Got a problem of understanding here.
I was looking for MOSFET's and whatnot on old PC monitors earlier and found what looked like a small transistor, but with odd numbering.
BT169D
Googled the datasheet and got this: BT169D Datasheet pdf - Thyristors logic level - Philips
The thing is about these, they are used as latches. A small current comes in at what would be a transistor Base and the unit switches on....and doesn't stop conducting.
I've found out that there is a mode where they shut down once the input current goes below a certain level and, presumably, that is what's happening here, hundreds of times per second. However, it should then latch, as online circuits for buzzers and other triggered alarms show.
I don't really know, but the motor runs well
There is a 1K resistor on the middle triggering leg. The Negative supply comes in on leg 1 and leaves on leg 3. I would think it's a bit like a MOSFET, but again have no real idea. Only other thought is that the collapsing coil AC is backing up via skin effect and causing the switch (a multi-strand 7 wire).
What's goin' on ?
Here's the video - please do note I must apologise, the vid says DT169D, not BT169D.
YouTube - ‪Thyristor powered pulse motor‬‏
BT169D
What's goin' on ?
