Cooling Question
  • Cooling Question
    I know this is a more mundane question, but judging from the out of the box thinking that I have witnessed on this forum, I have a question regarding the cooling of my house.
    I am trying to find a way to reduce my dependence on my central A/C. The A/C is on its last leg and I would like to find a way to avoid the huge electric bills I have in the summer.
    My house is in Houston, TX. Built in 1938 on a pier and beam foundation (meaning that it has a crawl space and no basement). The house is brick and is about 1500 square feet, one story with lots of windows and is north facing. I have two big live oak trees in front of the house, but no real protection from the sun on the south and west.
    The air under the house is pretty cool even in the summer. I believe this house used to have a fan in the floor that drew the cool air up from under the house, but I can't find any information online about this kind of cooling.
    Any ideas about how I can cool my house? I have a dehumidifier that I can run to take moisture out of the air, but that process produces heat.
    I'm open to suggestions.
    Thank you.
    Geothermal, but it could be expensive to set up. Long term you would save.
    FRC
      FRC
      I would love to have a geothermal, but you are right--too expensive and my house is on a small urban lot so there is no room for the equipment to drill the holes.
      Builders are buying up little cottages like mine, tearing them down, and building huge houses, so I don't want to make a big investment. I'm really looking for something to tide me over for less than 5 years.
        Evaporative cooling may be the answer.
        This can be cheaply made using a fish tank water pump and a porous material of high surface area for the water to evaporate off.
        It is very efficient in a dry atmosphere so if a small unit was placed on the output side of an aircon it can significantly improve the aircon efficiency. If placed on the input side it will work too but the efficiency is lower as the air is moister and the temperature gradient across the aircon unit is higher.
        A drop in temperature of 3C below what the aircon is doing is easily achieved using this method, I have done it.
        As it is combined with an aircon unit, the problems with extra moisture are not an issue as the aircon removes it.
        To get the best results you need your evaporative media to be quite deep. Normal commercial units are only 2 to 3 inches, I would multiply this by 3 as a minimum.
        I had a symphony evaporative cooler (cost more than an aircon) that my 5 year old broke by pouring water in the front causing the motor to burn out. I took the media from this and cut it into four pieces, placed it in a plastic box with openings at either end, it was about the size of a car battery. The fish tank pump was used to pump water from the bottom of the box to the top, wetting the media. Wow I had 3 degrees of cooling in 70% humidity.
        This worked for quite a while until my son broke it, he is good at that.
          Maybe
          I live in a place once; it was a real ****hole, but the rent was cheap; when summer came, I found out why.My utility bill was considerably more than the rent.After making sure the meter had been accurately read, and was working right, I complained to the landlord.He had an a/c guy come out, and put a new compreesor on it.But, the a/c guy said it probably wouldn't help.Said it was an old, and so very innefficient a/c unit. He was right, it didn't help, and I ended up moving out.So, a newer more efficient a/c unit may lower you bill, but upfront and payback wouldn't help, unless you culd get some kind of $ from utility or Gov't for going more energy efficient.Jim
              I'm in Houston too, and the way I found was to find a cheap driller crew to dig a well for me, and drop a small 2" schedule-80 PVC casing to maintain the hole.
              We have layer upon layer of aquafer below us, and dropping a substantial length of PEX 1/2" past the bottom as a heat exchanger is the answer for me.
              Pull local drilling records to find which depths water wells are using and avoid them to be fair.
              They are 200' with the last 20' screened NE of Houston as example,
              but there is a 60' aquafer for us due to Lake Houston.
              There is absolutely no way I can pump enough heat into the two 200' pieces of PEX I pushed into the well that will return even slightly warm water upon return.
              I paid abour $22 per 100', so $44 total pipe cost,
              and 120' are wasted in the well casing (60' X2).
              So 80' of randomly exposed loop of PEX sinks any heat I send in.
              People answering perhaps don't really understand just how humid Houston is,
              so hayshakers and the likes just make things worse for most people's health.
              I am using a very small 4000-BTU unit to cool a 46' x 46' building
              because I disassembled the AC and carefully folded down the condensor.
              It is submersed in a four gallon closed bath,
              and the pump is a stainless steel gear type,
              nothing to wear out expect seals.
              It is only rated for 4.0-GPM flow rate.
              the air is 38 degrees sustained from the custom freon mix I used,
              but then again, I hardly expect people to go and do that...
              I also replaced the freon pump with a two speed one.
              Obviously, don't insulate the feed line to the well,
              but do insulated the return line to keep Houston's heat out of it.
              @mbrownn, sir, you have it right,
              if you cannot vacate the heat efficiently,
              your mostly throwing money at fire.
              Stealth has a point too that I have tried,
              but increasing the crawlspace temp hurt the main enviroment.
              I drew air through the center of the building from the crawlspace
              to the attic in a leftover piece of furnace ductwork with a good fan.
              I (instead) elected to cover all the rafters in 1/4" panel,
              and duct the eve's edges to the roof's peak instead.
              I left a small triangle of space at the peak for a horizontal board
              that formed the main exaust duct, and used three solar fans to
              exhaust the roof's shingle heat directly back out to outside
              before it ever gets into the attic in the first place.
              From 145F to 92F is proof that concept works just fine,
              and it is so inexpensive to do yourself too.
              Yes, it helps in the winter too, without the condensation damage risks.
