Cristiansen et al (1992), Kumar & Bajaj (1995), Kudrolli & Gollub (1996), Kudrolli et al. (1998) and others, who have demonstrated patterns of equilateral triangles, regular hexagons, superlattice, and quasi-crystal array patterns by driving the oscillation of the fluid layer with a controlled waveform. Figure 2 shows some of the patterns produced by Kudrolli et al. It seems that this work is only touching the surface of the full potential of this phenomenon for producing complex geometrical patterns by relatively simple driving oscillations.
      • Giant veil of “cold plasma” discovered high above Earth | The Extinction Protocol: 2012 and beyond
        • thank you Dave
          could also explain some of the UFO sightings viewed from Space : Plasma filament behaving in peculiar manner
          • a fractal construct has an 'efficient function', it has a fractal ergonomy to them, they function on multiple levels and in multiple dimensions:
            New 'retention model' explains enigmatic ribbon at edge of solar system
            (Phys.org) It emits no light and no conventional telescope can see it. However, particles from inside the solar system bounce off this boundary and neutral atoms from that collision stream inward. Those particles can be observed by instruments on NASA's Interstellar Boundary Explorer (IBEX). Since those atoms act as fingerprints for the boundary from which they came, IBEX can map that boundary in a way never before done. In 2009, IBEX saw something in that map that no one could explain: a vast ribbon dancing across this boundary that produced many more energetic neutral atoms than the surrounding areas.
            Read more at:
            In a paper published in the Astrophysical Journal, researchers propose a "retention theory" that for the first time explains the key observation of the unexplained ribbon's width. The paper appeared online on Feb. 4, 2013. Indeed, since the discovery of the ribbon, over a dozen competing theories seeking to explain the phenomenon have been put forth. The new theory builds on one that was first published along with the discovery of the ribbon in 2009 and then quantitatively simulated in 2010. This theory posited that the ribbon exists in a special location where neutral hydrogen atoms from the solar wind cross the local galactic magnetic field. Neutral atoms are not affected by magnetic fields, but when their electrons get stripped away they become charged ions and begin to gyrate rapidly around magnetic field lines. This process frequently aims ions back toward the sun. So those ions that pick up electrons at the right time might explain the extra boost of neutral atoms that create the ribbon. The problems were that physical processes might break down the distribution needed for it to work and that models based on this process showed a ribbon narrower than IBEX observed.
            Read more at:
            The new theory adds a key process: That rapid rotation creates waves or vibrations in the magnetic field, and the charged ions then become physically trapped in a region by these waves, which in turn would amplify the ion density and produce the broader ribbon seen. Read more at
            • from: http://www.energeticforum.com/renewa...ations-18.html
              the shape of the coil looks almost "egg like" https://www.youtube.com/watch?featur...&v=NJ7saXwMYUU
              also considered a favorable aerodynamic shape
              The inventions, researches and writings of Nikola Tesla, with special reference to his work in polyphase currents and high potential lighting
              on a side note ..... you can print the above image and place pegs to create an egg like coil ( basket weave or not )
              • Wireless power transfer technology for high capacity transit
                The Korea Advanced Institute of Science and Technology (KAIST) and the Korea Railroad Research Institute (KRRI) have developed a wireless power transfer technology that can be applied to high capacity transportation systems such as railways, harbor freight, and airport transportation and logistics. The technology supplies 60 kHz and 180 kW of power remotely to transport vehicles at a stable, constant rate.
                Read more at:
                where did read this before :
                • I finnaly get it!
                  Hi.
                  What do you think about this schematic?
                  If the breakdown avalanche effect of the diode is big enough we could have some interesting results
                  kEhYo
                  • Originally posted by kEhYo77 View Post
                    Hi.
                    kEhYo
                    Is this to collect through the antenna
                    Could you give more detail, explain your idea.
                    dave
                      Hi.
                      kEhYo
                      good reading you kEhYo77
                      first a reminder of what is the breakdown avalanche effect
                      Avalanche breakdown
                      From Wikipedia, the free encyclopedia
                      Jump to: navigation, search
                      Avalanche breakdown is a phenomenon that can occur in both insulating and semiconducting materials. It is a form of electric current multiplication that can allow very large currents within materials which are otherwise good insulators. It is a type of electron avalanche. The avalanche process occurs when the carriers in the transition region are accelerated by the electric field to energies sufficient to free electron-hole pairs via collisions with bound electrons.
                      [edit]
                      Explanation
                      Materials conduct electricity if they contain mobile charge carriers. There are two types of charge carrier in a semiconductor: free electrons and electron holes. A fixed electron in a reverse-biased diode may break free due to its thermal energy, creating an electron-hole pair. If there is a voltage gradient in the semiconductor, the electron will move towards the positive voltage while the hole will "move" towards the negative voltage. Most of the time, the electron and hole will just move to opposite ends of the crystal and stop. Under the right circumstances, however, (i.e. when the voltage is high enough) the free electron may move fast enough to knock other electrons free, creating more free-electron-hole pairs (i.e. more charge carriers), increasing the current. Fast-"moving" holes may also result in more electron-hole pairs being formed. In a fraction of a nanosecond, the whole crystal begins to conduct.
                      Avalanche breakdown usually destroys regular diodes, but avalanche diodes are designed to break down this way at low voltages and can survive the reverse current.
