Bashar Free Energy Space-Time Antenna Replication
  • #16
    flat triangular surface
    A flat triangular surface subjected to high-voltage AC, approaching and exceeding the breakdown voltage in air will start to form corona plasma at the edges of the triangle, with the effect most pronounced at the apex, if the other corners are closer to ground potential. Arrange 3 such surfaces in a tetrahedron shape, and you will have 3 surfaces discharging at that apex.
    The points closest to the coil, will be the places were an arc can form inside. No wires necessary. You do want to care about the proximity, however.
    The ability to arc varies with distance and the potential on the surface.
    • #17
      Just a note to say your work, thoughts and replication are quite fascinating
      It would be hoped that many people join in, for the exploration of this initially bizarre design.
      The concept seems to appeal to 'nutters' and to be unworthy of considered thought by rational persons...until tested and until proven. And, how could that happen if noone takes it seriously ? It must have been trialed before and found not to work. However, it has and seemingly it did work.
      The biggest problem is probably the space brother link...eyes roll and the next topic is moved along to !
      Would it be an idea to construct a second matched tower and test out the receiver/transmitter idea ?
      Would fields radiate or focus from the pyramid tip at resonant frequencies ?
      • #18
        Slider and All:
        Although there may be more than a couple of us "nutters" out there, remember that both Tesla, Russel, as well as Anka, all are working through intuition. Nobody in this whole world using their best logic has been able to come up with a real Replicable free energy device, up to now, one that can light your house, not just an Led.
        I for one have faith that what is been shown to us for far, is just what it is, an Aether receiving antenna. And is part of a circuit in progress.
        Until we take the time to make it, and test this out, all our speculations are just that, speculations.
        So, has anyone been able to jump start this antenna, and notice any effects yet?
        • #19
          space nutter turn off
          I say let those that are turned off by the alien thing get turned off.
          More fun for us.
          This Bashar character is giving only a modest hint about how to build this
          thing. There are so many specific details that someone could get
          wrong ... and totally fail to get any results -- me included...
          I like that ... its sort of that Star Trek notion of the prime directive ...
          but with a slight "wink" going on.
          Also, I think it is likely true that everything has ALREADY been
          figured out by human beings with respect to this.
          Just searching around on the web for cone shaped coils and their
          applications has led me to find that they are used
          for all sorts of interesting things:
          - magnetic bottle to hold high-temperature molten metals
          - directed beam weapons
          etc. etc.
          So although this idea seams a little crazy at first ... there is
          HUMAN art here already.
          Also, ignoring the alien connection and going all power-conspiracy
          on this thing ... you could argue that this idea is already well
          understood by the so called "black-government" crowd, and not available
          to the great unwashed. I say ... "how dare they!!!".
          That feeling is enough to motivate me in this field....
          even if that feeling is pure fantasy on my part ...
          Also the recent nightmare in Japan is some further motivation
          for as many of us who can to focus on a "human" solution
          to our need for energy.
          You have to tap into psychological energies to motivate yourself.
          I'm a big believer in the "dumbo magic feather" notion or
          Stan Deyo's memorable description of the sci-fi short story "Noise Level"
          by Raymond F. Jones.
          So please ... those who find this interesting, take up the challenge
          to build a working model. Even if we find this thing doesn't work ...
          we learn and there are spin-offs ... as there always are.
          This particular project is so easy ... made out of paper & wire &
          and foil, etc.
          Yes you might need some equipment to measure stuff like scopes and
          signal generators, and multi-meters ...
          Buy them cheap on ebay ... borrow them... do what you can.
          You can use this stuff in many many projects...
          • #20
            the goal
            Someone can certainly try that ...
            My focus though is pure reception of energy though ... letting
            the cosmos be the transmitter.
            However, I have found that an easy way to simulate "better conditions"
            is to turn on my little plasma ball in the room.
            That sucker emits coherent fields that are easily received.
            Another interesting thing I might want to try soon is to get
            my high-voltage AC generator going again and pump this
            coil with some low-current - high-voltage....
            The claim from Bashar is that it needs to be kick started.
            In my mind, I'm thinking ... get this sucker oscillating with high
            voltage ... high enough to start the coronal discharge on the
            tetrahedron's surfaces. Ones that is established ... remove
            the AC power and let the coil ring down....
            The question would then be .. how long does it take to ring down.
            As a pure LRC circuit, L is pretty good ... pretty big.
            R is near zero ... and if I cooled the thing like Tesla recommends
            in his early patents, R could be made to be even better.
            But I'm cool with room temperature for now.. Its only spring.
            The C in my coil must be down in the low 10 to 100 pF range --
            I'm guessing. Self resonance is 1.2Mhz.
            A bigger coil would have even larger L ... and if made correctly,
            C could be low.
            So with all that going on, it can ring longer.
