  • #91
    correction:
    non-ferromagnetic conductive substances : , copper aluminium, air and water ....
    we should also envision the possibility of placing the charged quartz in a Moe-joe cell type of design: read the post
    http://www.energeticforum.com/149663-post200.html
    This is perfect. Then we could use alluminum or copper as out non-ferromagnetic conducter.
    I took a look at the mojoe cell. It's a thought but i think we should walk before we run.
    • #92
      Elestial Quartz (also known as Skeletal Quartz) is the name given to various types of quartz all of which have formed with terminations or points covering every surface in a layered or etched pattern. This is the result of unstable conditions during the crystallization process. Within the crystal, plainly visible cavities in geometric patterns can sometimes contain clay minerals of varied colors. The cavities can even include carbon dioxide and water displaying both the liquid and gas phase of formation. This is visible even to an unaided eye with the appearance of a moving water bubble.The youngest form of quartz on earth, it is unlike any other form of quartz. Flowing terminations (usually not sharp) have formed over the faces and body of the crystal, and are usually tabular, rectangular or square, with rounded corners. Markings on the surface can have the appearance of cryptic hieroglyphics, a cosmic alphabet of sorts.
      how about this type of quartz (egg shaped of course ):
      hen's egg = The youngest form of quartz on earth
      In the version of the Ogdoad creation myth used by the Thoth cult, Thoth created Ra-Herakhty, via an egg, and so was said to be the father of Neferhor.
      (Both Thoth and Hermes were gods of writing and of magic in their respective cultures. )
      Signs and symbols -Confucius.
      • #93
        Thank you Slider, we'll be looking forward to reading your results
        ------you guys are going to like this:
        Russian scientists announced a sensational discovery at a press conference in Moscow today (July 26).
        A group of scientists supervised by the director of the Volgograd Institute on the study of materials, under the Russian Academy of Natural Sciences, Academician Valerian Sobolev, have discovered a new substances that can serve as a principally new, autonomous source of energy.
        The new non-chemical "battery" is made from sand and gets its energy from the Earth's magnetic fields. What is particularly important that the installation producing energy is relatively cheap.
        According to the academician, this discovery is of tremendous significance today. Using a stripping process, quartz, i.e., sand is transformed into a special substance that looks like blue crystals. This substance is used for making a special installation that scientists view as a stable and very powerful source of energy.
        Russian scientists have been working on the new sour! ce of energy together with Americans (the group includes 11 Russians and one American). Some experiments are conducted at Columbia University, but the majority of tests (running into hundreds) are done in Russia and it will get the patent.
        Interresssssting, I bet they are using black sand in mixture with salt to form crytal batterries. Of course the color once mixed will probably be a very light black, gray or dark blue. not surprising.
        ,shawn
        • #94
          awesome. It could be a combination of interactions within the crystal that could lead us to a profound discovery. I say let's go for it. Got to start somewhere.
          ,Shawn
          • #95
            Enhydro Quartz Crystal | eBay
            A specifi c type of quartz crystal known as enhydro quartz works
            even more rapidly to structure water. Th ese crystals contain a
            remnant of ancient water that has remained unchanged for eons
            inside the crystal. During the formation of these crystals, water
            was trapped. Th is is evidenced by Air bubbles appear to roll inside
            a tiny cavity in the crystal as the crystal is shift ed. Th e geometric
            structural pattern from the water inside enhydro crystals is
            maintained by the crystal and translated easily to water.
            • #96
              If my instinct is correct:
              "Nothing escapes the Principle of Cause and Effect, but there are many Planes of Causation, and one may use the laws of the higher (frequency ) to overcome the laws of the lower (frequency ie matter )."-The Kybalion.
              rhetoric question:
              What do you think happens when you mix piezo electricity, sonofusion and energy conversion....
              that is if we get the right source of energy to trigger the "cascade effect"
              Bubble fusion - Wikipedia, the free encyclopedia
              The researchers used a pulse of neutrons in order to nucleate ("seed") the tiny bubbles, whereas most previous experiments started with small air bubbles already in the liquid
              • #97
                one more thing, here is a list of what some healers call Master Crystals
                master crystals specialty formations
                so that could make them 12 potential candidates (remember fractal construct )
                • #98
                  For myself, I had never discovered this matter to anyone had it not been from fear of the day of judgment, and the perdition of my soul if I concealed it.It is a debt which I am desirous to discharge to the Faithful, as the Father of the faithful did liberally bestow it upon me.
                  The possession of Knowledge, unless accompanied by a manifestation and expression in Action, is like the hoarding of precious metals-a vain and foolish thing. Knowledge, like Wealth, is intended for Use. The Law of Use is Universal, and he who violates it suffers by reason of his conflict with natural forces."
                  ie: share your knowledge...open source
                  • #99
                    another clue:
                    since nothing is done except the matter be decompounded, and because it is not perfected unless the colours be thoroughly passed and accomplished. Know then, that the division that was made upon the water by the ancient philosophers separates it into four substances; one into two, and three into one; the third part of which is colour, as it were-a coagulated moisture; but the second and third waters are the Weights of the Wise.
                      rhetoric question:
                      hmmmmm. You're talking about building a mini reactor that is actually safe. Didn't one of your posts say something about the ancients having crystals that emitted great amounts of light? It could be they already knew this.
                      • since nothing is done except the matter be decompounded, and because it is not perfected unless the colours be thoroughly passed and accomplished. Know then, that the division that was made upon the water by the ancient philosophers separates it into four substances; one into two, and three into one; the third part of which is colour, as it were-a coagulated moisture; but the second and third waters are the Weights of the Wise.
