  • Do you guys recognize this shape: Donut shape
    this photo comes from a story that broke a while ago:
    Ancient Greek Gods And Lore Revisited - Ionnides - Oltissis - Tom Connors - Drones
    the name Oltissis referred to historic pleasure palaces in Greece and China's Xanadu
    just stumbled on it and the shape caught my attention
    Signs and symbols -Confucius.
    • here are two links in relations to the previous post:
      [HOAX] Isaac CARET - Drones [HOAX], page 126
      The Principle of Polarity.
      "Everything is Dual; everything has poles; everything has its pair of opposites; like and unlike are the same; opposites are identical in nature, but different in degree; extremes meet; all truths are but half-truths (and all lies are but half lies ); all paradoxes may be reconciled." - The Kybalion
      • I don't know about you guys but this key has something special...just take 5 min to study it...let your eyes follow the flow and you'll see where you end up....
        And Time is one of these Dimensions...so i decided to Merge the 3 Historical Flags of Morocco into one...Here is the Result:
        also from the wikipedia link : the 7 Stars (7 Principles )
        see this post for shape power:
        and BioGeometry
        • the chess board pattern and the red color is also found in: Dragon Treasures of St. Germain on Vimeo
          Saint-Germain: The Immortal Count
          He was an alchemist who, it is believed, discovered the secret of eternal life
          Fulcanelli made references to him
          Hidden in plain sight
          • there is a useful discussion taking place in this thread.
            llynch has kindly taken it upon himself; for which I am Grateful , to reduce the numbers in the Table of Elements and seek out useful Patterns...PLease Check it out...you'll learn quite a bit
            He also Compared Iron with Copper
            and Iron with Zinc
            • From the Book of Comte St Geramin...Recognize the Shape (cone / vortex ) and the Snake (DMC Coil ) Comte de St. Germain --- The Most Holy Trinosophia (Alchemy)
              Note the Pentagram is not connected
              and the chess board pattern and the red color is also found in: Dragon Treasures of St. Germain on Vimeo
              • Even the Royal Standard is Full of Harmonic Math
                The Crown has 12 small red orbs ; the sun has 15 rays , the Lions have 9 red Claws ,if you don't count the 2 hidden yellow and blue (red yellow blue and white are magical and Alchemical colors ) there are 12 of them
                also from Comte St Germain's Book :
                Approaching I noticed on one of them sacred script, the other being engraved with a line of Greek letters; between the two plates was an iron circle. Two lions, one red and the other black, rested on clouds and appeared to guard a golden crown above them. Also near the circle were to be seen a bow and two arrows. I read several characters written on the flanks of one of the lions. I had barely observed these different emblems when they vanished together with the wall which contained them.
                one more thing...where the pentagram meets the Blue tile, it resembles the all seeing eye
                Edgar Cayce on Atlantis | Paranormal News Central
                We must remember that the periods of exodus from Atlantis were far apart. The type of civilization carried to the region of the Pyrenees and America just before and after the first destruction was not the same as that carried to Central America and Morocco before the second upheaval, and to Egypt and Yucatan before the final destruction.
                In the Pyrenees there are ruins of the early Atlantean settlements; and in Morocco early settlements, also as yet uncovered.
                for clarification: People (including royalty ) living in Morocco may not know this hidden in Plain sight Truth ...Nor are they Atlanteans (at least for most of them )
                From: Dragon Treasures of St. Germain on Vimeo see the Green Pentagram in red background
                • here is a list of books uploaded by a user on scribd.com that you might find useful in your acquiring new knowledge:
                  Philochatus on Scribd | Scribd
                  • also from: Dragon Treasures of St. Germain on Vimeo
                    the second pic is taken from power of shape
                    also
                    alchemical illustrations
                      KeelyNet.com ( MAY 11, 1994 )
                      CADUFAZE.ASC
                      by Joel McClain
                      In looking at the presumed design of the Sweet VTA, (presumed as a result of the lack of detailed information available) I have coined the term "alternate depletion" to describe its method of attaining ZP energy.
                      We know from conventional transformer theory that a transformer will reverse the phase of the primary signal in the secondary winding. This is caused by the inverse relationship of EMF and CEMF in the core of the transformer. Typically, the core is made of iron laminates, or some other ferrous material. The Sweet VTA uses this principle in a manner which uses the phase reversal to cause a cascade of energies.
                      The dual caduceus coils ( DMC coil is a variant of it ) are seen as next to each other, which permits inductive coupling, and within the field of opposing magnetic fields, which creates a stress within the cores of the caduceus coils. At the crossover points of each coil, the flux collapse is "assisted" by the stress field of the core. The stress field, similar to a conventional electric generator, oscillates the lattice structure of the copper wire, causing movement of electrons.
                      Energy "stored" in the stress field is added to the energy of the original flux collapse, because it is "pushed" in by the opposing energy of the other caduceus coil. That is the effect of reversed phasing, as mentioned earlier. While one crossover field is collapsing, the corresponding coil is expanding, which adds more stress field energy than that which was originally "displaced".
                      This continues to occur at each crossover point. The displacement caused by the "push" results in am imbalance in the stress field. As the process reverses, and the alternate coil's field collapses, it is aided by the "push" from the expanding field of the first coil. The current induced in the second coil is greater than the current in the first coil, because the "push" of the first coil is composed of its original energy, plus the "push" of the first coil.
                      This continues to increase the energy at each crossover point, yielding far greater energy at the output of the coils than that which was used to begin the process. The energy is amplified through each winding in a cascade effect.
                      Core saturation, normally undesirable in a power transformer, is required in the Sweet VTA design. The power attained will depend upon the strength of the cores. Power will increase until the core is saturated, and no longer able to expand energy into the magnetic field.
