Trees as radiant energy collector
  • sucahyo
    Will do...
    note: what would you guys recommend for nonconductive strip, i was thinking electrical tape in several layers could make for some good insulating strip in the Mobius Resistance and for the conductive material maybe aluminum or just two copper wires
    Layering metal/insulation will do something else.
    I think copper and aluminium will produce different effect.
  • MonsieurM
    Actually, I had an epiphany, I just thought of the perfect conducting material and actually it is something scientist just found out about and you can reproduce it....
    So for the Mobius Resistance, You'd Need:
    Electric Insulating Tape
    and GRAPHENE:
    Not only is graphene the thinnest possible material that is feasible, but it's also about 200 times stronger than steel and conducts electricity better than any material known to man—at room temperature.
    Graphene Will Change the Way We Live | Dr. Kaku's Universe | Big Think
    Here is a video on how to make Graphene, using your electrical Tape
    YouTube - ‪What is Graphene?‬‏
    YouTube - ‪Making Graphene 101, Ozyilmaz' Group‬‏
    YouTube - ‪Bottle plasma reactor - Part 1‬‏
    (there are more vid on youtube)
  • MonsieurM
    Replace the mobius with simple coil, put capacitor in mobius end, and lastly, try without any copper wire at all.
    Will do...
  • sucahyo
    Could you elaborate so i can try to reproduce it ?
  • MonsieurM
    Let's get back to our subject at hand: Trees as radiant energy collector
    I would like you to have a look at the following:
    Abstract --- An earth battery which includes a first electrode which is a veined material located in the earth, (a tree for instance) a second electrode electrically connected to the surface of the earth and disposed in a hole which extends from the surface of the earth into the first electrode, an electrolyte disposed in the hole and in contact with the first and second electrodes, and means for electrically connecting the first electrode to the surface of the earth. A seam of coal is preferred as the first electrode. A method of mining metals located in the earth using the earth battery and a method of drilling holes in the earth are also disclosed.
    list of all type of earth batteries:
    Earth Battery Patents
    see the first electrode (ie the tree )
    Justin CHRISTOFLEAU -- Electroculture book & patents
    Note: All these great discoverer have succeeded in reverse engineering Nature's work, and here we are trying to re-reverse engineer these great inventions in order to use Nature's Antennas to capture/transmit/converse/transport, and all it takes is the success of one experiment (a small Domino that is reproducible)- To you all Neo-Alchemist of modern times, you may not know it yet, but you are doing Nature's Work.
  • MonsieurM
    A video i found on youtube about Caduceus Coil:
    The Hyper Dimensional Resonator use an 115V AC electric current to generate the magnetic field. This is rectified to DC by six rectifier diodes and sent via a caduceus coil to a copper magnet wire wound around a soft iron core. It is my belief that the caduceus coil generates scalar waves.
    YouTube - ‪HDR versus magnet‬‏
    YouTube - ‪Lenz's Law - Caduceus Coil - Bedini - Perpetual Motion Holder - Leedskalnin Montage‬‏
  • MonsieurM
  • sucahyo
    Maybe you can test without copper, with selenoid and mobius with capacitor?
  • MonsieurM
    Based on the video i just posted, and the principle of electro-culture:
    Introduction
    The application of electricity, magnetism, monochrome light, and sound can stimulate the growth of plants to a great extent. This little-known technology, called Electro-culture, can accelerate growth rates, increase yields, and improve crop quality. Electro-culture can protect plants from diseases, insects and frost. These methods also can reduce the requirements for fertilizer or pesticides. Farmers can grow bigger and better crops in less time, with less effort, and at a lower cost.
    The several approaches to Electro-culture include: antennas, static electricity, direct and alternating current, magnetism, radio frequencies, monochrome and intermittent lighting, and sound. The energies are applied to the seeds, plants, soil or the water and nutrients. Robert A. Nelson
    You could recreate the same experiment with the sun's electromagnetic rays.
  • MonsieurM
    In the video you'll see two colors different from before, because i used Phenol red to mark the color difference in ph (note it is blue because of the presence of chlorine in acid water)
    (at 5 sec, i let the current pass) The haze you see are the bubbles formed
    I wrap it around a open ended plastic tube (one end of the coil dipping in water and the other vertical like an antenna), and plunged it in a glass of Alkaline Water for 24 hours. I noticed after that a cluster of bubbles around the coil only. I then tried the same experiment with the double mobius-Caduceus coil, but this time with a test tube filled with acidic water plunged in alkaline water (one coil's end dipped in acidic water, while the other used as antenna, same for the other coil but dipped in alkaline water). this time the bubbles formed in the walls of the glass and around the coils...Anyway just wanted to share this info with you
    I hope someone will try to reproduce this and let me know how it goes...
