And besides, you need to explore your surroundings in order to know where you were to begin with
Anyway, I do believe that Eric's comment has been quite helpful, combined with the limited experimentation so far. This might not be an accurate way of describing it in words, but I think the solid state method would need "many" primary turns to tune it efficiently because the relatively low power disturbance needs to excite the secondary somehow - so you need a bigger hammer as in the analogy below. But with big discharges, or harder strikes, you can use only one turn, sort of like you hit a bell in one spot and then the whole thing resonates. (Also any attempt to hit it in different places at the same time will have a damping effect and stop the ringing, and so will using a bigger hammer due to the bigger surface area making contact and damping the vibration). So you do (some of) the tuning with the capacitor and spark gap, which is the rate and force with which you hit the bell if you will. So the primary simply acts like a hammer, delivering "strikes" that cause the "bell" secondary to "ring" or resonate. The secondary is tuned to quarter of the rate that you're banging the hammer, so that the voltage peak occurs at the end of the wire or the terminal, not further down and result in a ball of fire as we have previously established.
That all seems relatively straight forward if I've got it right. So I suppose the next unknown is the relation of the secondary to the extra coil.
Honestly, this concept is a step beyond my understanding of radio and worthy of investigation. Umm, thinking about it, you might be able to replace the condenser with another half-wave coil and accomplish the same effect (educated guess, by no means certain as it would make the secondary both 1/4 and 3/4 long while making the extra 3/4 and 1 1/4 long, all of which are viable receive lengths).
