Earth Ground vs Magnets
  • Earth Ground vs Magnets
    Hi all,
    I've been reading about energy taping devices for a couple of years now, I'm still very new to this field. I have the privilege of not have been thought what is possible or impossible to do with an electrical circuit.
    What I've understood so far basicly is if you want to capture energy in a system, ( COP > 1 ) it has to be an OPEN LOOP.
    In my awareness, the most common ways to offer a "return path to the Ether" withou destroying the dipole you just created ,is either an earth ground or magnets. In my view, they both do the same thing. They connect to the natural river of magnetic particles that flows from the ionosphere to the earth. This is the other way around if you are in the southern hemisphere.
    These magnetic particles are neutral until we polarize them into electricity, as it done with conventional electric generators. This destroys the magnetic balance of the Earth. The only way to avoid this problem is to use the neutral magnetic flux as such, and return it to the earth ground.
    This is easier said than done, as it require a whole new thinking and new hardware and equipment to do that. The benefits are many. Neutral magnetism can be converted into an infinite number of polarities. We can do with neutral magnetism all the things we can do with electricity and much much more. We can create and dissolve matter, create force fields, transmute toxic elements into benign substance, etc.
    Magnets have a "draw factor" to the atmosphere, so they act like a "magnetic reservoir" that fills itself up from being in the flow of the magnetic river that flows from the atmosphere to the earth. It is my intuition that they act like "virtual earth ground".
    In circuits where you need an earth ground but you can't have it, as in a vehicle for example, this is what I'm proposing:
    Bagel coil :: virtualground.jpg picture by felaudet1 - Photobucket
    If anyone can expand on that, I'd be happy to hear you.
    Originally posted by Felix_the_cat View Post
    Hi all,
    It is so weird, i was just reading this website on Earth Resonance and the Pyramids, it talks about the same principle you've just described
    The most efficient shape to produce a focused electric field in order to create an ionized beam that would be used as not just an antenna but as a conductor to the ionosphere, is that of the pyramid. A conical shape would also work but when building a large structure out of available materials then the pyramid shape wins out. Not just any pyramid shape but one that has the exact shape as the great pyramid at Giza.
    I'm posting this not to derail you from the subject but to extrapolate from this article the info that could be applied to your concept
    Have a look at this post, http://www.energeticforum.com/144162-post23.html , Roy Meyers may have been thinking along these lines as well.
    Signs and symbols -Confucius.
      Scalar waves / Tantratron / Part 1 | Real Do it Yourself Energy
      First public release of tantratron plasma Zero Point Energy (ZPE) reactor technology. Part 1 provides some laboratory setup in order to progressively master ZPE using path of high voltage to stress Aether or Vacuum with different applications (free energy device and healing device). (PUMP) and extracted energy (IDLER) with minimum input power (SIGNAL). About SerialPro arduino-java protocol, please contact Alvaro Lopes on: github.com or Arduino - HomePage
      Edward Leedskalnin: Magnetic Current
      The earth itself is a great big magnet
        As I was reading the first post and saw the pic, the immediate thoughts were for virtual grounds in solid state Tesla tower experiments.
        Normally, a virtual ground would be a large lump of some metal or other, computer processor heatsinks etc. Large, clumsy but they do work.
        I'll try the magnet method, start at a very tiny size and increase the metal content and see what happens !
          observation
          I would like to add an observation I have seen now for some time in my own pulse motor experiments.
          I often run my motors for 24 hours non stop when I am testing new data.
          What I have seen is that the energy output is not constant when it should be.
          if no other parameters of the motor change. Why does the output voltage rise
          at certain time during the day and with certain weather condition's. The extra
          Power flows in from some where.
          I have seen one of my Adams motors go OU during a storm event. and On a bright sunny day.
          I have watch the battery charge up while supply power to the motor.
          I just have not been able to create this condition at will
            the power corporation
            This then begs the question How much extant energy do all the power corporation get from the grid. That is free earth energy. I bet if you could calculate the energy they create from burning coal and other rescores. That would not equal the amount of energy consumed by the usurers
            They have there big generators grounded and the power lines running across the county like giant antenna. At 60 hertz why 60 hertz?
              The UK and many other counties use 50hz
                I would venture an explanation , the phenomena you are seeing, is the effect of the alignment of other coils around you and above you (ie: sun, moon etc...).
                many of the experiments done by previous inventors noticed that if you placed the experiments in a certain direction (north, south) you increase the power generation of the exp.
                if you read Edward Leedskalnin: Magnetic Current above mentioned quote, it would sound like there is a "river" flow of "magnetic elements" between Earth's North Pole and South Pole...
                ps: toranarod have you thought about the 6,3,9 combination i posted in muller replication
                  we use 50Hz here in Australia too. I just quoted 60 because most readers are American.
                    50 - 60 hertz
                    Hi there Rod ,
                    You proberly know this - Low hertz = low interference to other frequencies like radio , safer on the human body , no noticeable hum from transformers , costs more for you to run things and a few more i carnt remember . 60 hertz is a longer wave length than say 1khz so thats why they use it on high powered lines with high voltage and little amps this travels in the wires with less loss . cheers Jason ps efficientcy in long wire lengths is achieved by low hertz , high voltage , low amps you get my drift
