Clean energy beeing discovered
  • Clean energy beeing discovered
    Completely without pollution of environment: Zero point energy of the quantum vacuum, abbrevition: "ZPE"
    Already motors available with certification.
    The energy is for free for everybody, coming from the universe.
    Disadvantage: It is not yet known by many people. And it requires still scientific work before it can go to series-production.
    Advantage: Without radioactivity, without combusting matter, without paying necessary.
    Only it many people know about it, we will get it. Market only produced products, for which people are asking.
    Prof. Dr. Claus W. Turtur ?
    SIR
      GB
        It would be good to post information (links, photos, description as PDF) about these motors, so that many can see it.
        Greetings, Conrad
        P.S.: I just found this file https://www.ostfalia.de/export/sites...speed_EMDR.pdf depicting a little coils (one coil for each magnet at the circumference of the rotor). This poses a real design problem (nowhere to hold the ring carrying the magnets)!
          CINATOTO adalah platfrom yang bisa membuatmu ketagihan dengan kemenangan dan keuntungan besar yang di berikan untuk para pecinta game online.
            "zpe"
            Very basics
            OS: Claus W. Turtur: Zero Point Energy Converter in the Kilowatt Range - PESWiki
              Based on the theories of Prof. Turtur, one can go a long way into explaining Stan Meyer / Andrea Puharich's car/motor cycles running on water as well as Edwin Gray's fuelless engine:
              If the electric field indeed is an energy source, powered by ZPE trough charge carriers as electrons and atom nuclei, then you can use the energy source known as the electric field in various ways. It appears that Meyer, Puharich and Gray all three put some coil configuration into resonance, powered by the electric field without the application of an externally supplied current.
              It appears that Kapagen used bifilar wound coils, one clockwise, one counter-clockwise wound, in order to supress the magentic component of the traveling electric waves. So, it appears one can generate pure electric waves, in contrast to the more familiar electro-magnetic waves. Based on this, I have I have posted some ideas about some new combinations of various ideas floating around on a.o. this forum. See:
              Unfotunately, I have not been able to experiment lately, so until I or someone else find some time, these ideas remain untested that may or may not work.
                A possible implementation: basic considerations
                I read through this file:
                What I get out of it:
                - A rotor with 16 magnets on its circumference (alternating polarity) is spun inside a coil L. The 16 magnets (as opposed to only one magnet) allow to reduce the revolutions per minute of the rotor to about 4000.
                - the coil L, a capacitor C and a load resistor R are connected to form a L-R-C circuit (see drawing)
                - the number of turns for coil L, the capacitance C and the value of the load resistor R can be calculated
                My naive questions:
                - How should the rotor be spun? E.g. with an electric drive motor?
                - Approximately, how big should the rotor be for a 1 KW version?
                - Once the target revolutions are reached the rotor becomes a self runner? What should be done with the drive motor at this stage? Can it be disengaged or does it have to supply some amount of torque continuously? How high would the input of the drive motor be in case of the 1 KW version (once it has reached target speed)?
                - Can the load resistor L be a filament lamp?
                Greetings, Conrad
                P.S.: I just found these files:
                depicting little coils, one coil for each magnet on the circumference of a rotor. The rotor has to be a ring, but there would be no easy way to hold the ring!
                  Smile it doesn't hurt!
                  Jesus said,"...all things are possible through God." Mk10:27
                    I wonder, if this latest 'hard Work' from the Max-Planck Institute has something to do with the Term, get Energy from the Enviroment since the Work from Turtur in Germany is a (not to far sproaded) Concept. Oh yeah not to mention, that some Guys allready know, that his flyer create "very dangerous and poisening" Ozone
                      Dollard said it too
                      Eric Dollard was also saying this too. By changing the capacitance at a time rate, you can extract energy from the electric field.
                      Where energy is HELD inside the geometry of a coil, energy FILLS the geometry of a capacitor.
                      If energy is quantized (whole numbers) and the universe follows the ratio of Phi, then fibonnaci in design is essential. That's a bit OT though.
                        Herr Turtur
                        IF, you have "motors available with certification", then why not post a link advertising such?? Otherwise all we have is hot air claims which amount to nothing and some very old clips of a electrostatic motor which is USELESS.
                        Show the motor with watts in : power out and it doesnt get simpler than that. Otherwise this is yet another baloney thread going nowhere.
                        TP
                          Hi Professor Turtur
                          I would like to make a zpe generator like this:
                          Can you help us build it, in terms of specifications: coil size and number of windings, capacitor values and resonance frequency of it?
                          It is so similar to a Newman machine, and I want to convert my Newman motor for this purpose. I suppose that if the LC resonant frequency of this device becomes about 50Hz, then if we rotate the rotor, to about 4000 RPM, it will drop down gradually and phase lock at 3000RPM(50Hz*60), No?
                          Thank you for sharing your work with us
                          Elias
                          http://blog.hexaheart.org
