The Golden Tractate of Hermes Trismegistus applied to electromagnetism
  • October 8, 2012
    Tighten the strap on your tinfoil hat: Recently declassified documents show that the US Air Force was working on, and perhaps had already built, a supersonic flying saucer in 1956. taking advantage of the Coandă effect
    more in the link
    a repost on the Coanda Effect : http://www.energeticforum.com/renewa...tml#post189599
    Thanks Dave .... we can only in awe with what Nature has to offer us
    Dave did you have a look at the Patent of Coanda Effect ... think of the magnetic funnel you want to create as a combination of
    the coanda effect Coanda Effect Patents
    and Biefeld–Brown effect - Wikipedia, the free encyclopedia
    Thomas Townsend Brown, Electrogavitic propulsion inventor
    so you end up with :
    here is a vid of the principle that creates a "sink" of sort :
    Sir James Dyson explains his bladeless fan - YouTube
    ps: i wonder if anyone has ever made Rodin Coil with an Aluminum Donut ( maybe filled with aluminum dust ) sink
    Signs and symbols -Confucius.
    • Hey MM good to read you, Im hoping to get an effect of some kind
      Like water down a drain bro
      We'll see I plan to pulse the coils as well a freeze them in ice.
      Get out of the box and follow your own drummer.
      dave
      Im sure the Air Force tried jet engines at first but the design is for an electromagnetic device and Im sure they found that out.
      Oh would I love to have a peek or just their resources.
      later bro
      • one of my fav website posted an interesting article : Rex Research: suppressed, dormant,emerging unconventional alternative technologies: Free energy, Over-Unity, Antigravity, Inventions, Alchemy, Transmutation, Cannabis Hemp Marijuana, Magnet motors, Alternative Therapies"
        Marcel VIOLET -- Substance Activator ( GB82733 )
        In 1961, Marcel Violet, engineer of arts and professions and recognised inventor and scientist of his time, gave the only public lecture of his life during which he revealed his discovery of vitalised water.
        This revelation was later published as a book: "The Secret of the Patriarchs: Essay on the Nature of Biological Energy - Perspective on its Use in the Field of Self-Defense and as a Factor of Rejuvenation". In regards to his work, and after successful experiments
        He discovered that beeswax, properly prepared, is a selective filter of cosmic radiation, all of which is explained in detail in the conference. The Magnetic Fountain integrates this discovery, while incorporating the resonant frequency of the Cosmic C, which constitutes an additional vital information. How to check this, is explained in two minutes. We owe the magnetic resonance characteristics found in the Magnetic Fountain to the works of the great and underrated Nikola Tesla.
        here is the interesting part :
        At the Time of Tesla .... they often used Beeswax
        The Turn Of The Century Electrotherapy Museum Tesla Library
        To make a more heavy duty coil, impregnate the coil in a 1:1 ratio of molten beeswax and rosin, melted by induction
        stove or a double boiler (NEVER over direct heat, it will cause a flash fire!). It helps to increase the size of the coil
        to prevent over-stressing the insulation. For example, a 2-3" diameter coil will operate easily for extended periods
        of time. At any rate, apply a small amount of current to the coil while the wax mixture is cooling. This procedure
        also works well with condensers. By stressing the components while the insulation is cooling, minute air bubbles
        are forced out of the interstices by the mechanical actions of the currents flowing through the devices. It is important
        to keep the current low as not to over stress the insulation while it is cooling.
        Schematics Illustrated
        Nikola Tesla exhausted his coils and capacitors for insulating purposes in a pressure tank while melting the beeswax and paraffin mixture with steam permeating the mix into the smallest spaces to force out all gas bubbles, which was the reason his equipment was capable to stand these high electrical pressures and extremely rapid potentials.
        The Magnetic Fountain also contains a magnetic vortex, a sort of swirling magnetic field, which rotates the water molecules. All serious chemists know that the water molecule is electrically asymmetrical, so it aligns with magnetic fields. The Magnetic Fountain's vortex is made based on the work of Schauberger. A short film on the La Fontaine Magnétique website helps us understand the presence and effect of the vortex due to its spinning top. Another film which shows and explains the water vortex is also available for free.
