  • a bit of info
    Fool's gold may prove an unlikely alternative to overexploited catalytic materials
    Catalytic materials, which lower the energy barriers for chemical reactions, are used in everything from the commercial production of chemicals to catalytic converters in car engines. However, with current catalytic materials becoming increasingly expensive, scientists are exploring viable alternatives.
    Researchers at the University of Cambridge have now discovered that the sulphide material iron pyrite, commonly known as 'Fool's Gold', may hold the answer. Their findings were published online today, 10 February, in Physical Chemistry Chemical Physics.
    In the past, sulphur was believed to be one of the most detrimental elements for surface chemical reactions, able to decrease dramatically the reactivity of a catalyst by occupying (poisoning) the "active sites" on the material, but more recently some sulphur materials (for example, molybdenum sulphides) have actually shown interesting catalytic properties of their own.
    Using state-of-the-art electronic structure calculations, researchers led by Stephen Jenkins at the University's Department of Chemistry, explored the potential catalytic activity of iron pyrite, the most abundant sulphur mineral on Earth. In their study, the Cambridge researchers focused on the reactions between iron pyrite and nitrogen oxides (NOx), an extremely poisonous class of compounds produced (among other sources) by car engines and industrial power plants.
    Signs and symbols -Confucius.
    • let us discover who the pyrites are
      Pyrite Group.
      Pyrite is a very common mineral, found in a wide variety of geological formations from sedimentary deposits to hydrothermal veins and as a constituent of metamorphic rocks. The brassy-yellow metallic colour of pyrite has in many cases lead to people mistaking it for Gold, hence the common nickname 'Fool's gold'. Pyrite is quite easy to distinguish from gold: pyrite is much lighter, but harder than gold and cannot be scratched with a fingernail or pocket knife.
      Pyrite is commonly found to contain minor nickel, and forms a series with Vaesite; Bravoite is a nickeloan variety of pyrite.
      It usually contains minor cobalt too, and forms a series with Cattierite. Many pyrites contain minor As, see Arsenian Pyrite. Pb-bearing pyrite has been described by Cabral et al. (2011). It can also contain traces of other metals, including gold.
      Classification of Pyrite
      (sulfides, selenides, tellurides; arsenides, antimonides, bismuthides; sulfarsenites, sulfantimonites, sulfbismuthites etc...
      antimony is often referenced in alchemical treaties and
      bismuth is used in MoeJoe Cell ( Official Website of The Moe-Joe Cell Spherical 316 Non-Magnetic Stainless Steel Joe Cell )
      Crystallography of Pyrite
      Crystal System: Isometric
      talking about isometric guess who else is
      from: http://www.energeticforum.com/psychi...antenna-6.html
      Magnetite is in the isometric crystal system where the crystal axes are the same length and at right angles to each other.
      Magnetite: Magnetite mineral information and data.
      The Isometric Crystal System
      the above animation is from: 1 - Tales of the Dodecahedron
      you should also check out the crystal Atlas as it gives you the different 3d geometry of each type of crystal
      see here.... Pyrite: Pyrite mineral information and data. just scroll down to crystal atlas
      • As mentioned previously when 2 Fractal constructs are put together they tend to resonate to each other: here is an example:
        from: http://www.energeticforum.com/renewa...rystals-6.html
        a Fractal Construct has an 'efficient function', they have, a fractal ergonomy to them, they function on multiple levels and in multiple dimensions:
        the following applies to the real pyramids as well
        Multiband Pyramidal Antenna for Radio Navigation
        and Telemetry Systems
        Abstract combining
        radio navigation and MicroSAT telemetry applications was
        recently introduced by the authors. This flexible antenna
        provides independent and easily adjustable operating frequency
        design. Furthermore, the radiation patterns of this pyramidal
        antenna are relatively similar at the different operating
        frequencies. One key element of this radiating structure is its cutoff
        waveguide placed underneath the antenna ground plane in
        order to improve input ports impedance matching while
        minimizing the antenna rear radiation level.