            But now lets consider the ionizing plasma on the plate surfaces
            of the tetrahedron. It is well know that you can use
            ionizing plasma on an antenna ... and you get a gain increase.
            I was reading today about plasma antennas.
            They provide "stealth" from Radar ... and you can do
            very cool things like TRANSMIT ... and then quickly shut
            off the plasma to avoid the ringing that normally occurs
            in wire antenna.
            So the goal here would be to create a device that self powers
            enough to produce a high-voltage just at that coronal discharge point.
            Once there .... "magic happens".
            I love to speculate like this ... but building such a thing might
            be real real tricky and take science and skills and materials
            beyond what can be done with paper and wire and tape and glue.
            Also, the notion of "free-energy" here is just a buzz-word
            to attract attention. This thing would violate no laws of thermodynamics
            since the energy is in fact arriving to it as normal background
            radiation.
            Another thought ... with a "foil" casing around the surface of the
            tetrahedron, you have the surface outside exposed to
            the cosmos ... and the coil inside in a nice Faraday cage.
            That is interesting.
            • #21
              its just engineering
              Originally posted by NickZ View Post
              Slider and All:
              So in the engineering field we start with "proof of concept".
              The first transistor, for example, looked like a piece of crap
              some "nutter" built in his garage. What made it elegant was
              not how it looked, but the science and how it was presented ...
              with an instruction-manual as it where so that others could
              confirm the science.
              Once you have that ... the basic idea is optimized and refined
              and optimized and refined ... and so on and so on until
              you have something really workable ... enough to sell and make
              a revenue stream to fund further research .. and so on.
              So here is the sort of goal I would have in mind here.
              Achieve self powering at these various levels:
              30mW -- Good for LEDs and Joule-Thiefs ...
              500mW -- Good for most low power hand-held devices...
              1W to 5W -- now your talking Cell Phone charging
              15W -- tablet computer, good lighting system for home, etc.
              60W -- modest home computer
              ... etc. etc. getting more and more greedy with power.
              The trend in personal electronics is to go lower and lower in power ..
              as gate count gets smaller and smaller.
              So we need to re-think this power thing.
              As a society, we can be quite happy with low-power portable
              devices. Look at how happy the youth feel with their own personal
              -- all powerful -- cell phone devices.
              The "power" here is not in Watts ... its in the ability to connect
              to people all over the planet, leveraging a HUGE network
              infrastructure ... that all around the planet is getting lower-and-lower
              in power as well.
              So I thinking ... in terms of the scalability problem ... you don't
              want to build something that can be scaled up to
              FUSION reactor. Silly ... crazy ... dangerous.
              Are we really ready for that. I don't think so. There are too many
              crazies out there ... and the planet is not as stable as we would
              like. Where would you put a fusion reactor? Not in my backyard dude.
              The whole high-energy physic crowd is working on DEAD technology.
              It can't possibly be deployed in a safe way. Not yet.
              Not until we reach a level of maturity for that serious level of power.
              No I'm thinking the other way to scale is down at the personal
              level. Each of my little personal appliances should be self-powered.
              Yes they have batteries .. rechargeable ones.
              Battery technology is pretty darn good now ...
              but charging them is the problem.
              Wouldn't it be cool if you could just give someone a recipe ...
              or an instruction manual ... that was easy enough so that
              people could charge their personal stuff.
              Let's start there... and not be greedy for power. :-)
              • #22
                I do hope the use of the word nutter was ok...the intention being to summise the thoughts of the general public, news stories that get tacked on at the end as a now for something different.
                Intuition is something i'm in full agreement about Nick, the things that just seem right, just look like they ought to work. And, you see, this Bashar doodah does have that look, if considered openly by the mind. I mean, there are straight sticks of metal as antennae, dipoles make sense, extending the aerial of a toy car transmitter makes head sense for better range etc. So it is with Tesla coils and the need for those hundreds of winds on the secondary.
                This one fits, or at least really would if it had been made in China and was all over the place on devices.
                Morpher44, yes indeed, the greed of power....but that's the old technology, where that power is required to do jobs that perhaps a different system could effect with more efficiency. We'd have to redesign electronics from the ground up, but at times like these i'm rather glad of some ignorance regarding component needs. I always consider components as building blocks and if it isn't needed I don't put it in the circuit. Most of that thinking, however, is derived from having to salvage parts rather than be able to buy them.
                Along with such thinking comes perhaps my addition to these challenges regarding the Bashar device. I'm from RCGroups mainly, model aircraft building and flying. My focus is normally down at the 1gram-6gram model level..the lightest things. Right now i'm working on wireless electric flight and having so much fun with the Slayer exciter based towers that I often have to remind the self of the purpose ! Such systems may be ideal for testing this Bashar device and for forwarding as transmission towers. I don't know, mere conjecture from a newbie
                One thing appeals, the double cone pyramid shaping. How about a segway thought, that the two pyramids to the side of the Great Pyramid at Giza were actually placed one on top of the other, but one fell off lol
                I'm getting plasma from my present setup and it's an aim to build a lifter type ultra-lightweight object and see if I can get the plasma to do anything useful in terms of lift. I'm imagining 3 plasma producing Bashar systems, each directing plasma at their pyramid top tips and the craft going upward.