        La Fontaine Magnétique - Fontaine Magnétique
        The "Magnetic Fountain" has a cylindrical shape, in which anisotropic ceramics are incorporated. This device accelerates the vibratory rate, and therefore increases the energy levels of the processed substances. The results is a significant increase of the wave of life, or increased vitality. Drinks and food are to be magnetized in / or on the receptacle provided for that purpose, and are instantly revitalized with a rotation of the levitating ring by the hand of the user. The "Magnetic Fountain" is very simple to use.
        http://en.wikipedia.org/wiki/Bee_(mythology)
        • are you guys familiar with the following coil ..... first time i encounter it ....
          ABHA Vortex coil finished and joule thief light´s her UP - YouTube
          Abha Vortex coil
          ..... will do a little search on it
          The Rodin/Powell Solution: A New Approach to Vortex Based Mathematics by Randy Powell
          ABHA Coil : Step-by-step Instructional! Disclosure! - YouTube
          • just felt it worth sharing as it is quite an interesting concept .... and thank you lasersaber for freely making it available
            SOLN1 - Amazing all in one free energy unit. - YouTube
            The SolN1 makes alternative energy easy enough for the masses. Lets build these and make them available to those in need. More info at: Laser Hacker! Free energy made easy. Forum: LaserHacker.com Forum - Index Many folks just need a couple light bulbs and a fan to change their lives for the better. After a natural disaster you may also want to have one of these handy.
            LED to enable agriculture 356 days a year in an urban setting | LEDinside – LED, LED Lighting, LED Price Trends, Global LED News and Market Research
            • just found these vid :
              you know me and the Caduceus Coil ..... we have a long history
              CADUCEUS COIL LEVITATION 1 - YouTube
              A 2 INCH CADUCEUS COIL ENERGIZED BY A 23 HERTZ SINE WAVE
              IS LEVITATING AN N45 ONE INCH SPHERE MAGNET WITH EASE
              VERY INTERESTING RESULTS FROM SUCH A SIMPLE COIL
              caduceus coil on delamorto 1.wmv - YouTube
              • ps:
                the key terms used in Alchemy can also be seen through the goggles of Numerology
                try for instance : Salt Mercury SUlphur or Antimony ( group 15 / Antimony in alchemy ) in :
                Sun Angel Creations - Law of Attraction Secrets - NumberQuest Numerology - NQ-Multi Numerology Calculator - Calculate Pythagorean, Chaldean, Kabbalah and Gematria Numerology Numbers! :: 123 Free Numerology Reports! :: Unlimited Free Numerology Name,
                by Fulcanelli p112 ( or 13 ): The Dwellings of the Philosophers
                Greek cabalists used to substitute numbers for
                certain consonants, for words whose common meaning they wanted to veil under a hermetic
                meaning.
                And so they used the epistimon ([*236-2]--- stagion)(33), Koppa, sampi, digamma
                (34)
                , to which they granted a conventional value. The names modified by this process formed
                genuine cryptograms, although their form and their pronunciation did not seem to have
                undergone any alteration. Furthermore, the word, antimony, [*236-3], stimmi, when it was
                used to signify the hermetic subject, was always written with the episemon ([*236-4],
                equivalent of the consonants sigma and tau together. Written in this manner [*236-5] ---
                simmi, it is no longer the stibnite of mineralogists, but indeed a matter signed by nature, or
                still better, a movement, a dynamism, or a vibration, a sealed life ([*236-6 --- simenai)
                so as
                to allow a man to identify it, a very peculiar signature submitted to the rules of the number
                six
                He is the seret artisan, the spirit, the mind enclosed in raw substance as translated
                by the Greek epistemon, because the spirit can single-handedly perform and perfect the entire
                work without any other help apart from elementary fire.
