Greetings. Maybe someone out there knows what's going on here? Then again maybe I'm just ignorant of how neons work?? Either way I've never come across anyone else mention this before so here goes... Last night I was playing around with connecting the output of the SG to a 240v to 12-0-12v transformer to see what would happen. With the SG connected to the 240v input end and no load on the transformer output, the neon was flickering away. But here is the strange thing. The lamp I was using to light the room is a regular CFL, and when I moved my head to examine the machine I happened to be causing a shadow over the SG... The neon went off. I moved my head away to allow the light on it, and the neon came back on. I could get the same effect by moving my hand over it but it wasn't as effective, I assume because the shadow of my hand is smaller than my head. I only focused my attention on the neon for a couple of minutes before I tried something else, but later I was thinking maybe it wasn't just the light falling on the neon that was causing the effect, but maybe light falling on the coil or something even more weird like that. So I'll have to repeat the same setup again later and fiddle about some more.
FYI, after I initially noticed the effect, I "tuned" the pot so that the neon was just about lit, so the difference between "on" and "off" was obviously noticeable and easily achieved through blocking the light from the CFL lamp. (Too little resistance and the neon will be permanently lit no matter what you do). The transformer I used was this, the 12v one.
Miniature 250mA Transformers : Mains Transformers : Maplin
The primary winding is around 560 ohms (but I'll have to measure it again to be sure), and the 5-9 ohm secondary windings couldn't produce the same effect.