                      The voltage at which the breakdown occurs is called the breakdown voltage. There is a hysteresis effect; once avalanche breakdown has occurred, the material will continue to conduct if the voltage across it drops below the breakdown voltage. This is different from a Zener diode, which will stop conducting once the reverse voltage drops below the breakdown voltage.
                      When both sides of the pn junction (called a depletion layer) which is lightly doped become large enough avalanche breakdown takes place.
                      indeed it could prove to have some very interesting effect ....
                      just on a side note : as we have discussed several times the use of Bismuth in free energy devices ( Hall effect Battery , Moe Joe Cell etc .... ) :
                      Bismuth-Ferrite Piezoelectric Material Opens New Roads for Energy Generation - The Green Optimistic
                        dave
                        It is to be used as a few turn primary for a Tesla Coil (transformer).
                        Having seen Primer Fields on YT, it is my belief that this PHI ratio clockwise / counter clockwise / clockwise type of primary winding will by very efficient.
                        @MonsieurM
                        I purchased recently some 99.9 pure Bismuth and the plan is to make a thick primary from copper pipes with ferrofluid inside and cover it with a thin layer of Bismuth from the outside.
                        And the final (Bismuth covering) layer should be of an insulating material.
                          @MonsieurM
                          can't wait to hear the results of your experiment
                          the following sentence caught my attention :
                          for some reason it reminded me of experiment with a quartz crystal and a spark gap
                          electroluminescence or just a chunk of quartz in a spark gap ? - YouTube
                          Triboluminescence or electroluminescence or just a chunk of quartz in a spark gap i dont know i cant decide makes for really powerfull discharges from a low wattage source though. mabe its the piezoelectric effect or just added capacitance. its milky quartz by the way
                          • forgot to mention an essential piece of info ....... that may prove essential ( all is connected ):
                            key word : Orgone :
                            Cloudbusting
                            Reich made an analogy between a lightning rods and cloudbusters: both discharge orgone from the sky (lightning was believed to be a super-dense bolt of electricity and orgone), except whereas a lightning rod does so in the fraction of a second, the cloudbuster extends its influence over tens of minutes -- an hour is the usual draw duration. Though lightning rods channel much greater magnitudes of energy than cloudbusters, it is not difficult to see why a cloudbuster produces a more apparent change in shape of a cloud than lightning rods do. It is not the magnitude of energy involved, but rather the rate of energy flow. With the cloudbuster's slower rate of orgone siphoning, the chaotically evolving cloud has a longer time to respond to the influence of a cloudbuster operator.
                            The rate of draw is dependent upon rate of water flow within the pipe, number of pipes, and the skill at which the cloudbuster is operated. The length-to-diameter ratio determines the range of influence of the cloudbuster;
                            from: http://www.energeticforum.com/renewa...tml#post223674
                            https://www.youtube.com/watch?v=e7nFga2BpGU ..... you won't have to go into high rpm as in the vid
                            or more like this one :
                            Tesla turbine powered by water - YouTube
                            side note : All of Tesla's work is scalable ..... all you need is
                            copper tube / fittings for the casing ..... and some small magnet rings .... and you can do the same .... with some retooling ..... thought worth to mention
                            if you prefer the other way magnetizing your water ...... interestingly also included as a part of the Tesla Turbine :
                            I 'd like to bring your attention to the principle used in the Valvular tube ..... Nikola Tesla: Disk Turbine / Pump (Articles, patents, links)
                            some parts need to be replaced by magnets ...... try to guess which
                            • as we also discussed Boron :
                              Scientists have discovered way to create high-quality graphene capacitor, which could deliver high-frequency electronics
                              graphene researchers found that sandwiching a layer of the wonder material between boron nitride could produce highly-accurate capacitors.
                              Read more at:
                              for all the post on Boron : Google
                              just a thought : what if Hendershot used Carbon ....... and Boron .... in his capacitors
                              Vortex pinning could lead to superconducting breakthroughs
                              • stumbled on the following info :
                                ubuntu: We Are Not Alone - European Space Agency
                                The prestigious European Space Agency (ESA) has declared Phobos, the mysterious Martian moon, to be artificial.
                                In other words, Phobos is not a natural satellite, is not a "captured asteroid," and is hollow. This is exactly what Dr. Shklovsky found back in the 1960s. Phobos was artificially constructed and placed into Martian orbit by...who?
                                Credit:
                                (Taken from a weekly report by George A. Filer - MUFON Director)
                                Egyptian girl, Aisha Mustafa, invents new space propulsion system
                                Sohag - A physics student from Egypt's Sohag University, Aisha Mustafa, 19, has patented a new type of propulsion system based on quantum theory that she says could propel space probes and artificial satellites without using any fuel.
                                According Gizmodo, Aisha's new system exploits the quirky laws of quantum physics which state that in spite of appearances, space really is not vacuum but that it is a seething cauldron of fundamental particle interactions involving creation and destruction of "virtual particles."
                                Mustafa believes it is possible to use vacuum energy fields to create propulsion and build spacecraft propulsion systems that need little or no fuel to travel in space. According to Fast Company, Mustafa is betting on exploiting quantum effects involved in dynamic Casimir effect and the Casimiri-Polder force. She uses two silicon metallic plates in a vacuum, "like capacitors placed a few micrometers apart." The plates interact with the virtual photons in the quantum field and generate a net force that is either an attraction or a repulsion depending on their arrangement. Egyptian girl, Aisha Mustafa, invents new space propulsion system