                Know that this matter I call the stone; but it is also named the feminine of magnesia or the hen, or the white spittle, or the volatile milk, the incombustible oil in order that it may be hidden from the inept and ignorant who are deficient in goodness and self-control; which I have nevertheless signified to the wise by one only epithet, viz., the Philosopher's Stone
                Hermes Trismegistus.
                ps: Coral Castle - Wikipedia, the free encyclopedia
                When asked why he had built the castle, Leedskalnin would vaguely answer it was for his "Sweet Sixteen." This is widely believed to be a reference to Agnes Scuffs (whose surname is given by some sources as "Skuvst"). In Leedskalnin's own publication A Book in Every Home he implies his "Sweet Sixteen" was more an ideal than a reality.
                Agnes - Wiktionary
                  more in the link
                  I have a question. The Dyson air multiplier works by creating a cone of air in a vortex shape. The inner part of the vortex is able to gain strength and "multiply" the air flow. I wonder if you took a standard generator and made it with the same idea. Like the copper windings would be on the outside and the energy your trying to generate would be happening on the inside of the spin. I wonder if a vortex effect would apply to electricity
                  • Originally posted by occy30 View Post
                    Good to read you occy30
                    similar to this : from Tesla's research
                    ----------------------------- a bit of esoteric .... follow up to previous post :
                    He also stated that he had "discovered the secrets of the pyramids",[14] which of course could be interpreted in either esoteric or engineering terms.
                    Try this! The Deepest most relaxing music and video ever - Air (15) - YouTube
                    still better, a movement, a dynamism, or a vibration, a sealed life ([*236-6 --- simenai) so as
                    six
                    Fulcanelli
                    • It would be unbecoming to not treat the Great Master to a 3 6 9 Lens
                      from : The inventions, researches and writings of Nikola Tesla, with special reference to his work in polyphase currents and high potential lighting
                      CONTENTS.
                      PART I,
                      POLYPHASE CUERENTS.
                      CHAPTER I.
                      BIOGRAPHICAL AND INTRODUCTORY..
                      CHAPTER II.
                      A NEW SYSTEM OF ALTERNATING CURRENT MOTORS AND
                      TRANSFORMERS Y
                      CHAPTER III.
                      THE TESLA ROTATING MAGNETIC FIELD. MOTORS WITH
                      CLOSED CONDUCTORS. SYNCHRONIZING MOTORS. ROTA-
                      TING FIELD TRANSFORMERS 9
                      CHAPTER IV.
                      MODIFICATIONS AND EXPANSIONS OF THE TESLA POLYPHASE
                      SYSTEMS 26
                      CHAPTER V.
                      UTILIZING FAMILIAR TYPES OF GENERATORS OF THE CON-
                      TINUOUS CURRENT TYPE 31
                      CHAPTER VI.
                      METHOD OF OBTAINING DESIRED SPEED OF MOTOR OR
                      GENERATOR 36
                      v iii
                      CHAPTER VII.
                      REGULATOR FOR ROTARY CURRENT MOTORS 45
                      CHAPTER VIII.
                      SINGLE CIRCUIT, SELF-STARTING SYNCHRONIZING MOTORS. . . 50
                      CHAPTER IX.
                      CHANGE FROM DOUBLE CURRENT TO SINGLE CURRENT
                      MO.TORS 56
                      CHAPTER X.
                      MOTOR WITH " CURRENT LAG " ARTIFICIALLY SECURED 58
                      CHAPTER XL
                      ANOTHER METHOD OF TRANSFORMATION FROM A TORQUE TO
                      A SYNCHRONIZING MOTOR ... 62
                      CHAPTER XII.
                      " MAGNETIC LAG " MOTOR 67
                      CHAPTER XIII.
                      METHOD OF OBTAINING DIFFERENCE OF PHASE BY MAG-
                      NETIC SHIELDING 71
                      CHAPTER XIV.
                      TYPE OF TESLA SINGLE-PHASE MOTOR 76
                      CHAPTER XV.
                      MOTORS WITH CIRCUITS OF DIFFERENT RESISTANCE 79
                      CHAPTER XVI.
                      MOTOR WITH EQUAL MAGNETIC ENERGIES IN FIELD AND
                      ARMATURE g^
                      CHAPTER XVII.