        This paper further
        describes the above-mentioned antenna and gives its latest
        improvements.
        look at the following pictures taken from the pdf , you are going to like this
        The secrets hidden in the pyramids of Egypt (Harun Yahya) - YouTube
        in it its mentioned the use of whithe limestone as insulating coating for the pyramid same properties as mica...which reminded me of the following news posted a while back:
        from http://www.energeticforum.com/renewa...-crystals.html
        Solar power without solar cells: A hidden magnetic effect of light could make it possible
        Light has electric and magnetic components. Until now, scientists thought the effects of the magnetic field were so weak that they could be ignored. What Rand and his colleagues found is that at the right intensity, when light is traveling through a material that does not conduct electricity, the light field can generate magnetic effects that are 100 million times stronger than previously expected. Under these circumstances, the magnetic effects develop strength equivalent to a strong electric effect. from the article
        this you need to remember when building your Crystal Cell
        The researchers found a way to make said Stephen Rand, a professor in the departments of Electrical Engineering and Computer Science, Physics and Applied Physics.
        In the process, they overturned a century-old tenet of physics.
        • and we all know that most pyramids were placed close (or on top of ) a body of water
          what do we know about water ...here are a few posts to add to the properties of pyramid and help you see clearer :
          the following can be viewed as the pyramid (in pink ) and its "Aura" formed by the water (in blue )...the earth is the vibratory plate on a more subtle dimension
          and
          just found this very nice german website on cymatics while watching a doc on crop circles:
          and if you are curious about crop circles, here is the doc i found it in:
          New swirled order want to watch the cymatics animation go to 14:30 min of the vid
          ‪New swirled order‬‏ - YouTube
          Where does this mysterious crop circle phenomena come from? Is it done by man as a joke? So why do people have extraordinary experiences then? Flying ball of lights were seen in and around crop cirlces. Or is it an alien intelligence which try to communicate with us? The geometry which can be found in crop circles, inculed a lot of mathematics which can be also found in nature.
          I would like to also read the following:
          Underground Water and Crop Circles - Article by Glenn Broughton
          Put very simply we are stating that there is always underground water present where crop formations occur.
          again water
          ...why am i not surprised
          let's not forget
          Tales of unusual light beams, even UFO's, are commonplace around crop circles. While some of these strange lights have been captured on film, perhaps more intriguing are the many oral accounts of crop circle activity from the days before airplanes or secret military technology. Between 1900 and 1910, one woman recalled having seen circles on her grandfather's land near Tilshead, Salisbury Plain. The wheat was apparently 'flattened so firmly that it could not lifted without springing back down.' Some crop circle researchers (know as 'cereologists' after the Roman goddess of agriculture, Ceres) have even wondered if the famous Salisbury Plain megalith, Stonehenge, was itself built to commemorate the spot where a crop circle once formed.
          The area certainly has had its fair share of crop circles in recent years. In 1996, the 'Julia Set', a staggering 915 foot long formation with 151 circles, appeared near Stonehenge in broad daylight and within a forty-five minute mesmerizing designs of the crop circles. The formations now happen so frequently that special tour buses headed towards the latest crop circle have become a regular sight on the narrow, winding roads of Wiltshire hills.
          a bit of Harmonic Math for the pleasure:
          1996 = 16 = H.M 7
          915 ft = 15 = H.M 6
          151 circles = H.M 7
          45 min = H.M 9
          • one more property you add to the pyramid... it functions like a tree (fractal ) too Principle of Correspondence
            from: http://www.energeticforum.com/renewa...llector-2.html
            James H. ROGERS
            Underground & Underwater Radio
            The Rogers laboratory, which comprises several large rooms, is lined on all sides with glass cabinets containing electrical apparatus which he has invented from time to time through his studious career. A novel and original high frequency generator was another of the devices that greatly interested the writer. It employed a jet of water shunted by a large capacity, the stream of water being connected to a high potential source of direct current. High frequency currents of any range up to the limit of audibility, or about 30,000 cycles per second, could be readily obtained with this apparatus.
            Remember what i wrote earlier in my posting
            Spiral grain is evident in trunks, limbs, and roots.
            then read what follows: from the same article
            As pointed out in the original article on the Rogers underground system in the March issue, very promising results have been obtained in transmitting with the underground antenna, and Fig. 8 shows how a small transmitting set was operated with such an aerial, coupling the exciting or spark gap circuit with the antenna oscillatory circuit by means of a two-coil oscillatory transformer, L, C. In this case two metal plates, about one yard square, are placed in the earth adjacent to the well, one of which connects with the secondary, S, of the oscillation transformer, while the other plate connects with the free end of the spiral antenna.