                        now read the following two infos : (water is dipolar )
                        from: James Y Johnson -- Dipolar resonance -- Anomalous dispersion bands
                        Abstract -- Changes in the energy content of dipolar substances are produced by exposure to a concentrated electromagnetic field having one or more frequencies corresponding to wavelengths between 3 mm. and 6 metres approximately and equal to characteristic periods of the substances treated. The process applies to naturally dipolar substances and to those in which dipoles can be induced by a field. The characteristic periods of the substances are of three kinds depending respectively on (1) the relaxation time of the dipoles when orientated by the field, (2) the natural oscillation-period of the dipoles, (3) the term-difference frequencies of the atoms. They are associated with anomalous variations in the optical and dielectric properties and can be found by examining those properties in a field of varying frequency. They can be varied within limits by changing the temperature, pressure, concentration, &c., and may thus be adjusted to correspond exactly with a field of approximately correct frequency. The fields may be standing ones produced between conductors such as concentric tubes or the plate resonators described in Specification 417,564, or radiated fields concentrated by reflectors. They may comprise several different frequencies and constant electrostatic fields may be superimposed on them. The exposure may be continuous or intermittent and different frequencies may be applied in succession...
                        ...The process applies to naturally dipolar substances and to those in which dipoles can be induced by a field
                        Modeling of quartz crystal oscillators by using nonlinear (fractal) dipolar method
                        from: IEEE Xplore - Modeling of quartz crystal oscillators by using nonlinear dipolar method
                        A quartz crystal oscillator can be thought of as a resonator connected across an amplifier considered as a nonlinear dipole the impedance of which depends on the amplitude of the current that flows through it. The nonlinear amplifier resistance and reactance are obtained by using a time domain electrical simulator like SPICE (Simulation Program with Integrated Circuit Emphasis): the resonator is replaced with a sinusoidal current source of the same frequency and a set of transient analyses is performed by giving the current source a larger amplitude. A Fourier analysis of the steady-state voltage across the dipolar amplifier is performed to calculate both real and imaginary parts of the dipolar impedance as a function of the current amplitude. From these curves, it is then possible to accurately calculate the oscillation amplitude and frequency without having to perform unacceptably long transient analyses needed by a direct oscillator closed loop simulation. This method implemented in the Analyse Dipolaire des Oscillateurs a Quartz or Quartz Crystal Oscillators Dipolar Analysis (ADOQ) program calculates the oscillation start-up condition, the oscillation steady-state features (oscillation amplitude and frequency), and the oscillator sensitivity to various parameters. The oscillation nonlinear differential equation is solved by using the slowly varying function method so that the program quickly and accurately calculates the current amplitude and frequency transients. Measurements performed on an actual amplifier show a very good agreement with the results obtained by the simulation program.
                        now we have frequencies and a method from James Y. JOHNSON article (read it please )
                        • one more variable i would add, is the use of the Solfeggio Harmonics also known as Fibonacci Harmonics (or multiples of these harmonics )
                          if we consider the 528 Hz frequency has an effect on us humans, which seems the case ;and if we consider a crystal being on the lower scale of vibration than us humans, it is then conceivable that a higher multiple of the 528 hz has an effect on the Crystal (principle of polarity, principle of vibration, principle of correspondence )
                          • side note:
                            see post: http://www.energeticforum.com/152708-post377.html
                            There is a legend among the ancient Persian Sufi. A wise man said that the day would come when all the water in the world, except for what had been specially collected, would disappear. And then a different [type of] water would replace it, but [and] anyone who would drink the new water would lose his mind. Only one man took the prophecy seriously and began to store up water, but [and] the day that had been predicted did come, and every body of water emptied out. The man who had listened to the wise man drank water from his supply. And then the body of water and wells filled up with water again. People thirstily drank this water and every one of them went crazy. But the man who had listened to the wise man continued to drink water only from his supply and kept his sanity. And he was the only sane person left among the mad men; and therefore he was called crazy. And then he poured his reserves of water, the old water upon the ground and he drank the new water and lost his mind, and the mad men decided he had become sane.
                            all seven principles are at play in this story
                            THE PRINCIPLE OF MENTALISM. (in layman terms it depends on the "eye of the beholder" )
                            THE PRINCIPLE OF CORRESPONDENCE.
                            THE PRINCIPLE OF VIBRATION.
                            THE PRINCIPLE OF POLARITY.
                            THE PRINCIPLE OF RHYTHM.
                            THE PRINCIPLE OF CAUSE AND EFFECT.
                            THE PRINCIPLE OF GENDER.
                            • piezoelectricity is a mechanical phenomena, so when exciting Enhydro Quartz Crystal, the water cavity would probably have some nano quartz in it due to friction ...
                              hint: hydro magnetic generator type of phenomena
                              we are definitely unto something here
                              • Just an update on the cell test.
                                One thing that does affect these, is HV. Running a mini Tesla tower at 8" away from a cell, at 3V, the cells drop as though a small load is on them. Typical results would be a cell with resting readinghs of 0.680V @ 4mA, will drop to 0.674V and the milliamps will keep going down by around .1mA per 5 seconds. The voltage will stay at that new reading.
                                If the voltage is increased to the tower, the jump down in voltage jumps similarly. At 4.5V, the reading may be 0.668V and sit at that level.
                                Switch off the tower and both volts and amps climb again. Kinda odd that.
                                Infra-red from various sources didn't seem to do much...I haven't tried sunlight yet, due to a storm today.
                                A red laser pointer appeared to have no effect.
                                I'll try the UV LED's just as soon as I find them