                      MOTORS WITH COINCIDING MAXIMA OK MAGNETIC EFFECT
                      IN ARMATURE AND FIELD 83
                      CONTENTS. ix
                      CHAPTER XVIII.
                      MOTOR BASED ON THE DIFFERENCE OF PHASE IN THE MAG-
                      NETIZATION OF THE INNER AND OUTER PARTS OF AN
                      IRON CORE 88
                      CHAPTER XIX.
                      ANOTHER TYPE OF TESLA INDUCTION MOTOR 92
                      CHAPTER XX.
                      COMBINATIONS OF SYNCHRONIZING MOTOR AND TORQUE
                      MOTOR 95
                      CHAPTER XXI.
                      MOTOR WITH A CONDENSER IN THE ARMATURE CIRCUIT . . . 101
                      CHAPTER XXII.
                      MOTOR WITH CONDENSER IN ONE OF THE FIELD CIRCUITS. 106
                      CHAPTER XXIII.
                      TESLA POLYPHASE TRANSFORMER 1 J9
                      CHAPTER XXIV.
                      A CONSTANT CURRENT TRANSFORMER WITH MAGNETIC
                      SHIELD BETWEEN COILS OF PRIMARY AND SECONDARY 113
                      PART II.
                      THE TESLA EFFECTS WITH HIGH FREQUENCY AND
                      HIGH POTENTIAL CURRENTS.
                      CHAPTER XXV.
                      INTRODUCTORY. THE SCOPE OF THE TESLA LECTURES 119
                      CHAPTER XXVI.
                      THE NEW YORK LECTURE. EXPERIMENTS WITH ALTERNATE
                      CURRENTS OF VERY HIGH FREQUENCY, AND THEIR
                      APPLICATION TO METHODS OF ARTIFICIAL ILLUMINA-
                      TION, MAY 20, 1S91 145
                      x CONTENTS.
                      CHAPTER XXVII.
                      THE LONDON LECTURE. EXPERIMENTS WITH ALTERNATE
                      CURRENTS OF HIGH POTENTIAL AND HIGH FREQUENCY,
                      FEBRUARY 3, 1892 198
                      CHAPTER XXVIII.
                      THE PHILADELPHIA AND ST. Louis LECTURE. ON LIGHT
                      AND OTHER HIGH FREQUENCY PHENOMENA, FEBRUARY
                      AND MARCH, 1893. 294
                      CHAPTER XXIX.
                      TESLA ALTERNATING CURRENT GENERATORS FOR HIGH
                      FREQUENCY 374
                      CHAPTER XXX.
                      ALTERNATE CURRENT ELECTROSTATIC INDUCTION APPARATUS 392
                      CHAPTER XXXI.
                      " MASSAGE " WITH CURRENTS OF HIGH FREQUENCY 394
                      CHAPTER XXXII.
                      ELECTRIC DISCHARGE IN VACUUM TUBES 396
                      PART III.
                      MISCELLANEOUS INVENTIONS AND WEITINGS.
                      CHAPTER XXXIII.
                      METHOD OF OBTAINING DIRECT FROM ALTERNATING CUR-
                      RENTS 409
                      CHAPTER XXXIV.
                      CONDENSERS WITH PLATES IN OIL 418
                      CHAPTER XXXV.
                      ELECTROLYTIC REGISTERING ]!UETER . 420
                      CONTENTS. xi
                      CHAPTER XXXVI.
                      THERMO-MAGNETIC MOTORS AND PYRO-MAGNETIC GENE-
                      RATORS , 424
                      CHAPTER XXXVII.
                      ANTI-SPARKING DYNAMO BRUSH AND COMMUTATOR 432
                      CHAPTER XXXVIII.
                      AUXILIARY BRUSH REGULATION OF DIRECT CURRENT DY-
                      NAMOS 438
                      CHAPTER XXXIX.
                      IMPROVEMENT IN DYNAMO AND MOTOR CONSTRUCTION 448
                      CHAPTER XL.
                      TESLA DIRECT CURRENT ARC LIGHTING SYSTEM 451
                      CHAPTER XLI.