            If the spiral antenna is used, it should be placed on its vertical axis, and it should be placed in the vertical placed in the vertical plane as shown as shown in Figs. 7 and 8. Excellent results have been had should be obtained in transmitting with the underground antenna, with the usual insulation incident to the form of conductors above specified, where the transmitting set is one employing an audion oscillation generator
            Note: When reading the article, keep also in mind the fractal/constructal properties of nature (meaning all its elements are "natural" antennas, and this article will look definitely easier to understand)
            link:
            James H. Rogers: Underground & Underwater Radio Antenna
            to plant some coils in old Mother Earth. Finding labor scarce decided to throw them into the lake for a trial. Ouch! Then the fun began. Now to get back to business we will begin with the first experiment carried out at this lake, in order to prove my sanity.
            Experiments were carried out with large square framed coils ( 200 feet to the turn, or 50 to each side of the square ) laid on the ground. This was tried for long wave undamped reception and exceptional results were had when the ground was wet, immediately after a good rain, for then the wires were practically buried. However, when the ground dried out, the signals vanished and were not received with a readable audibility. It was only necessary to have these coils buried in moist earth and excellent results have been obtained. Receiving on underground from short wavelengths with long outstretched wires demands a critical length of the wire. However on a loop or concentrated open ended coil such as mine, the length does not materially affect such reception until the length exceeds 500 feet to the coil.
            ps: the water is present everywhere in one form or another, even deep inside the earth and the moon (according to NASA)...
            Water appears to be one of the most abundant molecules in the Universe. It dominates the environment of the Earth and is a main constituent of numerous planets, moons and comets. On a far greater scale it possibly contributes to the so-called "missing mass" of the Universe and may initiate the birth of stars inside the giant molecular clouds. This paper gives a brief description of water and ice environments with an emphasis on their possible origin and subsequent development in the Solar System. Expanding the scope of hydrology to cover phenomena encountered on other celestial bodies is postulated and discussed.
            WATER IN THE UNIVERSE
            The Paper
            ...Guess what? A tree has aerial and ground Antenna best of both worlds
            Small reminder of Tesla's Set up:
            • if we follow through with the principle of correspondence you can also consider the following as applicable to a pyramid...instead of the wind think schumann Resonance + solar effect
              from: http://www.energeticforum.com/renewa...llector-5.html
              Hi Monsieur, I took the pulse of a large Ghost Gum tree today, I measured a main frequency at about 12 to 21 Khz and funily enough the waveform looks much like this. But not so jagged.
              Which is why I didn't bother to photgraph it, yet. The frequency increased as the wind picked up and there was a definate minimum at about 12 Khz and a definate maximum at about 21 Khz, no matter how hard the wind blew the frequency never topped 22 Khz it went from 12 Khz to 20Khz with just a bit of wind and stayed there as the wind increased.
              The little meter said between 25 to 35 db, whatever that means.
              decibels ?
              I only measured it 1.6 meters up the tree ( the probe) and right at the base, I used screws to get attachment points. I'll get a wire attached higher In a tree when I check a few more out.
              So that sounds like a resonable frequency to keep in mind for now, I will check out some more as i get time. It's very windy here now and winter so it is not that pleasent outside some days.
              thanks again Farmhand
              • Check this video out:
                Vortex Based Mathematics by Marko Rodin
                Rodin himself explaining why 3,6,&9 are so extremely important. He mentions sacred geometry, high math, and most other stuff in this thread. I'm only 1 hour In so far, I'll have to watch te rest later (4+ hour video).
                • thank you occy30 for your contribution
                  one more thing i would like to add to the pyramid is not to forget like you or a tree it has its own "DNA" Helix.....ie alpha quartz within the granite
                  also, remember the huge craft in Phoenix ie Phoenix lights:
                  Hovering not hard if you're top-heavy, researchers find
                  February 10, 2012
                  Top-heavy structures are more likely to maintain their balance while hovering in the air than are those that bear a lower center of gravity, researchers at New York University's Courant Institute of Mathematical Sciences and Department of Physics have found. Their findings, which appear in the journal Physical Review Letters, are counter to common perceptions
                  Could Venus be shifting gear?
                  New power source discovered
                  the combustion wave creates a strong electric current,
                  • things are kicking into high gears:
                    Big Name Neuroscientist Announces Telepathy as Proven Fact!, page 1
                    Neuroscience Researcher and Laurentian University professor, Dr. Michael Persinger, demonstrates telepathy under laboratory conditions.