                So, the aircraft thoughts, wirelessly and batteryless, was what this thread appealed for. The Bashar idea certainly raised a wonder or two about possibilities on the transmission side, as well as receiving
                That it is intended to receive brings visions of a levitating object !
                The summary from all my rambling (sorry about that), is that the scaling (and probably power) goes down for my interests.
                All fun.
                • #23
                  Ep. 5 - Tetrahedron Casing
                  YouTube - Ep. 5: Bashar Free Energy Space-Time Antenna (Tetrahedron Casing)
                  • #24
                    Ep. 6 - Tetrahedron as a Capacitor
                    YouTube - Ep. 6: Bashar Free Energy Space-Time Antenna (Tetrahedron as Capacitor)
                    • #25
                      Tetrahedron Math
                      Wikipedia saved the day for me on my confusing scale-down
                      of the Tetrahedron.
                      Tetrahedron - Wikipedia, the free encyclopedia
                      The way I solved the problem is as follows.
                      I knew my coil height was 9 inches and diameter I assumed
                      5.75 inch to give a bit of room.
                      So now I wanted to solve the math formula to find the
                      side length.
                      Each of the 4 equilateral panels has 60 degree corners.
                      The top of the coil, I calculated, would intersect the plane
                      through the apex with a length equal to:
                      l = (3.* D) / tan(DEG_TO_RAD(60.));
                      where D is the 5.75in diameter.
                      Thanks to Wikipedia's page, I see that you can convert
                      from that length to a height using the formula:
                      h = sqrt(6.) * l / 3.0;
                      This h is the additional height to tip of apex above the 9 inches.
                      8.131744 inch. Add that to the 9 in and you have 17.13 inch.
                      That is the total height.
                      Now, knowing that height, can work the formula the other
                      way to get the side length
                      a = 3. * h / sqrt(6.)
                      Hence a = 20.98 in...
                      I rounded up to 21 inch ...
                      I hope this helps anyone who might be building a coil
                      of a different size.
                      I recommend building the coil first, and measuring the diameter
                      after its all finished, since after all that handling, things can
                      change just a bit.
                      • #26
                        Ep. 7 - Plasma Ball as Exciter
                        YouTube - Ep. 7: Bashar Free Energy Space-Time Antenna (Plasma Ball as Exciter)
                        • #27
                          of the Tetrahedron.
                          side length.
                          change just a bit.
                          Interesting Wiki page. Off topic a bit but did you notice the images of tetrahedrons formed into a sphere towards the bottom of the page?
                          Could it be that the electro-magnetic properties of Earth are divided in a similar way and that is the source of so-called Ley lines?
                          Perhaps just one coil on top of another exhibits only a small portion of the potential. What if several coils were somehow geometrically configured into a sphere type configuration with points meeting in the center?
                          I know this is waaaay out there but then again???
                          • #28
                            platonic shapes
                            So my vague understanding of this stuff is that molecules arrange themselves in various platonic shapes.
                            The tetrahedron being the simplest shape. Each atom in the molecule has electrons
                            spinning around influencing fields around the molecule.
                            So yeah this is a very complex interaction of matter
                            and I would imagine in certain areas where there might be materials
                            that respond in interesting ways ... giving people headaches ... or
                            making people feel better, etc.
                            Certainly if you went to Fukushima, you would get more than
                            a head-ache. So yeah the rocks in the ground, the trees, everything
                            affects us and there are possibly standing waves in certain places,
                            vortexes, etc. It stands to reason.
                            I was looking at some Walter Russell stuff and see pictures of
                            4 cones, which kinda looks like two bashar coils meeting at
                            an apex. I think there are potentially lots of things to try.
                            Probably what is needed is a good 3-D rendering of the
                            electro-magnetic fields around these models. Using software,
                            one could pick various constants like inductance, resistance,
                            capacitance, the waveform frequency, the voltage amplitude,
                            etc. and then run the model.
                            If the math is right, you could visualize the field interactions.
                            What makes this more complex, I think, is that this is
                            similar to n-body gravitation, in that the mutual-induction
                            is very complex. A computer model would be good to develop
                            to study this problem more rapidly prior to building stuff.
                            • #29
                              All fascinating work. I'm thinking Star Tetrahedron. Also called the Merkaba -In modern esoteric teachings, it is taught that the MerKaBa is an interdimensional vehicle consisting of two equally sized, interlocked tetrahedra of light with a common center, where one tetrahedron points up and the other down.
                              • #30
                                Cap and transformer
                                Hi did anyone tried to take out something from this coil shape?