                      IMPROVEMENT IN UNIPOLAR GENERATORS . . . 465
                      PART IV.
                      APPENDIX : EARLY PHASE MOTORS AND THE TESLA
                      OSCILLATORS.
                      CHAPTER XLIL
                      MR. TESLA'S PERSONAL EXHIBIT AT THE WORLD'S FAIR . . . 4.77
                      CHAPTER XLIII.
                      THE TESLA MECHANICAL AND ELECTRICAL OSCILLATORS... 486
                      • CHAPTER XXXVI.
                        RATORS , 424
                        Heat pulse magnetic switching enables 200Gb/s hard drives – Computer Chips & Hardware Technology | Geek.com
                        Physicists 'record' magnetic breakthrough
                        has demonstrated that the positions of both the North and South poles of a magnet can be inverted by an ultrashort heat pulse, harnessing the power of much stronger internal forces of magnetic media.
                        • Shall we continue the Dance of Synchronicities
                          Walter Russell the Universal One Alchemy Chemistry
                          P 168
                          Tesla Patent 396,121 - Thermo-Magnetic Motor
                          TESLA PATENT 396,121 THERMO-MAGNETIC MOTOR. + Joule Ringer ...... ( think heat "problem" with the joule ringer )
                          In Figure 1 the permanent magnet N is connected with a frame, F, supporting the axis M, from which the arm P hangs, and at the lower end of which the armature A is supported. The stops 2 and 3 limit the extent of motion, and the spring W tends to draw the armature A away from the magnet N. It is now to be understood that the magnetism of N is sufficient to overcome the spring W and draw the armature A toward the magnet N. The heat acting upon the armature A neutralizes its induced magnetism sufficiently for the spring W to draw the armature A away from the magnet N and also from the heat at H. The armature now cools and the attraction of the magnet N overcomes the spring W and draws the armature A back again above the burner H, so that the same is again heated and the operations are repeated. The reciprocating movements thus obtained are employed as a source of mechanical power in any desired manner. Usually a connecting-rod to a crank upon a fly-wheel shaft will be made use of, as indicated in Fig. 10; but I do not limit myself in this respect.
                          url=http://archive.org/stream/inventionsresear00martiala#page/392/mode/2up]The inventions, researches and writings of Nikola Tesla, with special reference to his work in polyphase currents and high potential lighting[/url]
                          CHAPTER XXXVI.
                          RATORS , 424
                          (31) Law of Catalysis
                          "The presence of harmonics and discords."
                          P 168 also called The Feminine Pole
                          • found the following vid :
                            TESLA, the Accomodation of Angels - YouTube
                            "Tesla, the Accommodation of Angels" (Tesla ili prilagođavanje Anđela) is a play based on a real article (interview for Colorado Springs' "Immortality" magazine).
                            unfortunately it is in Russian ..... not giving up yet :
                            Interview with Nikola Tesla from 1899 - freedomtek.org
                            Very interesting interview Nikola Tesla and John Smith in which he said: Everything is the Light. In one of its rays is the fate of nations, each nation has its own ray in that great light source, which we see as the Sun. And remember: no one man that existed did not die.
                            Pier Ighina's Cosmic Energy Inventions - The Tesla / Reich / Keely of Italy - English Subtitles - YouTube
                            TESLA: It is the psychic discharge or a warning to be alert. The light was always on my side. Do you know how I discovered the rotating magnetic field and induction motor, which made me became famous when I was twenty-six? One summer evening in Budapest, I watched with my friend Sigetijem sunset. Thousands of fire was turning around in thousands of flaming colors. I remembered Faust and recited his verses and then, as in a fog, I saw spinning magnetic field, and induction motor. I saw them in the sun!
                            The glow retreats, done in the day of toil;
                            It yonder hastes, new fields of life exploring;
                            Ah, that no wing can lift me from the soil,
                            Upon its track to follow, follow soaring!
                            Faust
                            TESLA PATENT 396,121 THERMO-MAGNETIC MOTOR. ....... The Animals - House of the Rising Sun (1964) HD/Widescreen - YouTube
                            TESLA: Yes, these are some of my most important discoveries. I'm a defeated man. I have not accomplished the greatest thing I could.
