Originally posted by dR-Green
Do you have an oscilloscope?
Physical relays are good for extreme power switching, but they waste a lot of energy and they limit the frequency of switching. I suggest using a rotary commutator if you want to try physical switches instead of transistors. Connect the shaft of a regular DC motor to the shaft of one from which you have removed the windings. Drive the regular DC motor normally to get the desired spin rate, and use the commutator from the second DC motor which has had the windings removed to make and break the circuit containing the primary.
Probably more dangerous using the flyback though because I really have no idea what's coming out of it.
If you see a strange object in orbit tonight you'll know why
Which took many more hours than planned. I might have made more work for myself than I needed to because since the simple SEC experiments I figured things like a wooden base right next to the coil would affect it. So I thought better do it this way in the first place.