                    Persinger has discovered the same type of brain stimulation can create metal states conducive to human telepathy
                    kind of reminds me of the following:
                    • --------------------------and
                      The Ultimate Secret of Lincoln Cathedral — World Mysteries Blog read originally here The Devil's Chord: The conspiracy to open the portal of consciousness and mystery of the octave, page 1
                      For me, this became a further clue to the Magdalene mysteries cloaked in and around this great Gothic church, and that stayed on hold until now.
                      looks like an 8*8 magic square
                      The initial premise of a battle between Light and Dark suggested itself at the 19thC small church at Rennes-le-Chateau with its chequered floor of black and white squares, a sure sign of Freemasonry as the floor or groundwork of every Lodge denotes this dual nature, some say symbolising the Good and Evil principles of the Egyptian and Persian creed. Staring across at each other in this strange ornately decorated church are the figures of Jesus and the demon guardian Asmodeus. The dual Light and Dark
                      64 Hexagrams. The 64 squares of chess mirror the number of Hexagrams (64 also being the number of DND Codons), the 8 major trigrams replicate the 8 ranks, 8 files, six lines in a hexagram duplicate the 6 types of chess pieces and both have two opposing modes, the Ying-Yang and the two opposing black and white colours. Transformation in the I-Ching entails 8 major shifts paralleling the musical octave, something we will be returning to.
                      octave is the 8th day after a feast, sometimes called an octave and a fifth apart, which connected with certain intervallic relationships of the harmonic series. During the Easter Octave, for each of the days, there are specific chants.
                      12thC, and banned throughout Christendom, this the musical interval of the augmented fourthan acoustic resonating tuning fork which can be used to emit a pure musical tone, key or pitch.
                      remember the prophecy .... http://www.energeticforum.com/renewa...netism-64.html
                      Interplanetary ships, invisible to the human eye, are coming right now to the earth. These beings, invisible to the human eye, have always coexisted in our planet, and they dwell in temples and convents because they are mystics and they tray to impose the faith. (year 1939)
                      The earthly civilization has an astray civilization. It was higher than the following. The man of that time was "adaptable" to the intense earth heat as well as to the hard cold of his origin. He was electromagnetic, he knew how to follow the high mathematics and astral sciences. This man still dwells the iced Pluto, since as it was said "he is adaptable". (year 1960)
                      The amphibious interplanetary ship will prove the existence of habitable channels inside the earth. It will submerge in the South Pole and will reappear in the North Pole. Just soon afterwards! (
                      UFO and USO pisa italy USO report
                      for the Hollow Earth theory it makes sense if you consider our planet evolves like this:
                      when you read all the prophecies keep in mind that every truth is half truth (ie parabola ) that is how it works
                      if you prefer he tells it with his own resonance
                      • Let's explore a bit the Devil's Chord:
                        Tritone - Wikipedia, the free encyclopedia
                        In classical music from Western culture, the tritone"three" and tone) is traditionally defined as a musical interval composed of three whole tones. In a chromatic scale, each whole tone can be further divided into two semitones. In this context, a tritone may also be defined as any interval spanning six semitones.
                        The name diabolus in musica ("the Devil in music") has been applied to the interval from at least the early 18th century. Johann Joseph Fux cites the phrase in his seminal 1725 work Gradus ad Parnassum, Georg Philipp Telemann in 1733 notes, "mi against fa", which the ancients called "Satan in music", and Johann Mattheson in 1739 writes that the "older singers with solmization called this pleasant interval 'mi contra fa' or 'the devil in music'".[15] Although the latter two of these authors cite the association with the devil as from the past, there are no known citations of this term from the Middle Ages, as is commonly asserted.[16] However Denis Arnold, in the The New Oxford Companion to Music, suggests that the nickname was already applied early in the medieval music itself:
                        It seems first to have been designated as a "dangerous" interval when Guido of Arezzo developed his system of hexachords and with the introduction of B flat as a diatonic note, at much the same time acquiring its nickname of "Diabolus in Musica" ("the devil in music").
                        from: http://www.energeticforum.com/renewa...netism-58.html
                        B Flat and Black Holes
                        This one's a bit of a stretch, but here's what happened.
                        In September 2003, astronomers at NASA's Chandra X-Ray Observatory found what can be described as sound waves emanating from a supermassive black hole. The black hole can be seen in the Perseus cluster of galaxies located 250 million light years from Earth.