                            JOURNALIST: What is it, Mr. Tesla?
                            TESLA: I wanted to illuminate the whole earth. There is enough electricity to become a second sun. Light would appear around the equator, as a ring around Saturn.
                            Mankind is not ready for the great and good. In Colorado Springs I soaked the earth by electricity. Also we can water the other energies, such as positive mental energy. They are in the music of Bach or Mozart, or in the verses of great poets. In the Earth's interior, there are energy of Joy, Peace and Love. Their expressions are a flower that grows from the Earth, the food we get out of her and everything that makes man's homeland. I've spent years looking for the way that this energy could influence people. The beauty and the scent of roses can be used as a medicine and the sun rays as a food.
                            Life has an infinite number of forms, and the duty of scientists is to find them in every form of matter.
                            Three things are essential in this. All that I do is a search for them. I know I will not find them, but I will not give up on them.
                            JOURNALIST: Have you ever married? It is not known that you have affection for love or for a woman. Photos from the youth show you were handsome man.
                            TESLA: Yes. I did not. There are two views: a lot affection or not at all. The center serves to rejuvenate human race. Women for certain people nurtures and strengthen its vitality and spirit. Being single does the same to other people. I chose that second path.
                            TESLA: The knowledge of how the mental and vital energy transform into what we want, and achieve control over all feelings. Hindus call it Kundalini Yoga. This knowledge can be learned, for what they need many years or is acquired by birth. The most of them I acquired by birth. They are in the closest connection with a sexual energy that is after the most widespread in the Universe. The woman is the biggest thief of that energy, and thus the spiritual power. I've always knew that and was alerted. Of myself I created what I wanted: a thoughtful and spiritual machine.
                            Mayan Numbers Symbols
                            9 - Highest Female Authority. 9 levels of creation.
                            • Let me show you a simple application ( open source of course ) based on Tesla's Patent
                              one of the major problem with solar Panel is Tracking the Sun ..... now let me borrow your imagination for a second :
                              Sunflowers inspire more efficient solar power system
                              It's a clever bit of natural engineering that inspired imitation from a UW-Madison electrical and computer engineer, who has found a way to mimic the passive heliotropism seen in sunflowers for use in the next crop of solar power systems.
                              Unlike other "active" solar systems that track the sun's position with GPS and reposition panels with motors, electrical and computer engineering professor Hongrui Jiang's concept leverages the properties of unique materials in concert to create a passive method of re-orienting solar panels in the direction of the most direct sunlight.
                              His design, published Aug. 1 in Advanced Functional Materials and recently highlighted in Nature, employs a combination of liquid crystalline elastomer (LCE), which goes through a phase change and contracts in the presence of heat, with carbon nanotubes, which can absorb a wide range of light wavelengths.
                              "Carbon nanotubes have a very wide range of absorption, visible light all the way to infrared," says Jiang. "That is something we can take advantage of, since it is possible to use sunlight to drive it directly."
                              you can do the same with magnets and light concentrators ..... the devil is in the details .... and it can be a stand alone set up ..... connected to the solar system
                              borrowing from the design of another type of solar system : ( why because its fun )
                              V3Solar's Spinning Cone-Shaped Solar Cells Generate 20 Times More Electricity Than Flat Photovoltaics | Inhabitat - Sustainable Design Innovation, Eco Architecture, Green Building
                              • Words from a Wise Man :
                                Thomas Henry Moray :
                                a good friend of mine emailed me the following recently : ( believe it was mentioned briefly earlier in our discussion )
                                Can Earthing Help Adrenal Fatigue? | Food Renegade
                                For most of human history, we have spent our lives connected to the earth.. We do everything in an un-grounded state. In short, we are rarely, if ever grounded anymore.
                                ps: it is good to let children run bare feet in a natural setting
                                did you ever wonder why , whenever you go the beach ..... you dig your feet in the sand ( sand = silicate )
                                Analogy is perhaps the most powerful conceptual tool for understanding new phenomena or opening new areas of investigation
                                Thomas H. MORAY
