Hi folks, Hi gyula, thanks for the information, with the 12 volt setup there is probably some excess bouncing around in the transistor causing that effect.
Hi guruji, thanks for the tip, yes I'm trying all sorts of different configurations and having good results.
Hi nickz, thanks for the compliment. I decided to try the same leds that are in the christmas led string, the warm white flat top ones and use those in place of the other parallel leds on the kooler type setup.
They work much better at creating more usable light, by spreading all around and for a little less input it seems than the other 5mm white/bluish leds.
What I did was try the standard joule thief output off the emitter/collector with 8 leds in parallel. Since I used only 2.6 volts or 2, 1.2 volt AA's it worked for that setup and drew 62 milliamps or 161 milliwatts, I would estimate they are just about full brightness, maybe 95%. Which makes that much more efficient than my 12 volt setup.
I may have to try, just to see, how the 12 volt circuit can run the leds in parallel off a low turn pickup coil, hope the leds stay alive.
peace love light
tyson
peace love light
tyson