                        Andrew Fabian of the Institute of Astronomy in Cambridge, England, analyzed the waves and announced, "We have detected their sound...." The sound he found (which is really the waves passing through gas near the black hole) translate to the note B flat.
                        But this is not a B flat you or I can hear. It is 57 octaves below middle C. A piano, by comparison, contains only seven octaves. So if a black hole hums, it hums at a frequency a million billion times lower than you can hear.
                        • here is an interesting piece of info
                          Before It's News
                          French-born venture capitalist, computer scientist, author, ufologist and former astronomer "solar dance" at Fatima was a UFO. The idea of UFOs was not unknown in 1917, but most of the people in attendance at the Fatima apparitions would not have attributed the claimed phenomena there to UFOs, let alone to extraterrestrials.
                          from the same article:
                          "In the last two centuries, the Church has made apparitions of the Virgin Mary an evermore important part of the Christian religious experience and doctrine. Some critics argue the popularity of the Catholic Faith is largely maintained by the popularity of the Virgin Mary.Lourdes is no doubt the most famous. But the most intriguing apparition occurred in the early 20th century, in the Portuguese hamlet of Fatima.
                            Joseph smith is the creator of the Mormon Religion....found close to the UTE mountain ..which we discussed previously: see http://www.energeticforum.com/174980-post1789.html
                            a little excerpt from the post so you know how we came to talk about it:
                            As I was reading the Article Background and History on Aetheric Energy Charging Device
                            it kept talking about the Mormons and the Dream Mine and some out of this world contact....so i figured I'd go a little back in history to check out what the local indian tribes had to say about the Mountain where the Mine is Located... guess what i found
                            interview of Dr Vallee
                            Jacques Vallee thoughts about the nature of the UFO phenomenon - YouTube
                            for clarification: the use of the term "we" relates to all the participants and readers not to my person ( i'm not that full of it )....we would not be this advanced in our discussion if it was not for you guys...so you deserve much respect for that and the blessings of Angels .....thank you guys
                            • something you should know about the Mormons
                              http://en.wikipedia.org/wiki/Granite_Mountain_(Utah)
                              Granite Mountain is a mass of solid rock one mile up Little Cottonwood Canyon in the Wasatch Range of Utah, not too far from Salt Lake City, Utah. Despite its name, Granite Mountain is primarily composed of quartz monzonite, an igneous rock similar to granite in appearance, physical characteristics, and chemical composition. This is the same material used to construct the Salt Lake Temple and the facade of the LDS Conference Center.
                              isn't it close to Professor Steven E Jones
                              from: http://www.energeticforum.com/renewa...llector-3.html
                              I was just reading through this thread:
                              and i also read the info on pesn:
                              Dr. Steven E. Jones' circuit gives evidence for 8x overunity
                              Retired Physics Professor, Steven E. Jones is working on a simple overunity circuit that he has seen go as high as 20 times overunity; documented on a state-of-the-art Tektronix 3032 oscilloscope at Brigham Young University producing eight times as much energy as was required to run the solid state circuit. One of his friends, Les Kraut, has replicated the circuit and also achieved eight times overunity...
                              ..."I don't know where the energy is coming from, but it's coming from somewhere," he said.
                              I would like you to check out the following image, it is a "google map" of Brigham Young University (marker B)...
                              ---------------------continuing from the wiki link
                              The Granite Mountain Records Vault (also known simply as The Vault) is a large archive and vault owned by The Church of Jesus Christ of Latter-day Saints excavated 600 feet into the north side of Little Cottonwood Canyon. The Granite Mountain facilities feature a dry, environment-controlled facility used for long-term record storage, as well as administrative offices, shipping and receiving docks, a processing facility and restoration laboratory for microfilm.
                              Records stored include genealogical and family history information contained in over 2.4 million rolls of microfilm and 1 million microfiche. This equals about 3 billion pages of family history records. The vault's library of microfilm increases by up to 40,000 rolls per year. Since 1999, the church has been digitizing the genealogical microfilms stored in the vault. The church makes the records publicly available through its Family History Centers, as well as online at its FamilySearch website.
                              looks to me like they are looking for someone through the ages
                              • talking about the Elite found this quote interesting:
                                There is a small percentage of the human population who believe they are genetically superior to everyone.They always had and will continue to have one main objective:
                                To have and keep total control over the masses
                                Let me ask you, old friend, in a Spiritual Universe, what does Genetically superior Mean?
                                I found this quote (can't remember where ) but loved it:
                                It is like pissing against the wind
