  • Helmholtz Resonators
    Check out the patents based on the Resonator more in the link above
    BARRIER SYSTEM
    WO2009108071
    Process for the preparation of nanocrystalline hydrotalcite compounds
    GB2457771
    Vibration damper for damping hydraulic vibration of hydraulic oil in pressure line
    DE102009004705
    Pressure sensing device adapted to corrosive or explosive atmospheres and with means to filter disturbance frequencies
    GB2456865
    Resonator device for e.g. non supercharged internal combustion engine
    FR2926608
    INLINE HELMHOLTZ TYPE RESONATOR
    KR20090047083
    Handheld electronic device having hidden sound openings offset from an audio source
    EP2081400
    Hydraulic system for actuation of clutch of motor vehicle
    DE102008062336
    Hydraulic system for motor vehicle
    DE102008060584
    COOLING DEVICE AND ELECTRONIC DEVICE COMPRISING SUCH A COOLING DEVICE
    US2009168343
    LITHOGRAPHIC APPARATUS HAVING ACOUSTIC RESONATOR
    US2009161085
    Microphone for audio source tracking
    CN101449593
    Novel Helmholtz resonator
    CN101435356
    EXHAUST DEVICE FOR STRADDLE-TYPE VEHICLE AND STRADDLE-TYPE VEHICLE
    US2009139796
    MICROREACTOR DEVICE
    JP2009090265
    Noise attenuation device for a centrifugal compressor discharge or suction nozzle
    EP2063130
    MEASUREMENT OF SOUND SPEED OF DOWNHOLE FLUID BY HELMHOLTZ RESONATOR
    WO2009055197
    Method and device for achieving better heat transfer when using pulse heaters
    US2009084036
    SILENCER OF INTERNAL COMBUSTION ENGINE
    JP2009036185
    Signs and symbols -Confucius.
    • Tuning fork type piezoelectric resonator
      Electrically operated tuning fork - Google Patents
      • Now thats a water splitter if Iv ever seen one.
        • Now you saw a tuning fork , let's replace it with "wine glass/beer shaped" piezoelectric tuner
          watch this now
          Wine glass resonance in slow motion - YouTube starts at 1min 30
          • Here is a video showing the capabilities of Smith (Caduceus ) Coil
            Lenz's Law - Caduceus Coil - Bedini - Perpetual Motion Holder - Leedskalnin Montage - YouTube
            shawn, it will remind you of Dr Boyd's video on anisotropy
            -----the following video is a 3d description of a vimana
            THE VYMAANIKA-SHAASTRA-vinama device. - YouTube
            you should look at the above pic upside down to see the Ankh Set up
              alright let us see. So far I have seen a gyroscope, tesla device, roddin coil, and fusion reactor all combined did i miss anything?
              • Originally posted by shawnnweed View Post
                which makes complete sense. If a vortex of liquid water can create thousands of volts and this is just water then how about a vortex of liquid metal, like mercury? Of course what is a roddin coil filled with mercury once the metal is moving within but a vortex. If you filled the container then how could you get the mercry to vortex naturally, you can not, no vortex no electricity. But what if you spun the container. Then the liquid within will eventually spin at the same rate the exterior spins. This is why they placed the entire set up on a gyroscope. The base is nothing but a centrifuge (not a fusion reactor as previously stated...sorry. This total set up would cause an electromagentic flux so large that it would easily pick itself up from the ground.
                  We are on the same page .....
                    which begs to question...what would you get when you mix a roddin coil made of copper filled with mercury and wrapped with a caduceus coil?
                      You mean a copper Donut filled with mercury and wrapped with a caduceus coil...
                      I like where you are going with this sounds Nazi Bell like...
                      • watch the vid:
                        Rodin coil vortex in water - YouTube
                        First magnetic vortice reproduced... - YouTube
                        Magnetic Rotation in the Rodin Coil - was the Bell really a myth after all?
                        I "ventured" my personal take on this:
                          You get this...guess who...http://www.energeticforum.com/155886-post493.html
                          Helmholtz Torus UFO Technology Ferrofluid Rotor - YouTube
                          watch this vid, it is very well presented:
                          Anti Gravity - YouTube
                            pretty interresting. I also disocvered that mercury when in a copper donut will move when there is electricity applied and moves in the interior in a corkscrew fashion. An electro magnet is often copper wire wrapped around a iron core(soft metal) but mercury is also a soft metal. Wouldn't this be a giant electromagnet on crack. Apply high voltage and watch the sparks fly.
                            • you know if you look at the properties of water, you'll find that it shares some with mercury; i would suggest you read this post:
                              and it is safer for your health...
                                works for me
                                Principle of polarity:
                                centripetal energy is the basis of life whereas centrifugal energy is the basis of decay and destruction. V. Schauberger
                                Now add on top of it (the entire set up on a gyroscope) a Bell Shaped /or Singing Bowl shaped cover That functions like the Helmholtz Resonator (Helmholtz resonance - Wikipedia, the free encyclopedia )
