I have stumbled upon that strange contradiction in Tesla words also. Once he said he is using high frequency then he stated frequency not higher then 35Khz or EM radiation occur.
After years of thinking I think I found astounding simple explanation of this contradiction, of course I'm only guessing.
Tesla never said about frequency in our current meaning of this word, except maybe when decribing Hertz radiation which is EM waves.
Tesla always work with speed of propagation of (longitudinal, sound-like) wave and with wavelength of it. He didn't need frequency, but he used this words as a the term for "repetition in time". So he produced very high frequency vibration (he was unable to measure actual frequency of it but he guessed it is much more then Mhz range) and the repetition of them or the train of vibration was his frequency of transmission wave.
You have to have a nice clean space between sounds of whistle or other instrument or you have dissonance when they overlap. This dissonance is radio or heat radiated in space. The other limitation is Earth system. Per analogy it is like ball filled with water and hydronic pump store energy in it (TMT). In receiver place pops a little bubble but it depends on elasticity of water surface. To fast pumping action and the wave forming bubble is too fast and elasticity cannot hold it back in regular oscillation mode and it breaks and spread water around.
Nikola Tesla :: Tesla wireless system picture by boguslawb - Photobucket
I had to change from 28.8g 13 metres of 24 SWG wire to 28.6g 8.25 metres 22 SWG because the 24 SWG wouldn't fit. (So now I also have 2 matching lengths of wire to make more secondaries for the small coils). But the output is better than before, also using 50pF more capacitance. Same spacing between the turns on the extra coil as there is in the spiral coil. Obviously the "resonant length" or whatever hasn't been taken into consideration here because I did it by weight. Originally the 24 SWG would have been the same length as the spiral primary but since it didn't fit on the frame, there's now about 8.25m of thicker wire. I'm pleased with the results so far anyway. I'll post all the details and measurements soon. My initial thought, also since I tried about 21m of 26 SWG once before, is that the extra coil should not be longer than the secondary. Shorter seems to be ok, but longer did not yield good results. But that coil wasn't a "real" test so I can't be sure about that at the moment.
