    Check this out Shawn: see the emf egg and the ball
    Hendershot Used Phi (or so I speculate!!) - YouTube
    It is also how you calculate the distances between the rings in davey's heater (phi )
    No doubt he used Phi squared.
      I'll show you later, a little graphic play with the symbol Phi and the symbol for the Ankh Setup
      Signs and symbols -Confucius.
      • look what i found: Double Cone Bipolar Tesla Coil
        The above pictures are of a double coned coil I acquired on eBay. The seller purchased it from the estate of a deceased FBI agent. I was informed by one of the bidders, who owns a similar coil without the wires that it was designed by Nikola Tesla, himself. The wooden frame he owns was given to his father by Nikola Tesla as payment (Tesla had no money at the time).
        The Physics/Cosmogeny of
        Walter Russell and Lao Russell
        • from the same link on tesla's double cone: (once inside a a Rodin Coil... )
          The two cones are connected in the middle such that the entire length is one wire. There is no tapping point between the two coils. I had to replace the copper primary due to age and wear but I am keeping the old copper tubing as verification for the coil's age. This coil was likely built in the early 1900s and is identical in layout to Tesla's patent schematics from the late 1890s.
          Rumor has it that this coil exhibits antigravity properties. (just like the Caduceus ) I have not seen antigravity effects when applying a standard spark gap discharge to the primary.
          Variation of the Ankh Set up: The Phi Set up
          I have been reading a lot of Tesla's work and early on he experimented with cone shaped secondary coils. This is an interesting configuration and has come into particular interest regarding the generation of powerful electric arcs, as opposed to the generation of long electric arcs. Since Tesla's goal was to transmit power through the atmosphere he was primarily interested in generating intense electromagnetic radiation. The larger windings at the bottom of the secondary are able to absorb the most current from the primary, while the tapered format linearly increases the voltage in a proportional amount according to the electromagnetic falloff according to the distance from the primary. These conical coils often had no top load capacitor, and relied on the internal capacitance of the coil itself. This experiment clearly shows the distributed parameters in the components. I have built a Bi cone coil and have just started testing it. So far the results are impressive and will warrant further study.
          a collection of Walter Russell's drawings: find the egg
          Walter Russell Vortex Video - The Cosmology of Twin Opposing Electro - Magnetic Vortices - YouTube
          • The Emerald Tablet
            Its father is the sun and its mother is the moon.
            Father = RED (RED sun )
            Mother= BLUE (BLUE moon )
            Infra red / Ultra Violet
            -------also (all his videos )
            Watch the intro,
            because he explains exactly how i feel...and i think you guys do too
            sciencetosage's Channel - YouTube
            • One more thing i'd like to add to the many phenomenon that occur inside the Quartz / Mica / Neo ball inside the Tesla Egg:
              Solar power without solar cells: A hidden magnetic effect of light could make it possible
              Light has electric and magnetic components. Until now, scientists thought the effects of the magnetic field were so weak that they could be ignored. What Rand and his colleagues found is that at the right intensity, when light is traveling through a material that does not conduct electricity, the light field can generate magnetic effects that are 100 million times stronger than previously expected. Under these circumstances, the magnetic effects develop strength equivalent to a strong electric effect. from the article
              • Variation of the Ankh Set up: The Phi Set up
                Compared to the Ankh Set Up, what do you think is missing and i truly think this could make an awesome combination....
                just think of what happens: inside and outside: the following should replace the black ring
                  The double vortex at the bottom is the exact descrpition of the relation of the roddin coil with AC current running through it, only it possesses a larger interior null space where the flux is zero because the two forces are pushing against each other. In the roddin coil its easy to test because all you have to do is place a neoball in the center and you can see it grabbed by the opposing vorteces and levitated in the center. Yet it's not as simple as trapping a magnet between two totally differet opposing fields and levitating it. WHen the neo ball is caught in the null space it is spinning and trying to orbit which shows the the two opossing fields actually pass through the other. With this one it is the same but there is no way of testing the strength or area of the null space. If this is one single coil then it should principly behave the same as the roddin coil. And if you replace the black ring with that smaller circular ring it could increase the spin of the neoball by at least 50 hertz or more.
                  • The Ankh Set up is quite an amazing combination
                    our set up is bridging Tesla's theories and Russel's writings
                      Yes it does, are you going to build it?; if you build it they will come. (quote from filed of dreams)
                      • just think of what happens: inside and outside: the following should replace the black ring
                        Did you notice this small coil looks exactly like the green coil in the viamana picture that is at the top just under the bell. Except it appears that have that coil wrapped in ceramic or some other insulator.
                        • At some point i will, when I am sufficiently confident in my quality as an electronic technician if it improves
                          or i could just buy a ready made Tesla Coil (hopefully) and do the arrangements myself....I do not live in the US nor Europe so believe it or not, access to the necessary materials is not as easy as you might think (we don't even have Internet purchasing as well developed as you guys )
                          • Originally posted by shawnnweed View Post
                            used the same quote a while back.....good one Shawn
                              this coil is pretty much the same as Rodin Coil, and yes it is the same as the Vimana's...why would it be otherwise
                              principal elements found in the Ankh Set up (whether repeatedly used or not )
                              The Tesla Egg with the ball
                              The Elements in Tesla Coil
                              Rodin Coil
                              • the circuit mentioned in the vid using AC DC coupled:
                                funny how it resembles the following circuit (you could replace barium with quartz ):
                                Joel McClain & Norman Wootan: Magnetic Resonance Amplifier ~ Collected Papers
                                for those who have not watched this vid , you should (the dan winter water vortexer enhances the properties of water and it is the same you are doing with emf: principle of mentalism "all is vibe" )
                                Now a Caduceus is a sort of bifilar coil, just coiled in a solenoid instead of
                                a flat spiral, and the two "sub-coils" wired slightly differently...
                                the vid:
                                Fist Fights With Physicists - The Caduceus Coil, Helical Flow and the Evidence for Free Energy ☤ - YouTube