    from THE STUBBLEFIELD PAPERS
    It describes a device which uses a copper coil wound together with an iron coil side by side which is immersed in water. So far so good. The water as an electrolyte would cause the iron and copper to react with each other creating a galvanic element capable of generating electricity. Next he tells us that the copper wire must be insulated! From the iron wire! He also states that insulating the iron wire has no detrimental effect on the operation of the device.
    ps: make sure your wires are well insulated
  • MonsieurM
    Ok, remember this set up:
    well, i thought it would be a good idea to see what happens when you connect both "aerial" antennas to the wall socket (of course using a power cord i got from a lamp, ), anyway, as soon as i turn the power on, immediately
    an excessive amount of bubbles started forming (i filmed it, i'll try to post it), and a green foam formed on top of the water, and the glass was really hot (left it on for 1 min)....
  • MonsieurM
    As i was searching for some more info to provide you guys with on advancing our research, I stumbled on this little info which i thought it was worth sharing, especially after i learned about the caduceus coil
    Richard DAVIS
    Non-Inductive Resistor
    The Problem:
    To develop an electrical resistor that has no residual mutual- or self-inductance at high frequencies.
    The Solution:
    A Moebius strip made of insulated resistive materials with electrical leads attached directly opposite one another provides a noninductive, nonreactive resistor which is simple, inexpensive, and flexible in usage, and can be made to almost any desired size and shape....
    ....Two ribbon conductors of equal length are affixed on opposite ends of a strip of dielectric. The assembly is then given a single twist and the ends are joined to form a Moebius surface. The ends of the conductors are soldered together and the resistor terminals are attached to the directly opposed solder joints. Current applied to the terminals will travel in opposite directions, so that the electromagnetic fields cancel each other, resulting in an essentially noninductive, nonreactive resistor with a low time constant. Bifilar wire may be used instead of resistive ribbon, eliminating the need for a center dielectric strip. Thin film conductors on flat surfaces can also be used to make Moebius resistors.
    Two or more sets of resistive wire may be mounted laterally on the same nonconductive strip, with about 1/16-inch spacing, and connected to form multi-Moebius resistors in one unit. There is no change in the time constant of the individual resistors, nor does one in any way affect the operation of the others, even when they are assembled in parallel or series.
    The performance of the Moebius resistor is unaffected by its form, size, or length. Once it is connected into a Moebius shape, it can be folded or around around a cylindrical core or a card, or even into a ball, resulting in compact packaging of the resistor for use in miniaturized circuits. The Moebius resistor does not couple to metallic objects, external fields, or itself. When the bridge is nulled the resistor can be handled or changed in form without disturbing the balance. The conductors must not be touched and the spacing between them must not be altered.
    Add to this:
    The caduceus coil illustrated in Fig.1, basically consists of ordinary insulated copper wire wound in a double-helix around a ferrite core. THIS COIL HAS REPEATEDLY BEEN FOUND TO VIOLATE ESTABLISHED LAWS OF ELECTROMAGNETICS AND HERTZIAN WAVE THEORY WHEN A HIGH FREQUENCY CURRENT IS INJECTED INTO IT....
    ....First. This apparatus has zero impedance - unlike an ordinary coil. when fed electrical energy the wire in the Tensor coil does not get hot.
    Secondly. It has infinite resonance - unlike an ordinary coil which will resonate chiefly at its natural fundamental frequency and weakly on the second or third harmonic, the Tensor coil is capable of resonating strongly on any number of frequencies randomly spaced in the spectrum. The signal pumped into such a coil strangely enough cannot be quantified (detected) by standard RF (radio frequency) detection apparatus. Many "Ham" radio operators and electronic technicians who have used these coils, are completely baffled by them
    I remember reading about you guys having the kind of problem being described...well enjoy
    Richard L. Davis: Non-Inductive Resistor (Moebius loop)
  • MonsieurM
    post#94 updated added pics
  • MonsieurM
    I wonder what is the "shadow" of other coils and if they resemble any known wave figure ?
    use a light to project the shadow on the wall (the question remains at what angle should the light hit the coil , that is why experiments are made for )
    Live Curious
    If you are you breathe.
    If you breathe you talk.
    If you talk you ask.
    If you ask you think.
    If you think you search.
    If you search you experience.
    If you experience you learn.
    If you learn you grow.
    If you grow you wish.
    If you wish you find.
    And if you find you doubt.
    If you doubt you question.
    If you question you understand
    and if you understand you know.
    If you know you want to know more.
    If you want to know more ...then you are alive
    National Geographic
  • Farmhand
    Yes it is two sine wave's but the peaks are in phase but the sine wave's are crossed, wow that is wierd alright, everthing wierd is good as far as I can tell though, so far.
    Good observation.
