I have had an idea for a water purification system for a while now which can be made from simple materials by any person, that does not use consumable materials like carbon for the filtering process.
I am looking for from anybody interested also in this, as I think there are a ton of creative design concepts to be considered with wide implications. This will basically combine a magnet, the kelvin water drop experiment concept, and a naturally induced water vortex.
So here we go (example uses salt water),
Imagine salt water. In water, salt dissolved is in the form of the ions Na+ (sodium positive) and Cl- (Chlorine negative).
Now this salt water is in a round glass cup, with foil on the outside and an insulated electrode straight down its center. If we apply a voltage to the electrode in the center and the foil on the cup, we create a potential gradient across the salt water from the cups circumference towards the center. If the center electrode is +, then all of the Cl- ions will be attracted to it. The cup (with foil on outside) being negative will attract all of the Na+ ions.
Now imagine perpendicular to this electric field (which goes from center out) is a magnetic field. So you could imagine a ring magnet like found in a loud speaker that the cup is resting on.
The charged particles (ions) will experience a force per the right hand rule when they are moved.
Normally, the ions are all scrambled together, meaning no real net charge, and no macroscopic magnetic field interaction takes place, BUT, we have just separated the positive and negative ions.
Now if we give our salt water in the cup a spin, Some ions will be pulled further towards the periphery, and others will be pulled even tighter towards the center. This is the right hand rule showing us that a particle, with charge, moving in an magnetic field will experience a force at 90 degrees to this. This is Lorenz force. This is how Magnetrons work etc.
The advantages now are that we can separate or stratify ions to either the periphery or the center in a very strong way, using static electric field, and static magnetic field both of which really require no real large power for their upkeep. Magnets hold a static B field for years and years, and we can use the kelvin water drop experiment concept to create the needed potential gradient.
The easiest way to create the spin needed to see this strong stratification of the water, is to let the water spin itself! Think water vortex. There are tons of examples out there, and the work of Victor Schauberger has already shown many ways to use a vortex for purification which are right along these lines.
So now you have a vortex with its central axis perpendicular to a magnetic field. You have a potential gradient from the circumference to the center (radial) and you have a separation of ions within the moving mass of water.
As the water drops, you can take advantage of the Kelving water drop experiment concept.
Electricity from water - Kelvin water drop generator - Naked Scientists Kitchen Science 2009
YouTube - Kelvin's water droplet battery problem figured out !!
So now we have the water motion (vortex) and the voltage potential provided by gravity, and the B field provided by permanent magnets!
No HV electronics generators needed!
Now there are many ways to take advantage of this stratification process through the interaction of water in a properly oriented B field and Potential gradient for purification.
I have not yet built this and am looking for help in design ideas. Feel free to jump in.
