Side Note: from: http://www.energeticforum.com/psychi...ntenna-18.html
Here is a little fact finding for you:
OUM HANCH FOUM ZGUID MONUMENT HOSTOURIQUE
Known for their ancient knowledge:
and if you read the description of the oasis...you notice quite a bit of Harmonic Math (imo ) abouthow and where it was built
The myth is due to a contract between a snake and a noble man whose name is Ben Naser, indicating High Esteem
THE JEWS OF THE CASBAH
Thirty lived in the casbah, the majority of them are landowners there were also among them blacksmiths, merchants
Originally posted by MonsieurM
(3 6 9 ; harmonic math )
When energized, it will create energy flow within each set resulting in toroidal motion of energy when cones in each set are intercepting. Also, this will create enough disturbance in surrounding Aetheric field to cause a flow of energy into the device. The result, spherical field in the center, between apexes which can be concentrated or pulled into the oval shape by moving coil sets apart. I imagine that without proper control this system may become runaway due to the enormous amount of energy flowing in. Each set of coils will amplify the output going back into the input (microphone on the speaker effect). If this make any sense (my understanding) then Russell letter to NORAD with request to notify president will make alot of sense. This source of energy discovered by him will indeed shadow any other form known to man back then and today.