                      Why does the field collapse at each winding? This is at the heart of every caduceus coil. When wires are laid over each other, a capacitance is formed, and the capacitance cancels the inductance of the windings before the crossover point. This causes field collapse into the core, and then into the next winding.
                      A Tesla coil uses the same principle, in that a frequency is applied which is resonant at the value of LC, causing the series impedance to consist of wire resistance only.
                      From this, we can see that the current which is used to excite a caduceus coil must also be resonant relative to the length of the windings and the amount of crossover capacitance. To determine the appropriate frequency, the volume of the core as well as a resonating chamber must also be taken into account. The core is essentially a resonant cavity, and you need to apply a frequency which will cause it to resonate.
                      Think of the core as a hollow cylinder, to which you will apply a musical note until it resonates. The core density is irrelevant to resonance, and applies only when considering saturation. Try using an ordinary "tin can", opened on one end, and apply acoustic energy until you reach resonance, and hear the energy "ringing" back at you. (like the B Flat experience )
                      Having determined the resonant frequency of the core, then add the windings as if they were the holes in a flute, with a crossover at each "hole". In other words, even spacing is not going to work. Each crossover needs to be preceded by a length of wire which is calculated based upon the PHI relationship to resonance.
                      The caduceus coil has to attain aggregate resonance before it can produce an over-unity effect (I prefer Unity ), so each of the seven crossovers is a whole note on the diatonic scale. In other words, use alternate cube and square roots of PHI (1.618) times the length of the previous winding to determine the length of the next winding.
                      In this way, every winding is both a note as well as a harmonic of another winding.
                      Both coils of the Sweet VTA must be wound identically, placed side by side, and centered in the magnetic stress field. The primary for each coil should apply a low level signal at the resonant frequency, and the primaries should be 180 degrees out of phase with each other to aid in the expansion and collapse of the flux fields
                      • Just for your Information:
                        the speed of light, which is approximately 300,000 kilometers per second.
                        Some useful conversions between units are:
                        1 mile is 5,280 feet
                        1 mile is 1.61 kilometers
                        1 kilometer is 1000 meters
                        1 Light Year is 9.46 x 10 12 km
                        1 Light Year is 5.91 x 10 12 mi
                        fractal constructs has an 'efficient function', they have a fractal ergonomy to them, they function on multiple levels and in multiple dimensions:
                        Principle of correspondence
                        and probably that is why Tesla used to weight his coils too, it is much easier than finding 5.914441183 feet
                        look what i found you too are related to Light speed
                        More importantly, at this higher concentration of salt the DNA returned to near its original length with a final measured indicating complete dissociation of Rad51.
                        ps: when using the Principle of Correspondence (or harmonic math), you should not care much about the denomination (cm,kg,etc.. ) after the numbers
                        in reduction what matters is the reduced value and its place in the harmonic scale
                          LOL, the drummmer's beat is about 7-8Hz. This may sound crazy but when I was listening to this song I was also thinking about water energizing idea and Mobius wrapped crystal. Mobius coil has two ends which should go somewhere...then the title of John Mayall album appeared to me - Back to the roots. Simultaneously in my head appeared root system of a tree and Nathan Stublefield. I know it is weird, been reading too much lately.
                          V
                          I wanted to add this but forgot
                          • Found the following
                            There appears to be a mysterious connection between the star Sirius (the brightest star in the heavens), and planet Earth. Sirius, and our own planet are gravitationally linked, even though an enormous distance separates them. They move through space spiralling around each other in a helix pattern that resembles, mathematically, the geometry of the DNA helix. Many ancient cultures marked the helical rising of Sirius ( when Sirius rises over the horizon just before the Sun) with great ceremony, and based their calendar year on it.
                            An African tribe named the Dogon, who live in Mali in the former French Sudan. The Dogon were in possession of information concerning the systems of the star Sirius which was so incredible that I felt impelled to research the material. The results, in 1974, seven years later, are that I have been able to show that the information which the Dogon possess is really more than five thousand years old and was possessed by the ancient Egyptians in the pre-dynastic times before 3200B.C., from which people I show that the Dogon are partially descended culturally, and probably physically as well.
                            • As you might have noticed the chess board on the flag is an 8*8 Square...i figured I'd check the 8*8 magic square:
                              In the Western Occult Tradition, each planet has traditionally been associated with a series of numbers and particular organizations of those numbers. One such method of numerological arrangement is the magic square.
                              Associated Numbers
                              The numbers associated with Mercury are 8, 64, 260, and 2080. This is because: Each row and column of the magic square contains eight numbers.
                              The square contains 64 numbers total, ranging from 1 to 64.
                              Each row, column and diagonal adds up to 260.
                              All of the numbers in the square add up to 2080.
                              Divine Names
                              The divine names associated with Mercury all have numerological values of 8 or 64. The name of the intelligence of Mercury has a value of 260, and the name of the spirit of Mercury has a value of 2080. These values are calculated by writing out the names in Hebrew and then adding up the value of each included letter, as each Hebrew letter can represent both a sound and a numerical value.
                              here is an overlay on the flag with the numbers:
                              • Just finished watching 8 part youtube about the Egypt. Amazing and left me speechless on several occasions. Egyptians placed great importance on Sirius and spiritual influence upon the Earth beings. Their knowledge was way beyond what we know today. There is one face, a stone figure I couldn't take my eyes off. Even as being carved stone it makes me feel very small and insignificant.
                                Wonderful material and highly recommended.
                                Thank you
                                V
                                General D.Eisenhower
                                http://www.nvtronics.org
