Hi everyone
I've really been pondering the idea of how to use a permanent magnet alternator in a car. I like the idea of not having to excite the magnetic field so that no external input is required to start cranking out juice. No brushes is pretty cool too!
The next thing is that with the extra magnetic flux of the high strength neo's, the alternator pulley could be increased in size to reduce it's rotation speed. Some of you might not think that it is much, but think again. When your motor is spinning at 6k rpm, the alternator is spinning at around 18k rpm!!! With that bulky rotating mass of iron is spinning you better believe it affects the car. With a slower spinning alternator it would really wake up the cars acceleration etc. It has already been proven to be the failure point of VW diesel engines (older 1.9 aaz) that would give out after about 200,000km from the stress of the alternator spinning mass coming to a dead stop because diesel engines fall to idle rpm almost instantly from the high compression.
But now onto the actual charging mechanism. I've thought about using mosfet's but not sure. It would need to be efficient yet robust. It has to handle quite a bit of amps too. SCR's maybe? I've also thought about converting the whole car to run off of three phase power but that would be a regulating nightmare lol. At least the car wouldn't really rust.
Then I thought about even converting the alternator into a bipolar bedini charger. Is that crazy or what? Would a large capacitor and scr dump be enough to supply the cars battery and onboard components? Would the alternator need to be converted to monopole?
I think this would be a great way to harvest some high energy spikes for the plasma spark ignition
