I like your concept, how far along are you with this? one of the great things about the Tesla turbine was it's ability to operate at reduced temperatures - do you expect your unit to maintain this advantage?
We are an innovative company and we are always on the lookout for technology that we can use to help our clients - even if this means working with developers to bring their concepts to market. we always work under confidentiality agreements (NDS's) and are happy to help source financing and support for idea's that can be shown to work.
I already built the core of the engine and tested it by forcing compressed air at 20 PSI and it looked promising in terms of high rotation speed and it multiplies the air output. Attached are some pictures of the core. Hopefully by the next month I can run it on propane after I install the igniters and so on there is still much to build.
My email is michaellabib AT gmail DOT com . You can drop me a line and I will send you more details. Thanks.
however if you add a sawtooth around the edge this will give greater speed.
The nozzle feeding the turbine should have a converging / diverging profile. (venturi) the inlet wants to be rounded sides, the angle of the diverging output is extremely
You are welcome. I have read the book and it is fascinating for its research as well as the additional information. You can order it from Amazon.com. I have bought two of them:-) and I am not sorry. One goes round the family and one has gone to my naturopath. I have also started imaging as per Mr. Bengston. It is difficult, but doable and learn able. It is most likely going to be useful even for other things.
I am using 4 nozzles and at the compressor the port intake is 1 cm and the air gets out from a 0.5 CM and the opposit at the turbine stage.
Hi Michael, I find this most interesting, and hope you will continue to post and show progress. I'm not sure how I found this thread for I spend most of my time here in the renewable energy area. I believe if you were to move this thread there, you would find many much interest in your turbine.
best luck to you, Gene
